第54頁,共158頁 第一第一 ... 444525354555664104154 ... 最後最後
顯示結果從 531 到 540 共計 1578 條
  1. #531
    Maple板拿來當墊板的聲音聲音真的很不錯, 不過前提是要夠厚的效果才好
    我推薦這個, 有3吋厚
    http://www.overstock.com/Home-Garden...0/product.html
    謝謝!因為最近想把擴大機放到離喇叭近一點的地上,又不想直接放在地上。本來想去Home Depot買幾塊木板自己黏成厚一點的。現在有現成的更好!
    PS。會想到用楓木是看到這個 http://shop.mapleshadestore.com/Mapl...epartments/46/
  2. The Following 2 Users Say Thank You to Kent Lee For This Useful Post:
  3. #532
  4. #533
    請問phasetech/phasemation 這個牌子台灣有人代理嗎?
    看stereosound多年, 常看到phasetech P1G/P3G 的身影, 但國內好像很少人使用...
  5. #534
    引用 作者: Kent Lee 查看文章
    我推薦這個, 有3吋厚
    現在比較擔心的是,如果寄來了要怎麼跟家人解釋這是“音響用”的,不是新的菜板(sweat)
  6. The Following User Says Thank You to kevintran For This Useful Post:
  7. #535
    好像沒有耶~~~~~~~~~~`
    引用 作者: kriss 查看文章
  8. #536
    我也考慮過這個, 後來覺得 John Boos 是個老牌子, 選料製作都解釋得很清楚, 2.25 吋 應該是夠了.
    我推薦這個, 有3吋厚
  9. #537
    兩用吧!
    切過有機食材的板子聲音可能更好
  10. #538
    Wave Kinetics NVS Direct-Drive Turntable and Isolation Stand with Durand Telos 12" Tonearm
    Prices
    NVS including Isolation Stand $45000
    Telos $14500
    The design incorporates a relatively compact footprint, though its weight is still quite substantial. The NVS is a computer-controlled direct-drive turntable, with a touch screen to control speeds (33.3 and 45 RPM) and start/stop, with a screw down clamp, and a thick multi-strata platter.
    It's three adjustable pods support the mass of the unit, which in turn rests upon a remarkable Wave Kinetics isolation platform that is included with the turntable.
    Due to the precision of the computer control module for the direct-drive motor, the turntable is extraordinarily linear in its speed control, and thus its pitch accuracy. Operation is completely silent.
    The Durand Telos 12" tonearm is designed and executed by Joel Durand, it is a thing of beauty, a real work of art. Constructed of wood and custom machined brass and stainless steel and other cool stuff, the Telos takes to the NVS and synergizes as if they were born twins. And when you put the superb Ortofon A90 MC into the mix…well, the results are spectacular.
  11. #539
    好像很少真的看過家用的用這麼厚的菜板, 我家都是只要有奇怪東西出現, 都會自動被假設成是"音響用":^)
  12. #540
    預設 窮人的 Finite Elemente
    楓木砧板寄來了, 大小剛剛好
    LP 12 也是楓木座, 蠻合的
    唱頭換成 Linn 原廠未改的 Troika (0.15mv), Jeff Rowland Candence 阻抗調成 50 ohm, 74db gain
    砧板跟 Target 之間暫時用 Audioquest Sorbothane 墊著.
    窮人的 Finite Elemente
