第42頁,共89頁 第一第一 ... 32404142434452 ... 最後最後
顯示結果從 411 到 420 共計 881 條
  1. #411
    JRiver Media Center 28.0.34 for Debian Buster (i386, arm64 and armhf)
    https://files.jriver.com/mediacenter...0.34-arm64.deb
    JRiver Media Center 28 for Linux
    https://yabb.jriver.com/interact/ind...oard,71.0.html
    剛剛才發現樹莓派 4 也可以跑 Debian 版本的 JRMC,由於 39 鎂的 micro SD 卡好像是無從入手,因此價格為 60 - 10 = 50 鎂:
    https://jriver.com/purchase.html
    https://forums.stevehoffman.tv/threa...center.573945/
    Just found a $10 discount coupon for JRiver Media Center subscription:
    Just type the word 'ritz' in the box for coupon / discount code when you pay. Worked for me just today.
    IdPi on mSD Card -- Available Now
    https://yabb.jriver.com/interact/ind...topic=106807.0
    Quick Start Guide for Installing JRiver Mediacenter 27 on an rPi4 2-4-8GB
    https://yabb.jriver.com/interact/ind...topic=128121.0
    Id Install Guide
    https://wiki.jriver.com/index.php/Id_Install_Guide
    IdPi $39
    https://jriver.com/Id/
    實際上 AlbumPlayer 也是 UPnP Renderer,假如它的表現不遜於 JRMC 就比較簡單了,另一選擇就同樣是免費的 Rygel ,但是只有 piCore64 的 tcz,沒有 piCorePlayer 專用的 tcz:
    http://tinycorelinux.net/12.x/aarch64/tcz/rygel.tcz
    http://tinycorelinux.net/12.x/aarch64/tcz/rygel.tcz.dep
    http://tinycorelinux.net/12.x/aarch6...rygel.tcz.info
    http://tinycorelinux.net/13.x/aarch64/tcz/rygel.tcz
    http://tinycorelinux.net/13.x/aarch64/tcz/rygel.tcz.dep
    http://tinycorelinux.net/13.x/aarch6...rygel.tcz.info
    a collection of DLNA (UPnP AV) services, implemented through a plug-in mechanism
    http://forum.tinycorelinux.net/index...html#msg152896
    It's a media streamer - I've used it on an RPi3 to stream music/videos for a number of years.
    Projects/Rygel
    https://wiki.gnome.org/Projects/Rygel
    Rygel is a home media solution (UPnP AV MediaServer) that allows you to easily share audio, video and pictures to other devices.Additionally, media player software may use Rygel to become a MediaRenderer that may be controlled remotely by a UPnP or DLNA Controller.
    HQPlayer 4 Embedded
    https://www.signalyst.eu/custom.html
    Media server software:
    • Rygel
    相當壯觀的樹莓派 4 系統,網友是 NeutronStar 系列的用家之一:
    https://www.facebook.com/photo.php?f...22783934960382
  2. The Following 3 Users Say Thank You to seeteeyou For This Useful Post:
  3. #412
    rock pi 4A/B/C開發板瑞芯微RK3399rock pi X專配鋁製散熱片
    https://item.taobao.com/item.htm?id=602122321743
    rock pi x開發板 windows10卡片電腦四核X86架構支持Ubuntu/win10
    https://item.taobao.com/item.htm?id=630796566826
    MinorityClean 的 CPU 需求只是 SSE2 指令集,因此 Rock Pi X 的 Atom x5-Z8350 該沒有問題,只是無法跑 HQPlayer 罷了?
    它同樣支援 PD 2.0 規格的電源,因此 Elecom 的 GaN 電源也適用。
    另外還有這個 konahqss(Kona Linux High Quality Sound System)軟件:
    http://simosnet.com/debian/packages/Konalinux/public/
    http://simosnet.com/debian/packages/...nux/otherpkgs/
    https://docs.google.com/document/d/1...7GU9MWsmzZpWHA
    (6/1追記)
    Raspberry Pi OSで動作し音質向上を確認しました
    https://mao.5ch.net/test/read.cgi/linux/1568159444/691
    konahqssを強引にarch系(linux-zen pipewire)に入れてみたが
    素晴らしく音が良くなった。
    作者に感謝
    komahqssの行方
    http://kanzou7.seesaa.net/article/481750100.html
    konahqss ♪サウンドの設定
    http://kanzou7.seesaa.net/article/481947848.html
    Kona Linux ハイクオリティーサウンドシステム 遂に
    http://kanzou7.seesaa.net/article/482217074.html
    GPT形式ディスクにFedora 34 + konahqss
    http://kanzou7.seesaa.net/article/482189299.html
    konahqss 1.0.17登場だが(解決?)
    http://kanzou7.seesaa.net/article/482236183.html
    x86 CPU 還有另一好處,就是支援 Liquorix Kernel 的 MuQSS CPU scheduler:
    https://www.snakeoil-os.net/forums/T...d=4560#pid4560
    Just for your information, i installed a low latency kernel "liquorix" (https://liquorix.net/) on snakoil. Result is quite better in terms of SQ (better transparency, expand sound image and quickness improved), but the boot is really slow: i have to wait aprox. 3 minutes before the player appear in ipeng. I think there is many drivers' errors with this kernel, nothing critical because all works correctly afterward.
    After first comparisons, with this low latency kernel on my goldmund setup, snakoilOS 1.2.2 outperformed innuOS 1.4.7! And this is just the beginning of optimization. Well done guy!
    http://simosnet.com/livecdroom/
    原來 konahqss 的作者還分享了不少有趣的 Linux distros:
    https://drive.google.com/drive/folde...wVfMLCGeO4YLer
    APoraudio 1.0を公開
    Basix 5.0 HiFi
    http://simosnet.com/livecd/basix/5.0/
    Basix 5.0 HiFi(高音質)バージョン HiFiバージョンはnatureOSの高音質部分をBasixへ移植したものです.
    移植にあたってkona cofee様の協力をいただきました.
    ありがとうございました.
    HiFiバージョンをベースにすると高音質なディストリビューションを簡単に作成できます.
    Basix DE 1.0 HiFi
    http://simosnet.com/livecd/basix-de/1.0/
     Kona cofeeさんがkona linuxのサウンド・システムをパッケージ化してくれました.これによってKona Linuxの高音質なサウンドを他のディストリでも気軽に楽しむことができます.
    さっそくBasix de(debian edition)に導入してみました.
    UbuntuベースのBasix hifi版と同じくBasix DEの高音質版Basix DE hifiです.
    NatureOS 5.0
    http://simosnet.com/livecd/natureos/5.0/
    2.高音質なサウンド KLUEの作者にお願いしてKLUEサウンドを装備してもらっています.
    kona cofee様、ありがとうございます.
    設定機能を省いた以外は本家と同等の高音質サウンドです.
    APoraudio 大概是源自這裡的說:
    https://forum.porteus.org/viewtopic.php?p=36689#p36689
    https://www.mediafire.com/file/gcqrt...07.06-i486.iso
    https://www.mediafire.com/file/90haz....06-x86_64.iso
    https://forum.porteus.org/viewtopic.php?p=82781#p82781
    https://www.mediafire.com/file/adcpl...06.27-i486.iso
    https://www.mediafire.com/file/0pdwm....27-x86_64.iso
  4. The Following 2 Users Say Thank You to seeteeyou For This Useful Post:
  5. #413
    https://www.raspberrypi.org/forums/v...c.php?t=306507
    https://www.jeffgeerling.com/blog/20...-nvme-ssds-now
    2021-07-07 - Promote pieeprom-2021-07-06 to stable - STABLE
    https://github.com/raspberrypi/rpi-e...lease-notes.md
    Promote the latest beta to stable. For CM4 users this adds NVMe boot support to the stable release.
    EEPROM 的穩定版本又有更新,正式支援 Compute Module 4 的 NVMe 開機了,因此有 M.2 slot 的 Pizza4 就可以利用 Intel Optane 那種 latency 超低的 SSDs 來跑 LMS,畢竟 3D XPoint 於聲音方面的表現能夠超越 SLC 的 NAND 快閃記憶體,而最棒之處就是 32GB Optane 的淘寶價格實在非常便宜:
    https://github.com/geerlingguy/raspb...ces/issues/136
    OpenEmbed樹莓派4b網關NAS軟路由4G物聯網 linux開發板Pizza4
    https://item.taobao.com/item.htm?id=637737818585
    假如只需要 M.2 2242 長度的 16GB Optane 還可以選擇這種 ¥99 起跳的 Compute Module 4 專用子版:
    https://item.taobao.com/item.htm?id=644628109667
    https://www.waveshare.net/shop/CM4001000.htm
    另外把那個 Kona Linux High Quality Sound System 的 .deb 檔案打開就可以得到 data.tar 壓縮檔,內含不少 shell scripts,小弟沒有估計錯誤的話該可以把它們加入 piCorePlayer 的 User commands 那邊,因此只要透過更改 MTU 或 timeslice 就達到提高音質的效果,並不需要使用作者提供的 GUI。
  6. The Following 4 Users Say Thank You to seeteeyou For This Useful Post:
  7. #414
    引用 作者: sam0402 查看文章
    piCorePlayer 7 Quantum DuoGaN 正式版
    請參閱
    http://www.stsd99.com/phpBB3/viewtop...d67a164#p19877
    請教Sam兄,你的GaN如何連接FIFOPi?
    可否分享連結的照片?謝謝!
    因為最近小弟也入手台版的GaN充電座,
    用過之後,確實效果驚人....
    故有此一問。
  8. #415
    引用 作者: Ericcatz 查看文章
    可否分享連結的照片?謝謝!
    因為最近小弟也入手台版的GaN充電座,
    用過之後,確實效果驚人....
    故有此一問。
    Ericcatz您好,
    小弟的線是自製的,需要動到鉻鐵。
    用的是"WITRN 維簡 PDT001 誘騙器" + 香堡線。
    PDT001是請友人自淘寶代買的。
    如果沒法動鉻鐵,不妨找找誘騙線可輸出5V的。
    由於人不在台北家裡,無法拍線上使用情況。
    附上手工線完成的圖。
    附件 33787
  9. The Following 3 Users Say Thank You to sam0402 For This Useful Post:
  10. #416
    引用 作者: sam0402 查看文章
    Ericcatz您好,
    小弟的線是自製的,需要動到鉻鐵。
    PDT001是請友人自淘寶代買的。
    附上手工線完成的圖。
    感謝Sam兄回覆!我就無法動烙鐵的那個...
    分享一下我的解決辦法:
    在網路上找到這個小玩意,可以把3.3Vor 5V的電源轉傳輸出
    https://www.ruten.com.tw/item/show?21901468270639
    附件 33788
    附件 33789
  11. The Following 2 Users Say Thank You to Ericcatz For This Useful Post:
  12. #417
    有關piCorePlayer 6.1 量子版 DuoGaN 全系列(2021-07-01, 16:12) 的NFS版:
    安裝後 沒有LMS ???
    請問 這個版本是 for player 或是 可以當 LMS (要另行再安裝嗎)?
    求解?
    感謝!
  13. #418
    有關 GaN 電源的短片,小弟覺得真的十分有趣,那個 mains noise analyser 的數值好像是由 710 暴跌至 254→129→91 的說,就是不知道是否故弄玄虛呢?哈哈:
    https://www.facebook.com/ho.keung.18...49065390005674
    畢竟絕大部分的 GaN 電源也是相當便宜,而且品牌和型號方面也是不勝枚舉,真的有必要惺惺作態嗎?
    (香港的插頭都是英式 13A 那種,可是 GaN 電源還是以美式插頭為主,因此有必要加上轉接頭。)
    另外 FiFoPi Q2 跟 FiFoPi Q3 兩者之間是有些分別,前者能夠兼容兩種不同的電壓
    https://www.audiophonics.fr/en/dac-a...p-p-13823.html
    FiFoPi power supply : 5V or 3.3V DC
    https://github.com/iancanada/Documen...ManualV1.0.pdf
    Connect a 3.3V to 6V DC / 200mA (minimum) power supply to J5 to power the FiFoPi
    後者的要求則務必是 3.3V 才可:
    https://www.audiophonics.fr/en/dac-a...p-p-14758.html
    3.3V DC
    https://github.com/iancanada/Documen...ManualV3.2.pdf
    Uses pure 3.3V for a clean side DC power supply. All LDOs have been removed to allow direct operation with a better 3.3V power solution via LiFePO4 or ultra capacitor
    因此選購那些『觸發』或『誘騙器』的時候就必須注意是否提供 Programmable Power Supply(PPS)的功能,沒有 PPS 的話就無法輸出 3.3V:
    https://www.cypress.com/documentatio...1p-and-coolgan
    https://www.cypress.com/documentatio...and-pag1p-pag1
    Supports USB PD 3.0Fixed PDO: 5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/3.25A
    PPS: 3.3V-21V/3A
    但是小弟真的不知道是否 GaN 電源和『誘騙器』兩者亦需要同時提供 PPS 的功能,因此只能夠說保守估計是有那種必要了,醬子才能避免無妄之災。
    最後就是 150W 跟 65W 兩者之間的分別,假如有需要供電給予 12V 或以上的器材,而且耗電量方面比較高,看來還是 150W 那種 GaN 電源比較好:
    https://twitter.com/huwder/status/1412611447821987842
    https://huwder.com/products/150w-gan...c-wall-charger
    USB-C: 5V/9V/12V/15V===3A, 20V===5A
    PPS: 3.3V-21V===5A
    USB-A:USB-A: 4.5V===5A,5V===4.5A, 3.6V-6V===3A, 6V-9V===2A,9V-12V===1.5A
    https://forum.gamer.com.tw/G2.php?bsn=60559&sn=2786
    USB-C1輸出(使用5A線材):5V/3A、9V/3A、12V/3A、15V/3A、20V/3.25A、PPS 3.3V-11V/5A,最大65W
    USB-C1輸出(使用3A線材):5V/3A、9V/3A、12V/3A、15V/3A、20V/3A、PPS 3.3V-11V/3A,最大60W
    USB-C2輸出(使用5A線材):5V/3A、9V/3A、12V/3A、15V/3A、20V/3.25A、PPS 3.3V-16V/4A,最大65W
    USB-C2輸出(使用3A線材):5V/3A、9V/3A、12V/3A、15V/3A、20V/3A、PPS 3.3V-16V/3A,最大60W
    就算耗電量並非那麼高,支援 5A 輸出的話還是比較安全一點,而且一些網友的經驗是聲音方面的優劣跟 A 的數值成正比:
    https://audiophilestyle.com/forums/t...comment-890918
    As the voltage goes up, current requirement should be less and I could probably get by with a 24V/3A rail but my experience has been that an over-provisioned rail sounds better. Even if a tX-USBultra never fully draws a full amp at 12V, a 12V power supply with a 5A rating sounds better than a power supply with a 1A rating. Having discussed this with Paul Hynes, he agrees and so with all of my SR7s, they are over-provisioned.
    當然品質監控也是非常重要,故此選擇有信譽的品牌方為上策。
  14. The Following 3 Users Say Thank You to seeteeyou For This Useful Post:
  15. #419
    引用 作者: cuhulong 查看文章
    安裝後 沒有LMS ???
    求解?
    感謝!
    這邊有教如何安裝LMS
    https://omegaatt.com/blogs/develop/2...oreplayer.html
  16. The Following User Says Thank You to sam0402 For This Useful Post:
  17. #420
    首先探討一下 GaN 電源的 ripple 數值,這邊有不少評測:
    https://www.chongdiantou.com/wp/arch...tegory/reviews
    暫時找到兩個比較優秀的 65W 產品,飛利浦的『摩天輪』 比較特別,附帶 1.5 米的電源線,但是 IEC 插頭就只有英規 13A 或者國標的說,因此需要加轉換頭或者乾脆把 IEC 插頭砍掉後再換上比較高級一點的。
    同一系列的產品看起來都是差不多,因此請注意 2316G 才是正確的型號,不要買錯了 18W 的版本,或者其他並非 GaN 的舊產品:
    充電三兩事 篇一百一十三:體積小巧,電力十足、飛利浦(PHILIPS)摩天輪65W雙Type-c魔方插座 評測
    https://post.smzdm.com/p/aoozz5l9/
    https://www.philips.com.cn/c-p/SPS2316G_93/-
    https://www.chongdiantou.com/wp/archives/60359.html
    十三、紋波測試
    重載情況下,10個檔位輸出時紋波峰峰值在18mVp-p到34mVp-p之間。
    重載情況下,10個檔位輸出時紋波峰峰值在18mVp-p到28mVp-p之間。
    2316G 的正常價格該是接近 ¥200,但是存貨並不是十分不多,因此有一些淘寶賣家就『順水推舟』了。
    2316G 的 PCB 版本是 V1.7,HOP5334A 的就是 V1.9,但後者的價格為 ¥150 以下,由於兩者的拆解圖都相當接近,因此留待各位作出明智的決定了:
    拆解報告:PHILIPS飛利浦65W氮化鎵快充摩天輪插座
    https://www.chongdiantou.com/wp/archives/61519.html
    飛利浦10年研發生產運營商,昊達新品牌ON推出65W氮化鎵插座,PD快充完美融合
    https://www.chongdiantou.com/wp/archives/63914.html
    拆解報告:ON 65W 2C1A氮化鎵快充插座HOP5334A
    https://www.chongdiantou.com/wp/archives/70784.html
    另一款 Nubia PA0202 具備多種顏色任君選擇,明天好像有 500 件特價品:
    https://www.chongdiantou.com/wp/archives/81559.html
    2、紋波測試
    重載情況下:九個檔位輸出時紋波峰峰值從14mVp-p到70mVp-p不等。
    重載情況下:九個檔位輸出時紋波峰峰值從14mVp-p到64mVp-p不等。
    https://nubia.tmall.com
    努比亞65W氮化鎵充電器Gan Pro多口iPhone12適用於蘋果PD快充20W華為小米閃充插頭ipad筆記本macbook電腦手機
    https://detail.tmall.com/item.htm?id=628041370395
    前500件限時108元起,活動於7月14日 00:00開始,每人限購1件,超過全部恢復活動價
    https://mall.nubia.com/products/nubi...-ports-charger
    https://www.amazon.com/Charger-Adapt.../dp/B08RRTTHSG
    大幅降低 ripple 數值的方法之一是利用 LT3042 或者 LT3045 這種穩壓的 LDOs,但是必須把 GaN 電源的電壓提高一點,假設器材是吃 5V 的話,電源的電壓就必須調節到 7V,然後 LT3045 把 7V 減去 2V 就會把電壓降低 5V 輸出了。
    電壓的差距越大,產生的熱量就越多,因此 2V 左右的差距該是一個平衡點。
    友站的一些例子如下:
    https://www.pcdvd.com.tw/showthread.php?t=1170941
    http://www.andaudio.com/phpbb3/viewt...?f=18&t=142142
    一些日本網友亦有留意淘寶賣家的 10 片並聯產品,效果是相當正面的:
    https://twitter.com/na_bct/status/1339907093772394496
    https://twitter.com/yohine_ik/status...83137107136513
    https://twitter.com/thkeUKKpfIW8Elz/...66230505918466
    音は奥行きは物凄い
    それは微小信号を出せていると言うこと
    分解能は凄まじい
    加えて峻厳である
    癖が、と言うよりごまかしがないほど分解能しクリーンであるが故に峻厳
    只でさえ異形の分解能であるのに此処まで分解、暴露して、さらにこの先は踏みいるべきかわからない
    一片 LT3045 為 0.5A,4 片並聯就是 2A 輸出,10 片並聯就是 5A 輸出,餘此類推。
    電壓輸出是 15V 或以下,應該能夠滿足大部分器材的需要。
    預算許可的話還可以考慮雙重穩壓的方案,例如先把電源的電壓提高到 9V,然後第一組 LT3045 把 9V 降低到 7V,然後第二組 LT3045 再把 7V 降低到 5V,進一步把 ripple 的數值降低多一點。
    5A 輸出的話好像是只此一家,可以按照各位的需要和預算來選擇多少片並聯:
    https://item.taobao.com/item.htm?id=596666068669
    https://item.taobao.com/item.htm?id=620730645365
    https://item.taobao.com/item.htm?id=621194139045
    https://item.taobao.com/item.htm?id=630808013093
    有能力 DIY 的話還可以選擇這種分為左右兩邊的 2A × 2 或者 1.5A × 2 穩壓:
    https://www.diyinhk.com/shop/audio-k...57v-14ax2.html
    https://www.diyinhk.com/shop/audio-k...215v-15a2.html
    https://www.diyinhk.com/shop/outlet/...-pcb-only.html
    另一方法就是利用電容或超級電容來降低 ripple 的數值,人所共知的 IanCanada 那些產品就毋須介紹了。
    淘寶有售的產品如下,價格比較親民:
    樹莓派電源淨化板 濾波 DAC音頻解碼器 數播 同軸 適用所有擴展板
    https://item.taobao.com/item.htm?id=633664880034
    樹莓派HIFI電源濾波超級電容moode volumio 音質聽感變好動力澎湃
    https://item.taobao.com/item.htm?id=642864422111
    還有功效顯著的 Duelund JDM bypass caps,由於樹莓派這種器材的耗電量有限,故此只需要最便宜的 0.01 µF 就遊刃有餘。
    Bypass caps 的簡介:
    https://www.itsfun.com.tw/旁路電容/wiki-0391731-4657921
    這邊有超多電容品牌與型號的聽感,一般的 Duelund caps 獲得 14 至 15 的最高分數,配合錦上添花的 Duelund JDM bypass caps 後還可以增加 2 分:
    http://www.humblehomemadehifi.com/Cap.html
    一步到位的純銀型號:
    https://www.hiendy.com/hififorum/for...e=2#pid2939579
    小弟這部transport 三組電全部都是digital, 本來已經用緊一大堆cap,最近也只是各加了一粒0·01silver bypass cap…改變絕對是day & night!
    純銀/鍍錫銅/純銅的價格為 35/31.5/16 英鎊:
    https://www.​hificollective.co.uk/ca...ag-600vdc.html
    https://www.partsconnexion.com/DUELUND-87178.html
    https://www.hificollective.co.uk/cat...er-600vdc.html
    https://www.partsconnexion.com/DUELUND-87248.html
    https://www.partsconnexion.com/DUELUND-86921.html
    這是越南的價格:
    http://www.diyaudio.vn/dad_capacitors.htm
    淘寶的運費比較低,但是價格方面跟那些歐美的那些網店比較就顯得令人咋舌:
    丹麥Duelund 杜蘭 JDM 純銀箔油浸紙介電容 精緻高雅水蜜桃的聲音
    https://item.taobao.com/item.htm?id=618896431527
    丹麥杜蘭Duelund JDM銅箔油浸紙介電容 豐潤高雅多汁多肉驚世之作
    https://item.taobao.com/item.htm?id=618636666143
    淘寶上的評價也是很好,怪不得那個登峰造極的 Taiko Audio SGM Extreme 也是選擇 Duelund 純銀電容作為 bypass cap:
    https://www.monoandstereo.com/2021/0...o-duelund.html
    https://www.facebook.com/duelundcohe...52379124791980
    https://www.facebook.com/duelundcohe...40339775995914
    便宜又大碗的好東西,製作 DC 電源線或其他線材的時候值得一試:
    https://www.diyaudio.com/forums/vend...ml#post4676309
    As far as reducing AC line junk I got spectacular results with Finemet Beads.
    https://www.arcs-shop.com/product-list/27
    https://www.amazon.co.jp/NFJ-O255-Φ5.../dp/B01M3QY9I2
    雙電源的好處:
    https://audiophilestyle.com/forums/t...comment-813712
    We've tested 3 configurations:
    1. ATX only (using a Pico-PSU with a clean 12V input)
    2. 12V only
    3. ATX + 12V
    1. and 2. sound similar in our tests. 3 sounds significantly better. At first, we were expecting 2. to be the best, as it removed the Pico-PSU from the equation. But seems the board itself will do the same job as the Pico and doesn't seem to do it any better than that.
    We've fthen further tested with separate rails using the ATX only and compared to using separate rails for ATX + 12V input. The result is the same, adding both ATX and 12V results is clearly superior sound with this board.
    https://audiophilestyle.com/forums/t...omment-1140426
    2) 2 x Keces P8 for CPU
    On the motherboard, the CPU has 2 connectors: 8 pin and optional 4 pin. I used to have 1 Keces P8 on the 8 pin. I added a second Keces P8 on the 4 pin and the sound became much bigger, more powerful, fuller. Worth every penny and can’t go back.
    http://www.andaudio.com/phpbb3/viewt...rt=25#p1122064
    網兄玩到雙電源了,其他的經驗一定比小弟豐富,
    歡迎多分享!
    我確定多電源會有更好的效果,
    因為認識的朋友中,有人單機接三顆1200W,是我見過最極致的玩法了!
    http://www.andaudio.com/phpbb3/viewt...rt=50#p1123268
    雙電源為何更好?答案應該是電源雜訊隔離。
    請參考友站的討論串,建議全部看完:http://www.myav.com.tw/bbs/showthrea...eadid=20450539
    大部分的 GaN 電源也提供多於一個輸出,因此 65W 甚至 100W 以上的那些型號就一試無妨,效果理想的話還可以嘗試分開兩個獨立 GaN 電源同時供電給予同一樹莓派。
  18. The Following 2 Users Say Thank You to seeteeyou For This Useful Post:
