2010-12-21, 11:49 PM
#1381
底盤的散熱,另也可看出前面板厚7mm
初聽相當驚豔,高解析下帶有真空管的韻味
2010-12-21, 11:54 PM
#1382
2010-12-22, 12:16 AM
#1383
讚! 有代理嗎????? 好久沒看到真空管的DAC了.......
2010-12-22, 12:19 AM
#1384
You will like this one very much...
If you are ready, you could take this to home and have a try!
2010-12-22, 12:49 AM
#1385
will be ready on 28 dec......I must try.....@@
2010-12-22, 08:49 AM
#1386
2010-12-22, 09:06 AM
#1387
2010-12-22, 10:05 AM
#1388
Lampizator一定讚的,設計者觀念非常正確,也聽過很多好東西。
不過還好他住東歐...如果住在美國大概早就被黑道幹掉,他實在爆太多Hi-End音響的料了。8)
劉名振
2010-12-22, 02:19 PM
#1389
感謝martin的說明
看了LAMPIZATOR的介紹,這產品不好聲是很難的
慢慢的替大家介紹
這個Poland手工打造的DAC是什麼樣的一個精神
設計者LUKASZ fikus可說是要求完美者
High End - Hand Made in Poland
This is not merely an electronic product. It is not another high end DAC built like “a chinese PCB plus two tubes and a box”. This is in my opinion a masterpiece, my lifetime achievement. Beginning from Generation 2 announced in late june 2010 - I am prepared to challenge all the word’s best dacs including the top brands - Goldmund, dCS, Audio-Note, Wadia, Jadis, Esoteric, etc.
設計者LUKASZ fikus傾力之作,100%波蘭手工製作,用來挑戰世界一流品牌
2010-12-22, 02:53 PM
#1390
LUKASZ fikus用了他所有的時間、才能、經驗與熱情,使用最好的技術、元件,每月只能生產10部
What I offer you is my time and talent and my experience and passion to build for you the BEST dac today known to me, using the best practices, parts and components. I am able to build 10 DACs per month so this is a slow process.
LUKASZ fikus花了6年(天天試驗),在相同的lampizator線路上測試了市面上超過100種的晶片,最後挑選出5種晶片在4種接收晶片上進行測試,最後選出來的還在不同的操作模式、時鐘頻率、取樣率、超頻、升頻與其他選項下測試。由於數位的部門極端的敏感,這花了很長的時間。
I have arrived at the Lampizator 2nd generation Dac though an incredibly lengthy process. It took me 6 years everyday testing different DAC chips - over 100 DAC chips tested with the same lampizator circuit to hold the analog part as constant, practically all available chips have been tested. I have narrowed down the choice of DAC chips to just 5 and then I used 4 different types of digital receiver chips and tested them with DACS in all kinds of permutations. In the end, the selected “couple” was subjected to tests of various operating modes, clock frequencies, sampling rates, oversampling, upsampling, and other options.
This stage was the longest and the hardest because the circuit of the digital part is extremely sensitive to even smallest variations, and the re are countless traps and problems.
Putting all my reputation on the table, I do believe that this is a very musical, very transparent and analog like DAC. I sell it only against the world’s strongest competitors and so far I successfully beat most of them. The advantage I have with my It is already in another class compared even to lampized Sabre Buffalo, Behringer, Satch or Lampucera.
That DAC is so good, I decided to step down from my CEO function in the Polish branch of the multicorporation and embrace my dac full time - 24/7 (it is in fact a 19/7 job)
