第2頁,共29頁 第一第一 123412 ... 最後最後
顯示結果從 11 到 20 共計 284 條
    引用 作者: hayabusa 查看文章
    曾經用過K1前級3年
    記得只有RCA輸出是反向
    平衡輸出無此問題...:)
    對,K1說明書上的原文是這樣的:
    The Ayre K- 1x offers two pairs of balanced outputs and one pair of unbalanced outputs.
    Please note that the unbalanced outputs invert absolute polarity.
    When using an unbalanced connection between the Ayre K- 1x and your power amplifier, it is suggested that the speaker cables’“ plus” and“ minus” leads be reversed at the amplifier. This will restore absolute polarity and can enhance the sense of realism on many recordings.
    即和一般後級用RCA相連時是反相的,改正方法是把後級喇叭輸出端‘+’、‘—’接反就可以。不過我記得如果用的是AYRE的後級,就無需這麼操作了。
  2. #12
    引用 作者: anfield 查看文章
    對,K1說明書上的原文是這樣的:
    沒錯 沒錯, 就是這樣
    真高興anfield兄開了這個版, K1-xe + V5-xe 用家加入
  3. #13
    Can we ready do as suggested?
    1. For RCA the ground may also be used to earth the component as if we reverse + and - the amp casing is not grounded anymore.
    2. The ground is suppose to shield the signal so when it is reversed the shielding effect of RCA cable is not there anymore
    3. If the RCA cable is directional (as in my hi-end interconnect) than reverse + and - means the current now travel in the wrong direction. Need to reverse the RCA cable direction too?
    4. Same as (3) for speaker cable too.
    5. What happen to the circuit inside the amp and the cross-over circuit in the speaker? The polarity is reversed... will it affect the sound?
    Maybe things can get more complicated than it appear to be...
    引用 作者: anfield 查看文章
    對,K1說明書上的原文是這樣的:
  4. #14
    sorry, Mr.Bean, I cant explain the circut theoretically. but i did reverse + and - at the amp. the system went well.
  5. #15
    引用 作者: paneraiben 查看文章
    只有一台V-5X後及不知可不可以加入這裡
    欢迎!
    引用 作者: Musica 查看文章
    小弟有個建議,各位AYRE同好可否把現役的AYRE器材以及所推的箱子羅列出來,以供大家討論參考。小弟先開個頭:P:
    anfield: Ayre D1 + Ayre K1 (phono) + Ayre V5XE * 2 ---Tannoy turnberry.
    PCAyre L5xe.
  6. #16
    ec337280 目前離線 新手上路請多包涵���ž
    k-5xe + v-5xe 用家...大家好。(bow)
  7. #17
    我記得EC兄用的是K1XE
  8. #18
    我有CX-7e CD Player和K-5xe前級
    對,就是今年有MP升級版的那兩台|(|-
  9. #19
    TWAYRE用家真的不少,請MORI兄列出所用的音箱以及配的後級,也就是說,如果只用了AYRE前級或者後級,同時煩請列出另一部分。
  10. #20
    引用 作者: 小佐 查看文章
    這個我沒研究~~我只會用機器站在喇吧前面量測:P:*
    這個小弟代表AYRE用家澄清一下:
    AYRE的平衡設計和普通美國器材一樣,均是1地、2正、3負,它的單端為何設計成反相就不清楚了。 :*
