第29頁,共45頁 第一第一 ... 19272829303139 ... 最後最後
顯示結果從 281 到 290 共計 441 條
  1. #281
    關於那一台作為遙控的電腦,具備 AST2400 的主機板該是比較方便和便宜:
    https://www.supermicro.com/en/soluti.../bmc-resources
    2D/VGA-compatible graphics
    https://www.supermicro.com/manuals/o...ide.pdf#page=8
    The AST2400 provides a 2.5GHz PCI-Express interface. The AST2500 supports PCI-Express 2.0, which is compliant with PCI-Express Base Spec. Revision 2.0. The PCI-E bus controller connects to the VGA Controller that allows for direct communication with the 2D Graphics Engine, SPI Host Controller, and P2A Bridge.
    https://www.gigabyte.com/Enterprise/...D90-FS0-rev-11
    Integrated in Aspeed® AST2400
    2D Video Graphic Adapter with PCIe bus interface
    Intel C220 系列晶片組的 TDP 只有 4.1W:
    https://en.wikipedia.org/wiki/LGA_1150
    https://ark.intel.com/content/www/us...-chipsets.html
    基本上就是這些 Supermicro 的主機板比較好買:
    https://www.supermicro.com/en/produc...board/X10SL7-F
    https://www.supermicro.com/en/produc...board/X10SLH-F
    https://www.supermicro.com/en/produc...board/X10SLL-F
    https://www.supermicro.com/en/produc...oard/X10SLL+-F
    https://www.supermicro.com/en/produc...oard/X10SLL-SF
    https://www.supermicro.com/en/produc...board/X10SLM-F
    https://www.supermicro.com/en/produc...d/X10SLM+-LN4F
    https://www.supermicro.com/en/produc...board/X10SLX-F
    價格方面則不會超過 ¥400 的說:
    https://www.taobao.com/list/item/643875080238.htm
    https://www.taobao.com/list/item/662604827475.htm
    https://www.taobao.com/list/item/688374046315.htm
    https://www.taobao.com/list/item/697106134233.htm
    https://www.taobao.com/list/item/705496808711.htm
    https://www.taobao.com/list/item/709577122240.htm
    https://www.taobao.com/list/item/710914864112.htm
    https://www.taobao.com/list/item/715523947305.htm
    https://www.taobao.com/list/item/718645457797.htm
    然後看看所有 Xeon 處理器,TDP 最低的型號只有 13W:
    https://en.wikipedia.org/wiki/List_o...eon_processors
    就是這一顆沒有內建 GPU 的 E3-1220L v3,正好適合 C220 系列的晶片組,而且 Haswell 也是 Intel 史上第一代支援 AVX2 指令集的處理器,因此絕對可以跑那些 x86_64‑v3 的軟件:
    https://ark.intel.com/content/www/us...-1-10-ghz.html
    https://www.techpowerup.com/cpu-spec...1220l-v3.c1642
    With a TDP of 13 W, the Xeon E3-1220L v3 consumes very little energy. Intel's processor supports DDR3 memory with a dual-channel interface. The highest officially supported memory speed is 1600 MHz, but with overclocking (and the right memory modules) you can go even higher. ECC memory is supported, too, which is an important capability for mission-critical systems, to avoid data corruption. For communication with other components in the system, Xeon E3-1220L v3 uses a PCI-Express Gen 3 connection. This processor lacks integrated graphics, you might need a graphics card.
    價格方面也是超級便宜,但是選購的時候千萬不要買那個 80W 的型號:
    https://www.techpowerup.com/cpu-spec...-1220-v3.c1545
    With a TDP of 80 W, the Xeon E3-1220 v3 consumes a good deal of power, so decent cooling is needed.
  2. #282
    引用 作者: sam0402 查看文章
    請問Dequad兄,您的 '伽利略 Type C - SATA 外接硬碟轉接頭' 能不能抓到光碟機?
    小弟買的 'Delock(64188) Type C - SATA 外接硬碟轉接頭' 是抓不到的Pioneer BDR-S12J-BK,也會挑硬碟,非常不建議購買。
    失算!沒想到Delock 有兩款Type C-SATA 轉接頭,小弟買的64188ASM235CM晶片的。
    昨天發現竟然有另一款,Delock 64104,是
    VL716晶片,它對硬碟支援度應該比較好。
    至於光碟機的部份就有點尷尬了,
    VL716晶片有支援CDROM, DVDROM...,但Delock官方網站沒有提到。
    若有樂友有興趣買來接硬碟,就不妨測試一下光碟機吧!
  3. The Following User Says Thank You to sam0402 For This Useful Post:
  4. #283
    請問Sam兄與前輩們,有沒有可能做到兩個USB外接SSD,想聽哪一顆SSD就使用哪一顆。
    我在mpd裡編輯了以下兩種:
    =========1==========
    music_directory "/mnt/music"
    music_directory "/mnt/music2"
    =========2=========
    music_directory "/mnt/music;/mnt/music2"
    都沒有辦法正常開機,或者開機了以後抓不到其中一顆SSD
    不曉得小弟編輯的方式是不是有錯誤?
  5. #284
    引用 作者: pawaslider 查看文章
    我在mpd裡編輯了以下兩種:
    =========2=========
    不曉得小弟編輯的方式是不是有錯誤?
    @pawaslider 兄,
    mpd 只能用一個 music_directory
    有個方法,是使用 config -> mpd -> 修改 music_directory 的路徑,選擇你要聽的 SSD
    然後執行 mpc update 更新資料庫,這樣在 client 端可即時看到改變。
  6. #285
    引用 作者: silaslin 查看文章
    @pawaslider 兄,
    這個方法應該沒問題,不過如果有多個外接SSD,放了不同的音樂檔案就很麻煩了
  7. #286
    我在mpd裡編輯了以下兩種:
    =========2=========
    不曉得小弟編輯的方式是不是有錯誤?
    pawaslider兄您好
    或許您把mpd的music_directory設為/mnt就可以同時抓到/mnt/music和/mnt/music2的音樂檔案了。
  8. The Following User Says Thank You to tetsuka For This Useful Post:
  9. #287
    dmz 兄提議利用 symlinks,然後 firekage 兄說成功了:
    https://bbs.archlinux.org/viewtopic.php?id=217099
    代碼:
    mkdir ~/music
    cd !$
    ln -s /mnt/vc/vc_1/Music music1
    ln -s /mnt/vc/vc_2/Music music2
    mpd.conf:
    代碼:
    music_directory = "~/music"
    follow_outside_symlinks = "yes"
    ln(1) — Arch manual pages
    https://man.archlinux.org/man/ln.1.en
    symlink(7) — Arch manual pages
    https://man.archlinux.org/man/symlink.7.en
    ln — 建立連結指令
    https://www.ltsplus.com/linux/ln-create-link-command
    Linux 建立連結檔 ln 指令教學與範例
    https://blog.gtwang.org/linux/linux-...rial-examples/
    [Linux] 使用 ln 建立軟連結、硬連結檔案
    https://clay-atlas.com/blog/2020/04/...symbolic-link/
    相關討論如下:
    https://github.com/MusicPlayerDaemon/MPD/issues/1535
    https://ubuntuforums.org/showthread....2105007&page=2
  10. #288
    我在mpd裡編輯了以下兩種:
    =========2=========
    不曉得小弟編輯的方式是不是有錯誤?
    小弟先確認一下Pawaslider兄的使用方式:
    1. 兩個USB Storage 同時都接上ArchQ來聽。
    2. 兩個USB Storage 是想聽時,才接上其中一顆來聽。
    以上兩者操作不同,先給小弟你的方式,我再想想要如何解決。
  11. #289
    引用 作者: sam0402 查看文章
    Sam兄您好
    小弟想使用的是第二種方式,第一種方式tetsuka兄提供的方式已經可以克服,不過這種方式必須兩個SSD同時接上才能開機。
    seeteeyou兄提供的方案目前則還沒參透
  12. #290
    Pawaslider兄可以試試下面的方法,前題是兩顆SSD的音樂資料的Partition都是同一個:
    1. 先用lsblk 看一下
    代碼:
    $ lsblk
    NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINTS
    sda           8:16   0  1.4T  0 disk
    ├─sda1        8:17   0  1.3T  0 part /mnt/music
    └─sda2        8:18   0   32G  0 part
    小弟的HDD /dev/sda1,最後的1 是代表第一個partiton 是音樂檔用的。M.2 的SSD 應該是/dev/nvme0n1p1
    若移除第一顆,改放第二顆,結果也是相同,就可採用下一步驟。
    2. 複製(cp)mpd的資料庫到兩顆硬碟,下面指令兩顆都用做一次,並確認有存在(ls)。
    代碼:
    cp -a /var/lib/mpd /mnt/music/.
    ls /mnt/music/mpd
    3. 移除原來mpd的資料庫(rm),建立SSD裡複製好的mpd的資料庫的捷徑(ln):
    代碼:
    rm -rf /var/lib/mpd
    ln -s /mnt/music/mdp /var/lib/.
    4. 修改檔案系統的掛載表
    代碼:
    $vi /etc/fstab
    UUID=ceb76e95-6bac-4e2c-87d1-e6ce77cc35fb /mnt/music xfs ro,noatime 0 0
    第一欄UUID=... 改為 /dev/sda1
    代碼:
    /dev/sda1 /mnt/music xfs ro,noatime 0 0
    請確認無誤,不然會開不了機,就要用安全模式修改(官方Kernel 開機)。
    上面的方式是把mpd 資料庫也分別存放在SSD裡,這樣看到的專輯就會跟著SSD而不同。
  13. The Following User Says Thank You to sam0402 For This Useful Post:
