第11頁,共17頁 第一第一 ... 910111213 ... 最後最後
顯示結果從 101 到 110 共計 164 條
  1. #101
  2. #102
  3. #103
  4. The Following User Says Thank You to raywan For This Useful Post:
  5. #104
    Harmonic Resolution Systems - Damping Plate
    HRS DPII-05545
    :P:P:P
  6. The Following User Says Thank You to raywan For This Useful Post:
  7. #105
  8. The Following User Says Thank You to raywan For This Useful Post:
  9. #106
    所有調音補品
    均是用於吸走内在或外來震動
    效能有多少?
    及音質有沒有改變?
    會視乎與器材是否匹配
    改變了的音質是否合意,則因人而異
    故最好找朋友借入在自己的系統上測試
    有自己喜歡的效果,才作使用
    :o:o:o
  10. The Following 2 Users Say Thank You to raywan For This Useful Post:
  11. #107
    The main goal of these sound tuning products is to eliminate the loss of information caused by reading errors and the information loss caused by noise being introduced back into the signal path during amplification and transmission of the signal from the source to the speakers.
    By maximizing the retrieval of information and preserving the transmission of the signal, you end up with a much more realistic and believable musical presentation that has the ability to trick the human senses into believing that you are listening to and experiencing an actual musical event and not a reproduction of that event.
    :P:P:P
    Once you have a decent high-resolution audio system, vibration and mechanical noise causes a significant audible degradation of the signal. The fact that the vibration is the root cause of this degradation and is one of the primary limitations to their system performance is not always obvious to people as they swap out one high-quality component for another. The loss of information and added artifacts caused by vibration and noise can remove the essence of what makes a high-end audio system a special experience for the listener.
  12. #108
    HRS的墊材確實很不錯,小弟自用了NS-080,聲音線條型體感越發明確,尤其是高頻解析力,但是又能讓"衝"的成分降低
    想請教raywan兄的那塊小墊板是哪邊入手的,還有售價為何,謝謝您!
  13. #109
    引用 作者: ahniou 查看文章
    :O:O:O
    HRS Damping Plate 確實有效,我仍在使用中
    我的 HRS 已買入很久,現在記不起當年的售價
    (sweat)(sweat)(sweat)
    你可向以下代理商,查問最新售價
    Tech Union Incorporated
    No 371, Sec 2
    Cheng-Gong RD
    Neihu District
    Taipei City 114
    Taiwan
    Tel: (02) 2791 5009
  14. #110
    引用 作者: ahniou 查看文章
    我自己有用Damping Plate最大塊的 柏琦買的 售價應該就是美金售價吧.....
