第2頁,共11頁 第一第一 1234 ... 最後最後
顯示結果從 11 到 20 共計 103 條
    我覺得算辦得不錯耶,也不是很小,不是很大,還是蠻多有特色的
    的確是人手不夠啊!坐前台的都是志工,DC Hi-Fi跟DC DIY兩個clubs的會員輪班執勤在前當收銀員,這樣才有可能連續辦了七年,還越辦越大.
  2. #12
    MY-HEAD.....XD
    引用 作者: Deen 查看文章
    這個有好笑到
  3. #13
    引用 作者: Leo Yeh 查看文章
    不好意思打擾啦....我是六去的額
    我家離那裡不到10公里,很近.
    禮拜六我下午才去,待到快六點才走.
  5. #14
    預設 Merrill Audio Advanced Technology Labs, LLC - 超高端音频设计师
    非常感谢您访问我们的房间。我们很荣幸美林音频设计和建造超高端音频设备,价格比竞争对手好得多。我们为我们的产品和设计赢得了许多奖项。我们有VERITAS Monoblocks,Thor Monoblocks,Taranis立体声放大器,Cara Preamplfiier,Christine参考前置放大器和Jens Reference Phono Stage。据说我们的Phono舞台是许多人可以使用的最好的舞台。美林音频是一家年轻的公司。我们与德国Physiks合作的表演,并一起演示。不幸的是,我们的邻居贝司流了很多流血。该系统可以产生大量的低音,当播放得太大时,会使房间过载。我的来自德国Physiks的合作伙伴使用耳塞,打得太大,因此超负荷的房间,造成太多的低音。Lyra Delos墨盒速度非常快,Jens唱机舞台速度非常快,低音深沉而紧密。这是你会听到比平常低音更多的原因之一。有了正确的音量,它非常紧密,干净而深沉。我们也很幸运能够从VPI获得Fat Boy音色,这使得我们可以从之前的LP设计更清晰更强劲的低音。所有这些都会产生好的,干净的,强劲的低音,假设你不会为房间打得太大声。我们很幸运,有这么好的电子产品和最好的唱机舞台。如果你有机会,请停止我们的我希望你能听到声音舞台的深度,宽度和精确程度。大小也是现实的。详细信息或要求家庭试镜。再次感谢您的光临。
    [QUOTE = Leo Yeh; 233640] Merrill Audio is arguably the largest advertiser in this exhibition. The cover of the exhibition is covered with the back cover, and many bags are also sponsored for free. Mainly to promote the entire set of Merrill Audio German Physiks speakers, the beginning is to listen to vinyl, to be honest that the sound is not very good, low frequency too much, the sound loose, I originally thought it was a space relationship, and later changed to a digital source broadcast, the whole The sound becomes better, it seems that the vinyl system is not adjusted!
    [/ QUOTE]
  6. The Following 2 Users Say Thank You to MerrillAudio For This Useful Post:
  7. #15
    Thank you for the prompt response, actually I like your good products. They are very beautiful with reasonable price. We all know there are lots of uncontrolled factors at a hotel show room, it's really difficult to have perfect performance of the system. Because I like your products, so I have much expectation of it.
  9. #16
    預設 GTA, Sound Insight, Pass Labs, Triode Wire, Acoustic Signature, Estoeric, Vu Jade
    CAF這種地區性的展覽有看頭的地方就是會看到一些比較少參展的美國品牌,這間展房的主喇叭是GTA3R的四件式,主聲道為全音域的平面單體與絲帶高音,前端使用Pass Labs擴大機驅動,類比訊源為德國Acoustic Signature Triple X,數位訊源為Esoteric K-01X,音響架為Kotan,聲學產品ATS Acoustics。不得不說四件式喇叭就是整體全頻段與音場上佔有優勢,聲音還不錯!
    此篇文章於 2017-11-08 11:23 AM 被 Leo Yeh 編輯。
  10. The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
  11. #17
    預設 VAC Audio, Von Schweikert Audio, Esoteric, Transrotor, Critical Mass, MasterBuilt
    這是總價超過1百萬美金,台幣三千多萬的大系統,也是本次CAF展覽最大套的系統,系統大展房更大,應該跟圓山飯店的敦睦廳差不多,VAC是美國高級真空管機的代表,這次整套旗鑑展出推動Von Schweikert Audio ULTRA 11千萬喇叭,頻寬可怕從10Hz~100kHz,內建的低音擴大機功率為2000 watts RMS,推動15"密閉式低音(位於喇叭背面),四顆9"的陶瓷中低音、2顆7"的陶瓷中音與2顆鈹高音、兩顆5"的鋁帶超高音,喇叭後方也有對應的高音單體。數位訊源部份,為Esoteric Grandioso整套,還有最新的N-01播放機,類比訊源為Transrotor,音響架為CMS。CAF光"看"這套這麼大陣仗就已值回票價了,至於聲音部份,我星期六聽的時候狀態並不是很理想,其實這些年在CES等各展覽聽VAC的表現印象都不錯,可能場地與調聲上變數太多。
    VAC Audio
    Statement Phono Stage $80,000 USD
    Statement Line Stage $75,000 USD
    Statement 450 iQ (two pair) Monoblock Power Amplifiers $120,000 pr USD
    ULTRA 11 Loudspeaker $295,000 pr USD
    Shockwave V12 Subwoofer $11,500 ea USD (subwoofer used for active room correction)
    Esoteric
    N-01 Network Audio Player $20,000 USD
    Grandioso P1 Transport $35,000 USD
    G-01 Master Clock $18,000 USD
    Grandioso D1 Monoblock DAC $36,000 USD
    Transrotor
    Orion Turntable $30,000 USD
    5009 Tonearm $3,800 USD
    Air Tight
    Opus Cartridge $15,000 USD
    MasterBuilt Audio
    Ultra Line Interconnects, Power Cords, and Speaker Cables
    Critical Mass
    Olympus Six Shelf Rack $60,900 USD
    Maxxum MK3 Six Shelf Rack $36,900 USD
    Black Diamond MK3 Amp Stand $2,995 ea USD
    Acoustic Sciences Corp.
    ASC-TubeTrap Room Conditioning
    Critical Mass
    此篇文章於 2017-11-08 11:38 AM 被 Leo Yeh 編輯。
  12. The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
  13. #18
  14. The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
  15. #19
  16. The Following 2 Users Say Thank You to Leo Yeh For This Useful Post:
  17. #20
  18. The Following 2 Users Say Thank You to Leo Yeh For This Useful Post:
