第5頁,共89頁 第一第一 ... 345671555 ... 最後最後
顯示結果從 41 到 50 共計 881 條
  1. #41
    關於 piCorePlayer 未來的版本,kernel 方面即將由現有的 4.19 更新到 5.4:
    https://forums.slimdevices.com/showt...l=1#post985579
    I can put it on the list to work on, but right now, we are working on migration to kernel 5.4, and full 64bit support on pi3's and 4's.
    piCore-12.0beta1
    http://forum.tinycorelinux.net/index...c,24322.0.html
    http://tinycorelinux.net/12.x/armv7/...12.0-beta1.zip
    http://tinycorelinux.net/12.x/aarch6...12.0-beta1.zip
    Note that the 64-bit extension support is limited as everything has to be built from scratch.
    Core components
    - kernel 5.4.51
    - glibc-2.31
    - busybox-1.31.1
    - gcc-10.1.0
    - util-linux-2.35.2
    - e2fsprogs-1.45.6
    ARM64 版本的 source 在這裡:
    http://tinycorelinux.net/12.x/aarch64/releases/RPi/src/
    當然 piCorePlayer 跟 piCore /piCore64 兩者所走的方向只是相近,且看哪一版本的步伐比較快了。
    BFS/MuQSS 的作者 Con Kolivas 指出 Linux kernel 逐漸醞釀著一些隱憂,不知道那種不斷增加的 kernel 大小會否變成吃力不討好的負擔呢?
    MuQSS/CK's Con Kolivas Becoming Concerned Over The Increasing Size Of The Linux Kernel
    https://www.phoronix.com/scan.php?pa...-Size-Concerns
    https://ck-hack.blogspot.com/2020/08...on-issues.html
    期待 sam0402 兄 patch 的 5.4 BFS/MuQSS 版本,然後就可以測試一下針對 BCM2711 而 compile 的 ARM64 kernel 了。
  2. The Following 3 Users Say Thank You to seeteeyou For This Useful Post:
  3. #42
    除了surround外,其他試過還是不行...
    Output devices:
    null - Discard all samples (playback) or generate zero samples (capture)
    default
    plugequal
    equal
    sysdefault:CARD=DAC - STEREO192-DSD DAC, USB Audio - Default Audio Device
    front:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - Front speakers
    surround21:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - 2.1 Surround output to Front and Subwoofer speakers
    surround40:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - 4.0 Surround output to Front and Rear speakers
    surround41:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - 4.1 Surround output to Front, Rear and Subwoofer speakers
    surround50:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - 5.0 Surround output to Front, Center and Rear speakers
    surround51:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - 5.1 Surround output to Front, Center, Rear and Subwoofer speakers
    surround71:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - 7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
    iec958:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - IEC958 (S/PDIF) Digital Audio Output
    dmix:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - Direct sample mixing device
    dsnoop:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - Direct sample snooping device
    hw:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - Direct hardware device without any conversions
    plughw:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - Hardware device with all software conversions
  4. The Following User Says Thank You to jimmypan For This Useful Post:
  5. #43
    引用 作者: jimmypan 查看文章
    Output devices:
    default
    plugequal
    equal
    jimmypan兄您好
    看來這就是您使用的mytek 192 dsd的USB硬體相容性所造成的限制。
    "hw:CARD=DAC,DEV=0 - STEREO192-DSD DAC, USB Audio - Direct hardware device without any conversions"
    從您提供的資料來看應該就會知道為什麼Output setting的設定,小弟會請大家選擇hw:開頭的音效裝置來輸出的原因。
    因為hw:開頭的音效裝置輸出是直通硬體不經過任何的轉換的。
    建議jimmypan兄您在不更換mytek 192 dsd的前提下,或許可以先去借個USB DDC使用SPDIF輸出到DAC試試看聲音是否會更好。
  6. The Following User Says Thank You to tetsuka For This Useful Post:
  7. #44
    就在我準備放棄的時候,隨手把原本設定PCM Only調為Default,
    居然變成綠色啟動了!!!
    確認只有PCM Only不行,真是手殘...
  8. The Following User Says Thank You to jimmypan For This Useful Post:
  9. #45
    不知不覺快速的聆聽了1個小時,
    初步覺得picoreplayer的方向是我喜歡的
    要再多聽一下,
    感謝各位網兄的強力支援
  10. The Following User Says Thank You to jimmypan For This Useful Post:
  11. #46
    居然變成綠色啟動了!!!
    原來是Squeezelite Binary設定為PCM Only所以才會造成Squeezelite無法啟動嗎。
    切換到PCM Only以外3種Squeezelite Binary就能正常啟動Squeezelite的話,這個代表在Squeezelite的設定頁面中有使用了PCM Only不支援的參數所以PCM only才會Squeezelite啟動失敗。
    如果您是使用小弟提供的piCorePlayer的img檔的話,那麼小弟在Player的安裝設定中已經有特別提醒過這一點了。
    小弟建議對piCorePlayer的設定不熟悉的網兄,Squeezelite Binary請先用預設的Default比較不會出現問題。
    不管怎麼樣小弟恭喜jimmypan兄已經解決Squeezelite無法啟動的問題。
    如果接下來一切都順利的話,請您開始好好的享受piCorePlayer6.1.0-arm64-88-96所帶來的高音質體驗吧。
  12. The Following 2 Users Say Thank You to tetsuka For This Useful Post:
  13. #47
    引用 作者: seeteeyou 查看文章
    看來 Mytek 的 USB 2.0 或許有一點兒成功的機會,但作者只公開 x86 版本的 kernel:
    https://community.roonlabs.com/t/roon-nucleus-to-mytek-stereo192-dsd-dac-over-usb-2-0/54152/27
    Custom Kernel To Install Snakeoil OS
    https://www.snakeoil-os.net/wiki/Adv...stall-snakeoil
    Get Mytec Stereo 192 working in Snakeoil
    https://www.snakeoil-os.net/forums/T...d=1137#pid1137
    Access to source code ?
    https://www.snakeoil-os.net/forums/T...to-source-code
    另外這是樹莓派 4 專用的下載,但是不知道如何取得 ARM64 版本的 kernel/source 等等:
    https://www.patreon.com/posts/snakeoil-os-33602597
    https://drive.google.com/file/d/1r-w...Vy8eg3z4L/view
    seeteeyou兄:
    我完全看不懂...
    USB2.0就不敢強求了,感謝您提供的資訊
  14. The Following User Says Thank You to jimmypan For This Useful Post:
  15. #48
    不知不覺快速的聆聽了1個小時,
    要再多聽一下,
    感謝各位網兄的強力支援
    提醒jimmypan兄記得到LMS設定畫面中piCorePlayer的audio設定畫面將Volume Control改為100%。
    附件 33470
    Volume Control必須設為100%才會是BitPerfect的輸出。
  16. The Following 4 Users Say Thank You to tetsuka For This Useful Post:
  17. #49
    引用 作者: sam0402 查看文章
    jimmypan兄好,
    iOS這套應該可以,評價還蠻高的,但我沒用過。
    https://apps.apple.com/tw/app/ipeng/id767266886
    「iPeng 9, the music remote for the Logitech Squeezebox, has been designed for the latest iOS versions and fully supports all iPhone and iPad form factors.
    iPeng 9 is a remote control app that will work all over your home with your iPhone, iPad, iPod touch and Apple Watch.」
    (1) LogitechMedia Server/Squeezebox Server version 7.5 or newer available for free from mysqueezebox.com/download or downloads.slimdevices.com/nightly/」
    sam 兄:
    我是android,找到 squeezer可用,目前正熟悉中,謝謝!
    我從使用 Tapatalk 的 GM1900 發送
  18. The Following User Says Thank You to jimmypan For This Useful Post:
  19. #50
    昨天總算setup成功,後續準備做一些優化,也爬了一些文。
    對於LMS的檔案轉換,大致懂意思,想確認,我的檔案大部分直接無壓縮aiff,因為可以tag,aiff是直接設定pcm嗎?
    昨天問的手機操作軟體,有發現material skin,之前想說是web UI,所以沒特別看,後來發現在手機用browser看好像也不錯。
    還有看到soundcheck寫了超多的文章優化,慢慢消化。
    再次感謝大家提供的支援!
  20. The Following User Says Thank You to jimmypan For This Useful Post:
