第120頁,共166頁 第一第一 ... 2070110118119120121122130 ... 最後最後
顯示結果從 1,191 到 1,200 共計 1660 條
  1. #1191
    有加DSP的喇叭---還有
    1:Steinway
    2:NHT (在被賣掉之前)
    如果超低音也算的話,那就更多了。
  2. The Following 2 Users Say Thank You to kevintran For This Useful Post:
  3. #1192
    引用 作者: Eton 查看文章
    我知的有法國 Cabasse 還有 英國 Maridian,
    Cabasse 有附麥克風具備頻域與時域空間校正等化功能:
    1. Cabasse La Sphère
    2. Cabasse L’Océan
    3. Maridian DSP8000
    4. Maridian DSP7200
    這些喇叭可能很難被認同為主流或 hiend,(至少在台灣)
    是主動式,看起來也是外加 DSP,我看不出有何出人意表的設計.
  4. The Following User Says Thank You to hojuiyang111 For This Useful Post:
  5. #1193
    Cabasse La Sphère powered loudspeaker Specifications
    使用class-D放大, outboard active crossover with DSP processor
    Power handling: 30W (tweeter), 80W (midrange), 170W (low-midrange), 1kW (woofer). Fully balanced, class-D ICE monoblock power amplifiers: four 300W (tweeters, midranges), four 1kW (low-midranges, woofers).
  6. The Following 2 Users Say Thank You to hojuiyang111 For This Useful Post:
  7. #1194
    steinway speaker
    有趣的設計
    RoomPerfect™ is the most advanced room adaptation technology available. Offering a delightful alternative to the traditional route of adapting the room to the sound system with expensive acoustic room treatment, Steinway Lyngdorf adapts the sound system to the room.
    RoomPerfect™ gives perfect sound at the so-called Focus and Global positions. The Focus filter improves the sound quality at a single listening position, or master seat, thus making Focus the best solution for optimal sound quality when you are listening on your own. Global optimizes the sound for the room as a whole. This is ideal for larger groups of listeners, e.g. when entertaining dinner guests, or while listening in a home theater context.
  8. The Following 2 Users Say Thank You to hojuiyang111 For This Useful Post:
  9. #1195
    何大:Life style high-end 可也,從官網看,廠方也是這麼定位的。“愛玩“ 的燒友連主動喇叭的接受度都不高哩,更惶論把 DAC / 前級統統包進去,原因無他,就是沒有什麼混搭的機會了,不夠好玩!不喜歡老公太沈迷的聰明老婆們會投這一票的,簡單,絕對會開機,聽音樂就好了....
  10. The Following User Says Thank You to Eton For This Useful Post:
  11. #1196
    預設 Computer Audio 準備進入 DSD 規格播放世界
    各主要 Mac OS X 播放軟體大致準備好了 (右到左):
    1. Amarra
    2. Pure Music
    3. Audirvana Plus
    4. JRiver
    5. AuioGate
    在 Channel Classics 買下第一張唱片,網路下載 DSD 2.8MHz 檔案,馬勒第一,2012 很新的 DSD 錄音,2013 Grammy Award 提名...
    用 AudioGate 試播,dCS Scarlatti Upsampler USB port 現在只接受 PCM 24/96,AudioGate 自動把 DSD 2.8M 轉成 PCM 24/96,已經很好聽了,期待 dCS 行行好,趕快推出 Scarlatti 系列 DSD over PCM 升級吧,Vivaldi 您太高了!
    此篇文章於 2013-04-17 01:21 AM 被 Eton 編輯。
  12. The Following 7 Users Say Thank You to Eton For This Useful Post:
  13. #1197
    引用 作者: Eton 查看文章
    除此之外,震動處理也是問題,以後什麼都沒得換,也沒有升級空間.
    聰明老婆一定很高興...
  14. The Following User Says Thank You to hojuiyang111 For This Useful Post:
  15. #1198
    好讚的比試....................
  16. The Following User Says Thank You to john925 For This Useful Post:
  17. #1199
    引用 作者: Eton 查看文章
    與大家分享 OmniMic V2 量測出來的頻率響應 (黑線: 改變前, 紅色:改變後) 對應 上回的幾個調音動作的聽感, 還滿接近的!
    1. Power Amp 使用的 NBS Monitor 0 Power Cord 換成 Siltech Ruby Hill Power Cord - 低頻瘦身塑型, 增加高頻量感
    2. Siltech Ruby Hill Power Cord 的 Wattgate 頭換成 Furutech MI-50 碳纖接頭 - 隔離電磁波干擾, 加黑背景顏色, 增加極高頻細節
    3. 轉盤下黑檀木角椎換成 Goldmuld 鐵質 (中心灌類似矽膠物質) -
    縮短暫態時間, 高整體明亮度, 甚至是音樂的音高 Pitch!
    附件 21338
    從這圖表是無法判斷暫態時間的縮短.
  18. #1200
    找台有DSD解碼的比較好玩啦~~~~~~~~
