Denon發表了DCD-755SE唱盤、PMA-390SE綜擴,訂價均為日幣45,150,預計6月上市。
DCD-755SE
AL24 Processing => 16bit to 24bit
192kHz/24bit of the built-in DAC
power transformer with separate analog and digital system
front panel is equipped with a USB terminal (WMA/MP3)
master clock CD playback in 0.1% increments up to ± 12% adjustable
Frequency Response: 2Hz ~ 20kHz
SN ratio: 110dB
Dynamic range: 100dB
Total Harmonic Distortion: 0.0025% (1kHz)
Power: 9W
Dimensions: 434W × 107H × 279Dmm
Weight: 4.2kg
PMA-390SE
Output (both channels driven): 50W +50 W (8Ω, 20Hz ~ 20kHz, THD0.09%)
Practical Maximum Output: 100W +100 W (4Ω, JEITA)
Total Harmonic Distortion: 0.01% (1kHz, 8Ω)
Output terminals: Speaker A or B 4 ~ 16Ω, Speaker A + B 8 ~ 16Ω
Input Sensitivity / Impedance: LINE 105mV/47kΩ , PHONO 2.5mV/47kΩ
Frequency Response: 5Hz ~ 100kHz +0, -3dB
SN ratio (A network): LIN 107dB PHONO 86dB
Power: 150W
Dimensions: 434W × 121H × 307Dmm
Weight: 6.7kg
http://denon.jp
