顯示結果從 1 到 2 共計 2 條
    預設 Yamaha A-S500 綜擴、T-S500 協調器
    A-S500 Integrated Amplifier - $449.95 (Available End of October)
    The A-S500 is designed for superb musical expression with high performance, outstanding power and sound quality combining ToP-ART technology and ART Base chassis construction with gold--plated speaker terminals and dual aluminum heat sinks and a Center Bar for crisp, clean sound. Advanced features include continuously variable loudness control, Pure Direct, along with Yamaha iPod dock connection, for endless music enjoyment options.
    Features
    * Dual aluminum-extruded heat sinks ensure effective heat dissipation and help achieve crisp, clean sound.
    * Gold-plated speaker terminals and RCA in/out jacks are durable and provide highest quality connections.
    * Center bar reinforces the internal structure to further prevent vibration from affecting the sound quality.
    * Pure Direct uses the shortest signal route for higher sound purity with low noise and transmission losses.
    * Yamaha's exclusive Continuously Variable Loudness Control for listening at low volumes.
    * The built-in iPod Dock has an independent power supply for extremely high S/N ratio.
    Specifications
    * 85W x 2 high power output
    * ToP-ART (Total Performance Anti-Resonance Technology)
    * Aluminum-extruded front panel
    * Subwoofer out
    * Speaker A, B or A+B selection
    * Rec Out selector
    * Power management (Auto power off)
    * Slim-design remote control
    * Dimensions (W x H x D): 17-1/8" x 6" x 15-1/4"
    T-S500 AM/FM Stereo Tuner - $299.95 (Available End of October)
    A user-friendly tuner that provides convenient tuning functions and a high visibility, two-line display. Uses Yamaha’s new HiFi component design that matches the A-S500 Integrated Amplifier.
    Features
    * 40-station AM/FM preset tuning
    * All 40 stations can be accessed with two turns of the rotary encoder knob, after which it stops. Favorite stations can be set at either end for greater convenience.
    * Auto FM Station Memory
    * Automatically presets the 40 strongest FM stations on the dial so you don’t have to select and preset them manually.
    * Multi-Status Station Memory
    * Thanks to Multi-Status Station Memory, each station memory includes the parameters set when it was memorized, for optimum quality each time it is selected.
    * 2-line, 16-character (5x7 dot matrix) display
    * This high and wide display offers better visibility than previous types (1-line, 11-character displays). It provides a larger amount of more precise information, making the tuning operation easier.
    * Auto search and manual tuning
    * IR Sensor on Front Panel
    * Allows the remote control from Yamaha Integrated Amplifiers (including the A-S500) to control the tuner
    www.yamaha.com
    交響情人夢最終樂章~前篇,在巴黎的房子裡,用的好像就是yamaha前一代的綜擴+yamaha的喇叭
