顯示結果從 1 到 6 共計 6 條
    預設 TAD M4300、M2500 後級、C2000前級
    Balance
    In order to provide precise speaker drive to the utmost limits, TAD strives for symmetry in both circuitry and structure, with the goal of achieving perfect balance. By completely separating left and right channels from input to output, along with power supplies and transformers that are separated between both left and right channels and positive and negative rails, complete symmetry is maintained. Utilizing a bridged transformer-less design with two amps in a balanced configuration, the TAD-M4300 and TAD-M2500 deliver high output power of 300W/4ch and 500W/2ch respectively.
    Speed
    To provide an overwhelming feeling of speed and energy, the analog power supply is equipped with a high capacity toroidal power transformer and electrolytic capacitors. Combined with a Class D output stage, the result is high purity amplification with superior high speed response. For optimum sound, TAD adopted very low on-resistance power MOSFETs with no lead wires. Maintaining low heat generation thanks to the high efficiency of Class D, the amps achieve high power without heat sinks.
    Stablility
    In order to control vibration that affects the sound, the chassis is machined from a 90kg block of aluminum, effectively eliminating all joints other than connections. This helps stabilize the ground potential, further improving sound purity. It also provides both high stiffness and high internal loss, achieving improved sound quality. A three-point cast-iron insulator dampens any vibration transmitted through from the feet.
    Efficiency
    The sound quality of a Class D output stage is greatly influenced by the power source. The M4300 and M2500 are equipped with large toroidal power transformers that utilize high quality grain-oriented steel for superior magnetic saturation characteristics even during high power output. Low energy conversion loss due to the strong coupling between the primary and secondary winding of the toroidal power transformer, low load fluctuation properties based on parallel winding, along with our proprietary 33,000μF electrolytic capacitors results in an analog power supply with high drive capacity even under abrupt load fluctuations and high speed responsiveness even under abrupt load fluctuations.
    Elegance
    The precisely machined chassis is formed from a solid block of aluminum. The twin tones of silver and black for the divided upper and lower halves produces a striking appearance.The elegant clean design, extending to every detail, such as the elimination of visible front panel screws, ensures that either amplifier will harmonize beautifully with any room.
    TAD-M4300
    300 W / 4Ω, 150 W/ 8Ω(4 channels simultaneously driven, 20 Hz to 20 kHz, T.H.D., 1.0 %)
    Less than 0.05 % (20 Hz to 20 kHz, 150 W, 4Ω)
    112 dB or higher
    5 Hz to 50 kHz, -3 dB
    29.5 dB
    1.16 V/220 kΩ(Balance), 0.58 V/47 kΩ(Unbalance)
    AC 120 V, 60 Hz (USA), AC 220 V to 230 V, 50 Hz /60 Hz (Europe),
    AC 220 V to 230 V, 50 Hz (Asia)
    300 W
    Less than 0.5 W
    440 mm (W) x 170 mm (H) x 467 mm (D) (17-5/16 in. (W) x 6-5/8 in. (H) x 18-3/8 in. (D))
    43 kg (94.8 lb)
    TAD-M2500
    500 W / 4Ω, 250 W/ 8Ω(2 channels simultaneously driven, 20 Hz to 20 kHz, T.H.D., 1.0 %)
    Less than 0.05 % (20 Hz to 20 kHz, 250 W, 4Ω)
    112 dB or higher
    29.5 dB
    1.5 V/220 kΩ(Balance) 0.75 V/47 kΩ(Unbalance)
    vAC 220 V to 230 V, 50 Hz (Asia)
    250 W
    Less than 0.5 W
    43 kg (94.8 lb)
    http://tad-labs.com
    C2000前級應該也快發售了.........
    預設 TAD-C2000
    TAD-C2000
    2011年1月中旬発売 日幣1,995,000円(税込)
    入力から出力まで正負のフルバランス増幅方式を採用したプリアンプ。配線の長さを左右同一にするほか、L/Rのオーディオ回路には同じ基板ユニットを左右に配置し、入力から出力までが完全に同一となるように構成しているという。
    TADのデザインコンセプトであるシルバーとブラックのデュアルトーン筐体はアルミブロック削り出しで、外部振動に強く電気的にも安定したアース電位を得られるという。下部ケースとインシュレーター(ねずみ鋳鉄素材製)は3点の点接触構造で、下からの振動を吸収。さらに本体自体を3点のインシュレーターで支えることで、物理的な安定性を高めている。
    D/AコンバーターにはバーブラウンのPCM1794Aを採用し、192kHz/24bitまでに対応。これを左右独立配置して並列型バランス回路を構成している。また、マスタークロックはTAD-D600で開発したC/Nマスタークロック「UPCG」を搭載。サンプリングレートコンバーターでリクロックを行うことで、正確な信号再生を実現する。
    デジタル入力としてRCA、XLRに加え
    USB 2.0端子を備えたのも大きな特徴だ。こちらはUSB Audio Interface1.0規格に対応し、本機にPCを接続するだけでデジタル音源を再生できる。対応OSはWindows XP SP3以降、Mac OS 10.5以降で、USB入力は96kHz/24bitまでに対応する。
    USB入力からの音楽伝送方式には、PCのクロックジッターを除去したアシンクロナス転送方式を採用。さらに独自開発のUSB転送エンジン搭載により、送られてくる音楽データの転送制御を行うことで高音質化を実現したという。
    ボリューム回路部には、新開発の抵抗ラダー型ボリュームを採用。電気的なスイッチコントロールを行うことで、低歪率と高精度ボリューム制御を実現しているという。ファンクション切り替え操作部とボリューム操作部の軸受け部には、新開発の高精密ボールベアリングを採用。ガタつきを抑えた高精度な操作が可能だ。
    また基板には70μ銅箔厚プリント基板を採用し、基板配線における損失を低減。さらに、専用の高出力トロイダル電源トランスをアナログ部とデジタル部に配置。電源の一次回路でアナログ部とデジタル部を分離する構成にすることで、低雑音と高出力を両立したという。
    WOW!
    加上R1和那台SACD...
    嘖嘖嘖...
    明年音響展先鋒可以不用再借他牌前級了
