顯示結果從 1 到 5 共計 5 條
    預設 Sonus Faber 發表三款新喇叭
    在今年CES上我們就看到Sonus Faber的新書架喇叭Monitor(約USD 3,000)已亮相,現在官方網站已經公佈,其實同一系列的還有Liuto落地喇叭(約USD 6,000)及Smart中置。
    http://www.my-hiend.com/vbb/showthread.php?p=30413
    monitor
    Structure: 2-way free standing speakers with a heated cabinet Housing: Format lute guarantees an excellent stiffness, without resonance, and with good control-wave.
    Tweeter: 25 mm High Definition driver with a dome of coated fabrics, wide surround of soft polymers and rear chamber. Special structures.
    Midrange driver: 150 mm bevel driver. Design with the free compression chamber and a separate thermal Cast polypropylene textiles basket, known as the "curve" and the aim of achieving excellent dynamic characteristics. Special structures.
    Crossover: Nerezonantna construction of second degree with optimum phase characteristics and spatial / temporal relations. Point buffer at 3500Hz.
    Frequency Response: 55 Hz - 25,000 Hz, including circuits for tuning
    Sensitivity: 86 dB SPL (2.83 V/1m)
    Nominal impedance: 8 ohma
    Power: 30W - 150W, without limiting
    Finish: Combination of wavy black finishing and black piano lacquer high shine
    Dimensions: 350 x 185 x 335 mm (HxWxD)
    Weight: 16.5 kg / pair - net, 19.5 kg / pair - pack
    Racking: Dimensions: 667 x 395 x 300 mm (HxWxD). Weight: 15.2 kg / pair - net; 18.5 kg / pair - package.
    Overall dimensions: 1018 x 395 x 335 mm (HxWxD).
    liuto
    Structure: 3-way free standing speakers with a heated cabinet Housing: Format lute guarantees an excellent stiffness, without resonance, and with good control-wave. Internal ribs are set to eliminate unwanted vibrations
    Midrange driver: 150 mm bevel driver. Design with the free compression chamber and a separate thermal Cast polypropylene textiles basket, known as the "curve" and the aim of achieving excellent dynamic characteristics. Special construction is in accordance with acoustics enclosure.
    Low-frequency driver: 220 mm bevel driver from lightweight aluminum alloy and magnesium.
    Ultra-dynamic performance and linearity. Used the special coaxial anti-drill, scheduled for the elimination of resonant frequency and distortion.
    Crossover: Nerezonantna construction of second degree with optimum phase characteristics and spatial / temporal relations. Separating the point at 350 Hz - 3000 Hz.
    Frequency Response: 40 Hz - 25,000 Hz, including circuits for tuning
    Sensitivity: 89 dB SPL (2.83 V/1m)
    Power: 40W - 250W, without limiting
    Finish: Combination of wavy black finishing and black piano lacquer high shine.
    Dimensions: 1031 x 236 x 413 mm (HxWxD)
    Weight: 62 kg / pair - net  73 kg / pair - pack
    smart
    Structure: 2-way free standing speakers with a heated cabinet Housing: Construction of a split side panels guarantee a better control control resonance and standing waves
    Crossover: Nerezonantna constructions third row with optimum phase characteristics and spatial / temporal relations. Point buffer at 2000 Hz.
    Frequency Response: 60 Hz - 25,000 Hz, including circuits for tuning
    Sensitivity: 88 dB SPL (2.83 V/1m)
    Finish: Combination of wavy black finishing and Black
    Weight: 11 kg / pair - net  12.5 kg / pair - pack
    原廠網站
    www.sonusfaber.com
    没以前的好看了,外型感觉硬硬的。
    Toy系列還有以前的感覺,而且那對書架很可愛~~~~(inlove)
    但是"價錢"一點都不"玩具"...(u)
    Toy正如其名,玩具啦....
