第32頁,共166頁 第一第一 ... 2230313233344282132 ... 最後最後
顯示結果從 311 到 320 共計 1660 條
  1. #311
  2. #312
    Pure Music 1.24畫面擷取:
    1.下載15天試用版頁面
    2.下載完成後留在桌面的軟體與說明文件檔
  3. #313
    3.啓動中的Pure Music(用1.23版代替,1.24也一樣),可看到iTunes正在喚起中
    4.播放中的Pure Music與iTunes,可看到Pure Music“含“著iTunes“跑“,綠色小字-Native Sample Rate (96 KHz)Playing from Memory(紅色框框處)
  4. #314
    5.漂亮的iTunes全螢幕顯示
    6.ARC plug-in在Pure Music中的設定畫面,特別留意CPU Load竟然相當高,至少超過80%!
  5. #315
    7.Pure Music可設定Sample Rate,In and Out都在96KHz,因為Apple Core Audio最高到96KHz,dCS Scarlatti D/D upsampler也是96KHz,現階段燒友們不需太迷信192KHz或更高,畢竟要考慮,192KHz訊源的:
    取得來源,下載速度,儲存空間,傳輸線頻寬,處理器能力都要End-to-end完整成熟!
    比賽結果:
    Neutrino 勝之不武!
    Pure Music在一週內連出了兩個版本1.23(3月29日),1.24 (4月4日),必然事出有因!
    在Mac Mini上播放時每隔幾秒鐘就會出“Click“小雜音1.23如此,1.24也沒有排除,合理的猜測是Pure Music + iTunes + ARC Plug-in讓CPU太忙了(見Pure Music圖 6),但是,關掉ARC Plug-in後只有Pure Music + iTunes,CPU Loading立即下降到0-5%,“Click“小雜音未見改善,看來此軟體的成熟度是有待改進的?
    還有它挺貴的(US$129)。但是我還是很喜歡iTunes的使用者界面的友善度,勝出Neutrino一截,問題就在iTunes不能加掛Plug-in,期待Pure Music成熟度進步,或是有一天Apple大發慈悲,讓iTunes可以加掛Plug-in又能Memory Play?!那... Pure Music只好Sayonara囉。
  6. #316
    註:請看Pure Music說明文件最後一頁的最後一段話,大意是:
    請耐心享用,不要有過度期待,放輕鬆...才會有最好的結果...聽音樂如此,人生也應如此吧...Enjoy!
    Note about Pure Music and iTunes:
    When using Pure Music, keep in mind that the user interfaces of two applications (both Pure Music and iTunes) are being controlled at once; not just one. iTunes is used to select the music, and Pure Music plays it. Consequently, there is (as expected) a small but sometimes noticeable lag between control inputs, such as initiating play, fast forward, skip back, etc. in iTunes, and when Pure Music responds to the commands. Think of waiting a heartbeat or so.In addition, Memory Play mode (a feature not available in iTunes) imposes a delay of several seconds (depending on the number of tracks) after pressing Play, while music track(s) are being loaded. The interface will be unresponsive during this track loading process. Again, this is to be expected.
    When using the Server feature, envision how you would use a standalone, hardware based CD player (especially one having a memory play feature, which has the same side effect of delaying playback while the CD is loaded into memory). Press Play, relax, and experience the superb, crystalline, highest possible quality playback available for your music...
    …Enjoy!
  7. #317
    先要感謝micheal和小葉以及ETON兄等的熱心和發燒精神,我一直都很關注Pure music的軟件,自己也在試用,希望綜合各位的意見共同提高,pure music的記憶體播放聲音的確要比硬盤直播要好,聲音更細膩順滑。
    但是使用過程中未發現有“Click“現象,我觀察到圖片中pure music的內存占用情況比較大不知道是否有關系。但是的確也存在一些小問題。
    在見到上文時候無意發現pure music已經出1.25版本,看來這個軟件完善起來還需要一定時日。
  8. #318
    不曉得Eton兄有沒有考慮過用iPad當作操控器?:P
  9. #319
    用iPad讚啦...iPad面板用的也不錯
  10. #320
    引用 作者: gamers1978 查看文章
    引用 作者: DeadHeart 查看文章
    去年就已經想了!
    請看下面連結
    2009.12.24 Eizo
    現在!請看來自Eton的最新報導
