顯示結果從 1 到 3 共計 3 條
    預設 Luxman DA-100 DAC
    Luxman發表了DA-100 DAC,訂價日幣71,400,為DA-200的精簡版,USB DAC可支援到24/96,同軸/光纖可到24/192,DAC晶片為PCM5102。
    www.luxman.co.jp
    請教版主此機是否能當純前級直接連接後級使用呢 ? 是否有遙控裝置 ? 台灣哪裡買得到 ? 以上問題 ~ 感謝 !
    音控有可能是耳機用的
    http://www.luxman.com.tw/
    ・The D/A converter of 2 compact channel PCM methods of the A5 documents size.
    ・I adopt product made in bar brown latest 32bit processing DAC tip PCM5102.
    ・I am equipped with a USB terminal (type B) and can input a USB digital audio signal from PC/Mac.
    ・The USB connection with the PC supports each OS standard driver after MacOS10 after Windows XP.
    - Product Specifications
    ■ A form: 2 channels, D/A converter
    ■ Correspondence sampling frequency:
    ・COAX/OPT input: 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
    ・USB input: 32kHz, 44.1kHz, 48kHz, each 96kHz ,※ 16 - 24bit 2ch PCM
    ■ Digital input: USB (type B), OPT, COAX
    ■ The digital output: COAX, OPT
    ■ Analog output: 1 RCA imbalance system (18mm pace), 1 headphones system
    ■ Line output voltage / impedance 2.1V/300Ω
    ■ Headphones output 130mW+130mW(600Ω), 80mW+80mW(32Ω), 40mW+40mW(16Ω)
    ■ Frequency properties: 2Hz - 60kHz (+0, -3.0dB)
    ■ Total harmonic distortion, the S/N ratio: 0.004%, 112dB
    ■ Consumption electricity 7W (the electrical equipment security method)
    ■ External form dimensions: 149(W) X 70(H) 2 ()(D)mm including front knob 14mm, back terminal 8mm)
    ■ Weight: 2.3kg
    ■ Accessories: Power supply cable
