第12頁,共17頁 第一第一 ... 21011121314 ... 最後最後
顯示結果從 111 到 120 共計 164 條
  1. #111
    HRS Damping Plate
    The HRS Damping Plate MKII is the latest in damping plate technology. It significantly reduces the negative impact of air-borne vibration on your audio or video component. The HRS Damping Plate should be placed directly on top of an electronic component chassis with the soft side (a custom formulated elastomer) of the damping plate in contact with the chassis surface. The greater the surface area covered by the damping plates the greater the improvement in audio/video performance.
    All visible surfaces are made from a precision machined billet aircraft aluminum with a black anodize finish.
    HRS Damping Plate Physical Characteristics (Standard Sizes)
    DPII-05545
    Dimensions(LxWxH): 5.5" x 4.5" x 0.7" [14.0 x 11.4 x 1.8cm]
    Weight: 1.1lb (0.5kg)
    DPII-09545
    Dimensions(LxWxH): 9.5" x 4.5" x 0.7" [24.1 x 11.4 x 1.8cm]
    Weight: 2.0lb (0.9kg)
    DPII-14545
    Dimensions(LxWxH): 14.5" x 4.5" x 0.7" [36.8 x 11.4 x 1.8cm]
    Weight: 3.1lb (1.4kg)
  2. #112
    我自己有用Damping Plate最大塊的 柏琦買的 售價應該就是美金售價吧.....
    :o:o:o
    HRS Damping Plate
    Dimensions: 4.5" x 5.5" US$120
    Dimensions: 4.5" x 9.5" US$175
    Dimensions: 4.5" x 14.5" US$220
  3. #113
  4. #114
    引用 作者: raywan 查看文章
    :o:o:o
    HRS Damping Plate
    柏琦價格很實在:):):)
  5. #115
  6. #116
    預設 魔豆網.
  7. #117
    預設 魔鐘.
    真實體型很小8).
  8. #118
    預設 同一家.
    調音板..約比A4長一點.
  9. #119
    實為雙層.表有細孔.
  10. #120
    調音腳墊~橡膠部份.
