2021-08-13, 06:38 PM
#481
piCorePlayer6.1.0-Xenomai-44.1-48KHz雙機入門簡易安裝教學
2021-08-14, 04:40 PM
#482
The Following 4 Users Say Thank You to sam0402 For This Useful Post:
2021-08-19, 10:07 AM
#483
大家好,我遇到一樣的問題。
我換了 pCP8,開機後,Pi4 IP 一樣,從 IP scanner 上看狀態,Pi 4 應該是開起來了。
但是我用以前的方式,瀏覽器打上 IP 卻無法連線進入 squeezelite。
ssh 也連不進去。
砍掉 C:user/username/ssh/known_hosts 檔案也沒有用
不知道有沒有樂友遇到一樣的問題,後來怎麼解決呢?
作者: seeteeyou
2021-08-19, 12:41 PM
#484
The Following User Says Thank You to sam0402 For This Useful Post:
2021-08-19, 02:57 PM
#485
作者: dearflight
大家好,我遇到一樣的問題。
ssh 也連不進去。
dearflight兄您好
其實Sam兄的pCP6.10或pCP8開機後IP scanner找得到IP,但是WEB介面和ssh都進不去的狀況,
大多是Linux Kernel有正常開機但是pCP主程式並沒有正常的載入。
會發生這種情形大多都是USB開機碟或CF卡不夠穩定讓pCP主程式正常載入,所以請先改用Micro SD卡來開機會比較穩定。
其實我自己也遇過Sam兄的pCP改版後,之前版本可以開機的CF卡在更換新版後卻無法開機的狀況。
當我遇到時會改用Micro SD卡測試可以正常開機後,再使用其他不同的CF卡測試看看能不能開機。
The Following 2 Users Say Thank You to tetsuka For This Useful Post:
2021-08-19, 05:08 PM
#486
溫馨提示:AirPlay 2 有一些限制:
Can Airplay 2 support Hi-Res Audio?
https://www.technologyfocus.net/can-...-hi-res-audio/
https://www.forbes.com/sites/markspa...s-some-polish/
Apple’s AirPlay 2 protocol downsamples audio files to 24-bit 44.1 kHz
看來 RAVENNA 也不錯:
https://www.merging.com/products/als...a_aes67_driver
PCM up to 384kHz
Native DSD playback (64/128/256) support (DOP not supported)
https://groups.google.com/g/audio-over-ip/c/Jsua2t5QxXI
I have recently published on GitHub an AES67 Linux Daemon and the associated configuration WebUI both licensed under the GPLv3.
The daemon uses the Merging Technologies ALSA RAVENNA/AES67 Driver
https://github.com/bondagit/aes67-linux-daemon
https://github.com/bondagit/aes67-li...ultikernel.zip
https://github.com/bondagit/aes67-li...emon/issues/29
I'm using your wonderful program on my Raspberry Pis, and it's great
https://github.com/bondagit/aes67-li...ment-767896687
Device A (10.1.14.120)
Raspberry Pi 4 Model B Rev 1.1
Hardware: BCM2711
Revision: a03111
Kernel: 5.4.83-v7l+
Result 1: ok
Result 2: ok
Result 3: ok
其他相關的資源:
https://aes67.app/resources
https://hartung.io/2020/07/aes67-resources/
Chord 的 Hugo M Scaler 只有 100 萬 taps,HQPlayer 有 1600 萬 taps,而 PGGB 的離線升頻則可以高達 80 億 taps,因此 16fs 或 32fs 的 noise shaping 實屬革命性的效果 ,當然先決條件就是 DAC 必須能夠支援 768 kHz 或 1536 kHz 的 USB/I²S/雙同軸輸入。
日後 PGGB 的實時升頻版本或許可以透過 RAVENNA 把 8fs 的 384 kHz 音訊傳送到 ALSA 那邊,且看屆時 taps 的上限有多高:
https://www.whatsbestforum.com/threa...97#post-738259
I forgot to add we are also discussing adding PGGB based real-time and/or offline up/down/resampling/noise shaping and volume control in TAS with the PGGB author. This can have some pretty distinct advantages with various DACs for various reasons,
pCP7 已經新增了這個功能,因此 pCP8 也可以試試用 http://pcp.local 代替原來的 IP,當然不喜歡的話也可以把那功能關掉:
https://forums.slimdevices.com/showt...rePlayer-7-0-0
mDns enabled by default. Burn your image, boot the RPi, and find it by http://pcp.local This is broadcasting the hostname of your player, so please change your hostname on the tweaks page if you have multiple pCP devices. (mDns can be disabled on the tweaks page too)
https://forums.slimdevices.com/showt...=1#post1011164
BTW: You can disable "Broadcast .local" on the [Tweaks] page if it is interfering with shairpoint-sync.
Raspberry pi 4 + piCorePlayer 7.0.0 折騰筆記
https://omegaatt.com/blogs/develop/2...oreplayer.html
如果需要判斷是否 CF 卡的問題,可以嘗試清除 Windows 的 DNS cache:
代碼:
ipconfig /flushdns
ipconfig /displaydns
然後 ping 一下 pcp.local 再看看是否原來的 IP:開啟瀏覽器後測試 http://pcp.local 和 http://pcp.local:9000 兩者是否正常,假如砍掉 known_hosts 後的 SSH 不行,瀏覽器也是沒戲唱,最後的結論就是挑 CF 卡,因此必須改用 Micro SD 卡開機。
另外 SLC 的 64GB Micro SD 卡終於有現貨了,盛惠 100 鎂:
https://www.mouser.com/ProductDetail...DSDQED-064G-XI
8GB 的話好像有 33 片快將上架,只要同時訂購 3 片就享有免費的 UPS 全球優捷速遞:
https://www.mouser.com/ProductDetail...DSDQED-008G-XI
https://documents.westerndigital.com...ed-microsd.pdf
SD5.1 UHS-I 104
Speed Class 10, U3
The Following User Says Thank You to seeteeyou For This Useful Post:
2021-08-20, 03:23 PM
#487
感謝 tetsuka, seeteeyou, cuhulong 提供的資訊。
結果真的是挑 CF 卡。
我換了一張很舊規格很普通的卡,竟然開起來了。
如果大家也遇到一樣的問題,可以試試看這個方向。
作者: tetsuka
dearflight兄您好
2021-08-20, 08:02 PM
#488
2021-08-21, 12:01 AM
#489
不知道有沒有樂友比較過 PC (LMS) + Pi4 和 Pi4 (LMS) + Pi4 效果差距多大。
畢竟 PC 的效能還是高過 Pi4 一大截,但是要搞一台夠好的 PC 也是要花不少錢。
PC 講究的話,Power/ram/cpu 都要很好。Pi4 還是相對便宜。
如果差距不大,似乎 Pi4 蠻划算的。
2021-08-21, 02:15 AM
#490
其實還有一個比較簡單一點兒的選擇,CM4 同樣可以跑 sam0402 兄的 pCP8:
https://item.taobao.com/item.htm?id=643286972960小弟猜想那是 tetsuka 兄的評論,當然亦有可能是其他樂友?
實際上真的只是簡單一點兒,電源方面並不支援 USB-C PD,理論上是 DC 輸入需要 6V 至 9V,但推薦 6V 至 7V,那麼 ELECOM ACDC-PD1165BK 的 9V 輸出還是需要透過 PD 誘騙器/誘騙線才能夠得到尚可接受的電壓,當然利用 LT3042 或者 LT3045 就可以把 9V 降到 7V 或 6V 輸出,電源的質素方面也會得到改善。
問題是 DC 母座和 DC 公頭兩者也是瓶頸,impedance(阻抗)太高的先天性缺陷就只會糟蹋了好的電源和 DC 電源線:
https://audiophilestyle.com/forums/t...omment-1149407
According to Paul the SR4 has an output impedance of <3 milliohms from DC to 100kHz but when you combine the impedance of the DC cable and the barrel connector (which are horribly high impedance), then the output impedance of both sources are roughly the same and while the batteries and the SR4T achieve roughly the same dynamic contrasts (which is to say both are excellent), the batteries in comparison sound slow, soft, and smeared around the edges.
https://audiophilestyle.com/forums/t...omment-1149634
Among the worst connectors are the barrel connectors. Those are high impedance.
https://audiophilestyle.com/forums/t...omment-1149674
Yes, lots of possible options for DC wire but those high-impedance barrel connectors are instant turn offs and make the whole setup look cheap. I think the connectors are potentially more damaging than the wire.
而 impedance 最低的就是 WBT 那些 RCA 母座和 RCA 公頭,加上純銀/純銅的電導率也是一流,當然這個世界的定律就是一分錢一分貨:
https://audiophilestyle.com/forums/t...omment-1150480
還有其他需要注意的地方,CM4 沒有 40-pin GPIO 的話就需要另加 iancanada 兄的 BridgePi/XingCore U30 子卡兩者才可以連接 FifoPi/TransportPi 那些 HAT。
網卡只支援 100Mbps,假如 network switch 只支援 1Gbps 的話就完蛋了。
散熱方面也相當頭痛,由於 CPU 超頻後可以提升音效方面的質素,不知道 4mm 厚度的純銅散熱器加上外置的小型風扇是否能夠把溫度保持在合理的範圍,雖然 pCP8 的 kernel 5.13 的確令溫度有所降低,但是這塊純銅散熱器的面積還是比較細小:
https://www.aliexpress.com/item/1005002935486960.html
USB 2.0 port 亦只有一個,大概是只可以用 SD 大卡來開機了,不用考慮任何讀卡器/CF 卡/隨身碟。
現在實屬過渡時期,說不定 5nm 的 Apple M1 能夠大勝 16nm 的 ARM Cortex-A72(就是 CM4 的 BCM2711 SoC 那一顆 CPU),理論上靜觀其變才是權宜之計。
趁現在有時間的話就把手上的檔案都升頻到 16fs 的 705 kHz/768 kHz,屆時 Apple M1 專用的 pCP8 版本就可以盡享 PGGB 的好處:
https://audiophilestyle.com/forums/t...omment-1153649
Having listened repeatedly to the files I upsampled with PGGB during the trial period, I concluded that I no longer wish to listen to the rest of my 2,000-plus digital albums without the benefit of PGGB. The improvements it has made to digital music playback are many and extraordinary, as I listen at 32 bits/705.6-768 via Audirvana 3.5 thru the Chord Mojo DAC direct to a naim NAP160 power amplifier and Spendor/REL speakers. No more playing around with audio settings, and no more EQ/convolution! My only regret at the time of purchase is that this software wasn't available 10 years ago. I haven't enjoyed listening so much since the days when I first discovered the music I would love. Indeed, PGGB enables a voyage of musical rediscovery that I am only now beginning. Thank you to ZB and the contributors to Audiophile Style who have promoted this software!
二手的 Chord Mojo 只是 8,500 元,但是 PGGB 的效果已經十分明顯:
https://www.hifizero.com/cht/index.php?q=mojo
當然 30 天的免費試用完結後的 license 就盛惠 14,000 大元,還有額外的硬碟空間,幸好很久以前 LMS 早已支援 WavPack(FLAC 只可以支援 384 kHz)格式:
http://svn.slimdevices.com/repos/sli...hangelog7.html
WavPack is now supported.
https://forums.slimdevices.com/showt...l=1#post233050
I have been using this patch extensively for the last few days with my Squeezebox3, and it appears to be very stable on both Linux and Windows. It has correctly played just about all the WavPack files I've tried with it, and I was particularly surprised to find it even works fine with my collection of 24/96 files! I don't have my WavPack files tagged with album art [yet], but that feature is very cool too.
有一些 DAC(例如價格並非那麼高的 Musician Audio Pegasus)更可以支援 1536 kHz(理論上 pCP8 該沒有問題吧?),效果比 HQPlayer 的 DSD 升頻更上一層樓:
https://audiophilestyle.com/forums/t...omment-1127088
And then comes the PGGB pre-upsampled 32fs files(using default settings) and all of a sudden the details of 32fs becomes so natural and the response of the orchestra is so unanimous yet you can hear the sounds of different members clearly and with good enough timbre. It seems that suddenly you can get to the best of both worlds. And that gave me the signal to go all the way for PCM. Now the PCM may still be a little more forward but the feeling are excellently conveyed. Everything is so fast so lively and so transparent. DSD would seem a little laid back and occasionally lacks liveliness.
Musician Pegasus R2R DACを入手した
http://blown-lei.net/endive/blosxom..../20210521a.htm
日本網友的分享,他也是樹莓派的用家,閱讀過他的文章後才發現 Music Player Daemon 的好處,另外其他日本網友也是結合了 MPD 和 Xenomai/EVL 的力量:
https://sites.google.com/site/digifi...i-ban-nitsuite
