顯示結果從 1 到 10 共計 11 條
    預設 CHORD QBD76 數位類比轉換器
    CHORD發表新一代數位類比轉換器:QBD76,訂價英鎊3,000,除了各項技術有提升外,還支援A2DP的藍芽傳輸介面。
    特點
    ・5th generation Pulse Array:8th order noise shaping (the highest order of noise shaping of any known DAC), and 2608 times oversampling and digital filtering.
    ・new digtal PLL:Using a highly accurate 115MHz clock. Data related jitter is completely removed from the source, and you are left with just random master clock jitter of less than 3pS cycle to cycle.
    ・Addition of a display and control
    Bluetooth audio input.
    規格
    HARMONIC DISTORTION
    < -103 dB (1kHz, 24-Bit @ 44.1KHz Sample Frequency)
    < -110dB (100Hz, 24-Bit @ 44.1KHz Sample Frequency)
    SIGNAL TO NOISE RATIO > 120dB
    CHANNEL SEPARATION > 125dB @ 1KHz
    DYNAMIC RANGE 122dB
    SWITCHABLE DIGITAL
    INPUTS
    2 x 75 SP/DIF BNC Coax
    2 x AES Balanced XLR Input
    2 x Plastic fibre optic ( TOSlink )
    1 x USB ( B type )
    1 x Bluetooth supporting A2DP Stereo Audio ANALOGUE OUTPUTS
    2 X RCA Phono
    2 X BALANCED XLR
    RAM BUFFER 3 Settings – off, minimum & maximum
    PHASE SWITCH 2 Settings – Positive or Negative output phase
    SAMPLE FREQUENCIES 32KHz – 96KHz Single Cable,176KHz & 192KHz Dual Cable ( Dual data mode )
    OUTPUT MAX 6V rms. Balanced. 3V rms. unbalanced
    OUTPUT IMPEDANCE 75 (short circuit protected)
    DIMENSIONS IN MM 338 x 60 x 145mm (Width x Height x Depth)
    WEIGHT 7 Kg
    原廠網站
    www.chordelectronics.co.uk
    可接USB,那不就直接接電腦,:P
    規格
    HARMONIC DISTORTION
    DYNAMIC RANGE 122dB
    SWITCHABLE DIGITAL
    INPUTS
    1 x USB ( B type )
    2 X RCA Phono
    2 X BALANCED XLR
    這台也不錯呀
    http://www.my-hiend.com/vbb/showthread.php?t=763
    引用 作者: 臭酸石頭 查看文章
    可接USB,那不就直接接電腦,:P
    規格
    HARMONIC DISTORTION
    DYNAMIC RANGE 122dB
    SWITCHABLE DIGITAL
    INPUTS
    1 x USB ( B type )
    2 X RCA Phono
    2 X BALANCED XLR
    這篇為什麼不早點寫啊!!! 我已經買了USB DAC了.......
    慢慢來,一步一步來
    "敢"動...才會"感"動
    引用 作者: andychu 查看文章
    萬能的小朋友,肆給我神奇的力量. . .
    慢慢來,一步一步來
    "敢"動...才會"感"動
    這台大概是UAB玩家的夢幻逸品了!
    馬 馬 馬.... 馬啦 馬啦..............
    要訂一台嗎?我問代理看看
    引用 作者: sp007 查看文章
