第32頁,共48頁 第一第一 ... 22303132333442 ... 最後最後
顯示結果從 311 到 320 共計 475 條
  1. #311
    業界最高の面記録密度を実現した750GBの2.5型HDDの商品化について
    厚さ9.5mmの2.5型HDDにおいて業界最大記憶容量を実現
    http://www.toshiba.co.jp/about/press...3/pr_j2501.htm
  2. #312
    預設 FOSTEX
    FOSTEX USB CABLE
    ET-U1.0
    Release April 15, 2010
    Price ¥ 9,450 (approx.)
  3. #313
  4. #314
    Decware ZDAC-1
    24/192kHz Up-sampling DAC
    Coax, Optical, USB
    $1269.00 SUG. RETAIL
    FACTORY DIRECT PRICE $875.00
    SPECIAL LIMITED INTRODUCTORY PRICE
    $799.00
    FEATURES:
    Digital inputs: 1-Coaxial, 1-Optical, 1-USB (Windows XP/Visa, Mac OS, Linux compatible)
    Inputs selectable from the front panel.
    USB is plug and play, no drivers needed. Compatible with 1.0 and 2.0 USB standards.
    Removable power cord with high-end IEC connector
    Analog outputs: 2- Gold/Teflon RCA jacks
    CS4398 24 bit 192kHz DAC chip - 120dB dynamic range with -107dB THD+Noise.
    Digital receiver CS8416 with low-jitter recovery clock
    CS8421 up-sampler
    Dual FET output stage with Burr Brown followers
    Nichicon MUSE caps, WIMA, Rubycon as well as mil spec 1% resistors used everywhere.
    Front panel LED indicates on/off.
    Rear panel LED lights when USB is connected to computer.
    http://www.decware.com/newsite/ZDAC1.html
  5. #315
    Wyred4Sound DAC
    Wyred4Sound's new DAC comes in two flavors, DAC1 [$999] and DAC2 [$1.499]. Both run the ESS 9018 Sabre32 Reference 32-bit DAC and modular boards for future improvements. Both run automatic 500kHz oversampling, a fully balanced circuit with XLR and RCA outputs, an oversized power toroid and a 35A bridge-rectified power supply with 88.000uF of capacitive filtering. The DAC1 gets 2 x coax and 2 x optical inputs, a 16/48 USB input and an LCD display for input and sample rate confirmation. The DAC2 adds defeatable 32-bit remote volume, a VFD display, HT bypass inputs, 1 x XLR input, 1 x balanced I-squared-S on HDMI input, a 24/192 async USB input and Wyred4Sound's own low ESR 'super caps' in the power supply just like the STP-SE preamp. The DAC1 begins shipping April 9, the DAC2 April 23
    http://www.wyred4sound.com/
  6. #316
  7. #317
  8. #318
  9. #319
  10. #320
    分享一下~
    HRT Music Streamer II Asynchronous USB DAC 24/96
    $149
    他的上一代是 The Absolute Sound Golden Ear Award Winner!
    “What if I told you that you could have a cheap USB DAC that delivers true high-end sound? If you don’t believe me, try comparing it with your favorite high-priced USB DAC. After all, at this price you can afford to be daring!”
    – Steven Stone, Golden Ear Award Issue, The Absolute Sound, June/July 2009
    進階版
    HRT Music Streamer II+ 24/96 $345
