第32頁,共41頁 第一第一 ... 223031323334 ... 最後最後
顯示結果從 311 到 320 共計 401 條
  1. #311
    原來 Supermicro 的個別主機板和 Dell 的一些舊款伺服器還有這種好康:
    https://www.supermicro.com/wdl/drive...n/G200e/Linux/
    https://linux-hardware.org/?device_v...=graphics+card
    美中不足就是只能夠支援 4:3 或者 5:4 的解像度:
    http://www1.la.dell.com/content/prod...stab&~wsf=tabs
    https://www.dell.com/community/Power...673623/#M25733
    Matrox G200eW w/ 8MB memory integrated in Nuvoton WPCM450 (BMC controller) and supports 2D graphics only.
    https://www.supermicro.com/support/f....cfm?faq=14787
    The X9SCM-F motherboard design as server form factor support and had embedded Nuvoton WPCM450RA0BX with 16mb video display through IPMI BMC chipset and the max resolution at 1280x1024 32bit.
    https://www.supermicro.com/support/f....cfm?faq=17055
    No. The Matrox G200 is a 2D card. You need a 3D graphics cards to support openGL.
    另外那些型號比較舊的主機板就不一定支援 NVMe 開機了,因此需要借助這些方案:
    [HowTo] Get full NVMe Support for all Systems with an AMI UEFI BIOS
    https://winraid.level1techs.com/t/ho...efi-bios/30901
    [Guide] NVMe-boot without modding your UEFI/BIOS (Clover-EFI bootloader method)
    https://winraid.level1techs.com/t/gu...r-method/31665
    [Guide] NVMe-boot for systems with legacy BIOS and UEFI board (DUET-REFIND)
    https://winraid.level1techs.com/t/gu...t-refind/32251
    當然還有這個選擇,然後試試 Delock 的線材:
    曾被延遲的 ASMedia USB 4.0系列主控方案即將面世
    https://www.cnbeta.com.tw/articles/tech/1362881.htm
    ZikeDrive USB4 40Gbps SSD Drive Enclosure Z666
    https://ziketech.com/products/zikedr...usb4-ssd-drive
    至於型號比較新的伺服器則具備這個 G200eW3,只是價格方面比較可觀罷了:
    https://github.com/torvalds/linux/bl...g200_g200ew3.c
    https://archive.today/https://ubuntu...d/202208-30520
    The video card in this device is meant for basic 2D displays, 3D/accelerating features are not supported.
    https://ganzsecurity.com/product/1591/DT-1X-xTB
    Matrox G200eW3 16MB video adapter with VGA output
  2. The Following User Says Thank You to seeteeyou For This Useful Post:
  3. #312
    USB卡供電改善方案
    目的:隔離來自主機板的3.3v和12v的電。
    注意:若無法採用Tetsuka兄的 NVME和PCIE介面卡的獨立供電方案 (已置頂),才考慮使用。
    免責聲明:可能燒毀USB卡和主機板。有看懂小弟寫的,手中有電表量測,清楚自己在做什麼再動手,請不要依樣畫葫蘆。
    日前被CPU搞,害小弟誤認主機板出問題,USB 3.1的卡(PCIe x4)無法使用,耗了一個半月才搞定,終於用上USB 3.1卡。
    買了一張有獨立供電的卡,
    因為主機板是ITX,加上Case小,無法用Tetsuka兄的方案。才出此下策。
    猶豫了很久,怕樂友搞壞電腦,但因為講到究極,決定還是發佈上來。
    先看圖:
    灰色部份就是要貼掉的腳位,除了 '3.3v aux',小弟的卡貼掉就不能動了。
    因為獨立供電的部份,通常只提供5v和12v,3.3v都不供應,於是小弟就採用SATA供電座的pin腳直拉到3.3v的腳位。
    查看板子電路,可以看出3.3v腳位是到正面一顆電容焊腳點,用電表測量後確定是通路,這樣就找到可焊接的點。
    焊接好線後,先只接上SATA供電線,不上主機板,用電表測量3.3v的腳位是否有電,若是就完成了。
    此篇文章於 2023-06-04 06:47 PM 被 sam0402 編輯。
  4. The Following User Says Thank You to sam0402 For This Useful Post:
  5. #313
    引用 作者: sam0402 查看文章
    小弟是用 iPad(Rigelian) 走WiFi -> Ethernet -> USB(電訊隔離) -> ArchQ MPD 的使用法,這樣應該算是簡捷好用的操作模式。
    sam0402 兄您好,鑒於不少 Intel 主機板已經具備 USB4,加上 Delock 的 40Gbps 線材實在是便宜又大碗,不知道 USB4NET 是否可行呢?
    CONFIG_USB4_NET: Networking over USB4 and Thunderbolt cables
    https://cateee.net/lkddb/web-lkddb/USB4_NET.html
    Linux 6.1 Thunderbolt Networking To Support USB4 End-To-End Flow Control
    https://www.phoronix.com/news/USB4NE...d-Flow-Control
    https://gihyo.jp/article/2022/09/daily-linux-220906
    I can't tell what Linux does but USB4NET works without a hitch through USB4 hubs.
    https://news.ycombinator.com/item?id=32714807
    基本上就是打造最強的 ArchQ 路由器:
    https://wiki.archlinux.org/title/router
    https://github.com/tnewman/arch-router
    https://eldon.me/arch-linux-based-home-router/
    https://bbs.archlinux.org/viewtopic....d=50531#p50531
    https://www.reddit.com/r/archlinux/c..._linux_router/
    USB4NET 不行的話也不打緊,這個 USB Ethernet 加上 Delock 的線材也不錯吧?
    https://post.smzdm.com/p/a9gdq8p5/
    https://item.taobao.com/item.htm?id=644849645096
    https://www.juplink.com/products/2-5...etwork-adapter
    就算不需要 routing 方面的功能,把它當作 network bridge 的話也無傷大雅。
    另外 Delock 還有 M.2 轉 USB-C 的產品,但是只有 10Gbps 的說:
    https://www.ebay.com/itm/294946328062
    https://www.aliexpress.com/item/4001286739867.html
    https://www.delock.com/produkt/63174/merkmale.html
    https://www.delock.com/produkt/63330/merkmale.html
    https://www.sybausa.com/index.php?ro...roduct_id=1061
    https://www.amazon.com/IO-CREST-Expa.../dp/B08J2GXYSD
    當然 Delock 亦有推出 ASM3242 的 20Gbps 產品,不知道效果會不會比其他品牌更好呢?
    https://www.reichelt.com/de/en/pcie-...5-p290223.html
  6. The Following 3 Users Say Thank You to seeteeyou For This Useful Post:
  7. #314
    神級的USB 4 Cable
    再次的大躍進,身為基督徒的我,知道這是上帝的預備好的,沒有巧合,太多次了!
    第一次是香堡寶電源線,加上N次的ArchQ進化,這次是Delock USB 4.0 Cable(80009)。
    三月中,在Higuma兄來訪離開前,把隨意訂、不起眼、沒打算用在音響上、全新的 Delock USB 4.0 0.8m (86979)接上DDC,兩人驚歎的下巴都合不起來。
    這樣又聽了一個小時不想停下...。隔日,小弟速速的訂了一批1.2m版本(80009)。
    聽感直接說結論:資訊完整度近乎100% >>> 任何的線材(小弟非常有把握)。
    五月,小弟想想,USB4或許可用在其他地方,就來個帶有12V和Type-C 的SATA-USB轉接頭。
    上週到貨後接上,賓果! USB4 + 轉接頭 >>> SATA 或任何的線材(小弟非常有把握)。
    這就是Seeteeyou 兄最近一直提到Delock USB4.0的原因了。而小弟也正猜想,用得上的地方都應改採用這條USB4,其一就是網路線。
    近日小弟也正在預備kernel 6.1,自然的會把USB4的網路功能加上,或許雙機之間用上這條USB4也能大幅提升音質。
    另外,這條USB4 台灣也有 Avier Uni G3 1.2m (=Delock 80009)。
    此篇文章於 2023-06-20 11:14 PM 被 sam0402 編輯。
  8. The Following 6 Users Say Thank You to sam0402 For This Useful Post:
  9. #315
    引用 作者: sam0402 查看文章
    神級的USB 4 Cable
    這幾天因為換了伽利略的 Type-C 的SATA-USB轉接頭,還有新的硬碟 hub,也正想測試買了很久的 USB4 和 Thunderbolt 4 線,都是 0.8m 長度的。想先請問 sam 大:
    接 DDC 是否有經過 hub 及 U3TT?
    Type-C 的SATA-USB轉接頭是否有經過 hub?
    不知道是否有比較過 Delock 和其他品牌的 USB4 線?
  10. The Following User Says Thank You to dequad For This Useful Post:
  11. #316
    引用 作者: dequad 查看文章
    沒想到Dequad兄有志一同,同時也買了USB4線材和SATA-USB轉接頭來玩。
    小弟沒在玩U3TT,三月中第一次聽USB4線,是用Benevo USB 3.1的HUB,HUB -> DDC 這段換USB4線來聽的。
    之前是採用了兩條Intel認證 TB4的線,而這次一換上USB4就上癮。
    現在則採用USB 3.1卡和80009接DDC,聲音更直接,動態更好,就是前兩篇的那張卡。
    這張紅色的就是和Delock 一樣的,台灣是Awesome, 美日是StarTec。
    不過小弟另外又訂了USB3.2的,還在路上,不是Delock/Awesome。
    我的目標是3.1的有兩個Type-C,分別接HDD和藍光機;3.2接DDC。
    另外也發現USB4線無需再用 iFi idefender 這類的器材,DDC端有做電訊分離就可。
    經Dequad兄這一問,小弟覺得自己好像說大話了,我只和TB4比過,不過聲音實在差太多了。
    本想賣個關子,看到Dequad兄熱心實測,就直說了:Avier Uni G3 1.2m == Delock 80009,在台灣的有福了。
    歡迎Dequad兄來打臉!
  12. The Following 4 Users Say Thank You to sam0402 For This Useful Post:
  13. #317
    期待 sam 大持續分享測試結果!
    不同的線材或組件放在不同的系統和位置,常會得到截然不同的結果。只要是在當時的系統/組合上實際的狀況,就有一定的參考價值。我自己的系統和喜歡的聲音走向可能跟 sam 大、教授或其他版友有所不同,但這一兩年來還是藉由大家的經驗分享省下好多時間,也讓系統性能進步很多。如果有機會大家一起聆聽實測,收穫一定更多。sam 大下次拜訪或邀請教授時記得揪一下!
    去年取得一片使用 ASM 3242 晶片、也可外接電源的 USB 3.2 卡,插在技嘉 Z690 Master 主機板上怎麼也無法辨識,但在 ASUS Z690 Apex 上則開機後立即可用。當時因為這張卡認不到 U3TT,就省去 U3TT 和 hub、直接以一條線接 DT2。本來想找出一條最理想的 USB type C 接線,買了 USB4 和 Thunderbolt 4 線準備試聽,沒想到 Z690 Apex 一再送修,測試計畫停擺。曾用 TB4 線連接主機板的 USB 3.2 Gen 2x2 座和外接硬碟,感覺聲音變得過分沈重,就沒再進一步測試。
    今天分別用 TB4 線和 USB4 線連接伽利略 type C - SATA 外接硬碟轉接頭和 hub,發現 USB4 線(不是 sam 推薦的 Delock/Avier 版本) 的聲音較單薄、TB4 線則較具實體感。接下來準備回復雙 PC 設定,在直通 CPU 的 PCIe 槽插上 USB 3.2 卡、分別接 DT2 和外接硬碟試試看。
  14. The Following 3 Users Say Thank You to dequad For This Useful Post:
  15. #318
    查了一下 sam 大提到的兩款 Delock USB4 線規格:
    Delock 80009
    USB Power Delivery (USB PD 3.1) support up to 240 watt
    Support for the Extended Power Range resp. USB Power Delivery 3.1 standard means that connected devices can be supplied with power, up to 240 W (48 V / 5 A) is possible.
    • Chipset: Etron E-Marker
    • Cable type: coaxial
    • Cable gauge:
      28 AWG data line
      23 AWG power line
    • Contacts gold-plated
    • Cable diameter: ca. 5.2 mm
    Delock 86979
    USB Power Delivery (USB PD 3.0) support up to 100 watt
    Supports the USB Power Delivery 3.0 standard, which allows connected devices to be powered with up to 100 W (20 V / 5 A).
    • Chipset: Cypress E-Marker
    • Cable gauge:
      30 AWG data line
      24 AWG power line
    • Cable diameter: ca. 4.8 mm
    兩款線的 PD 規格(分別是 3.0 和 3.1)、E-Marker 晶片線芯和線徑粗細都不同。影響最終聲音表現的很可能是線材的其他特性,從規格未必看得出來。不知道版上有沒有誰可以測量 USB 線的客觀性能,例如看一下數位訊號的 eye diagram 之類的,如下圖(圖片擷取自 Anritsu 的 application note)?
    [補記]
    看起來有適當的示波器就可以想辦法測量:
    此篇文章於 2023-06-14 05:49 PM 被 dequad 編輯。
  16. The Following 4 Users Say Thank You to dequad For This Useful Post:
  17. #319
    引用 作者: dequad 查看文章
    恕刪...
    請問Dequad兄,您的 '伽利略 Type C - SATA 外接硬碟轉接頭' 能不能抓到光碟機?
    小弟買的 'Delock(64188) Type C - SATA 外接硬碟轉接頭' 是抓不到的Pioneer BDR-S12J-BK,也會挑硬碟,非常不建議購買。
  18. The Following 3 Users Say Thank You to sam0402 For This Useful Post:
  19. #320
    沒有對比就沒有傷害,那個 eye pattern 的話就有這些測試,只是很久以前的說:
    https://docplayer.net/24290292-Group...bles-6-5k.html
    https://web.archive.org/web/20221127...B%20kabelu.pdf
    https://web.archive.org/web/20221127...elu%202014.pdf
    當時的「狀元」該是醬子的說:
    https://www.absolutesounds.com/pdf/m...n2013_4web.pdf
    https://www.absolutesounds.com/pdf/m...dream_4web.pdf
    https://audiophilestyle.com/forums/t...comment-907126
    The only cable that I have heard in my system that met all my expectations was the Crystal Cable Absolute Dream, but at a price I am not willing to pay. Other than that, the Valhalla V2 does it all, except some the organics that I miss.
    當然現在最好還是等待 80Gbps 版本的 Delock 線材,然後加上 QSA 的量子科技就十分理想了:
    https://www.whatsbestforum.com/threa...-series.36078/
  20. The Following 2 Users Say Thank You to seeteeyou For This Useful Post:
