奧地利Pro-Ject發表新的LP唱盤組合Xpression III(訂價英鎊 325),為入門款Debut系列的更高一級。其搭配的唱臂為Pro-Ject 8.6c tonearm、MM唱頭為Ortofon 2M Red。轉速有33rpm、45rpm與78rpm(選購)。
特點
• Tonearm bearing comprises inverted hardened stainless-steel points and sapphire thrust-pads
• Conical carbon fibre armtube allows adjustment of needle azimuth despite fixed headshell
• Vertical tracing angle adjustable
• Acrylic platter
• Low-tolerance chrome-plated stainless-steel axle runs on a polished ball bearing in a brass bearing housing
• Motor decoupled to reduce vibration
• Rubber-damped aluminium cones
原廠網站
www.project-audio.com
