第1頁,共3頁 123 最後最後
顯示結果從 1 到 10 共計 29 條
    哇, Dynaudio的新叭:O , 真想一窺究竟, 而且現在正在香港音響展展出,
    根據最新消息台北圓山Hi-End音響展也會展出這對30周年的新叭, 敬請期待8)
    三度無相位圓場劇院發聲物品
    Dynaudio will mark the company's 30th anniversary by releasing their Sapphire floorstanding loudspeaker ($16,500 per pair). There will be four finish options for the semi-gloss lacquered wood sections of the cabinet, including Bordeaux (Rosewood stained Bird Eye Maple), Amber (Cherry stained Bird's Eye Maple), Mocha (An Espresso stained Bird's Eye Maple), and Ivory (a Natural stained Bird's Eye Maple). The back section of the cabinet will be finished in a semi-gloss black lacquer. Fit and finish will naturally be of the highest level. Production is limited to 1,000 numbered pair worldwide. Dynaudio's Sapphire driver complement includes a conventional tweet/mid/woof/woof array of 28 mm tweeter, a 15 cm mid/woofer and two 20 cm woofers. The cabinet has perfectly formed wood surfaces, cut like a jewel into a shape revealing distinct gem-like profiles when viewed from different angles. Danish master craftsmen made a totally unique loudspeaker celebrating 30 years of Dynaudio. Featuring one of the most elaborate and distinctive loudspeaker cabinet designs ever, hand-built in the Dynaudio tradition of excellence, the Sapphire is finished in a satin-gloss lacquer that brings out the finest detail in the cabinet's alluring wood grain. The Sapphire will begin shipping this fall. See Enjoy the Music.com's review of the Dynaudio Confidence C2 floorstanding loudspeaker by clicking here.
    http://www.enjoythemusic.com/news/
    看來鈦孚訂價還OK...|(|-
    記得C4的retail price好像是$16,000
    Sapphire價格跟C4有得比, C4定價680,000, 不知2者聲音走向有何差異,
    看來想得知數據情報還需等到9月初原廠網站才會公佈...:^)
    這個藍寶石(Sapphire)的外型果然不同凡想,正面看上寬下窄的斜切面,側面注意看木紋處像寶石般鑲嵌入,後上方斜削的造型更是獨特,丹麥的工匠藝術真是厲害,如果真有出寶藍色的木紋就更像藍寶石了。
    文章末的網站連節Dynaudio Confidence C2 review,一樣寫的相當好可以仔細看一看。
    warwick
    看來鈦孚訂價還OK...|(|-
    引用 作者: warwick 查看文章
    warwick
    的確有寶藍色的木皮喔!!
    馬哥,買一對吧
    希望有限量
