PMC TB2i、FB1i Signature Loudspeakers
PMC TB2i Signature Loudspeakers
£1375.00
Product Information
The TB2i has received accolades from all corners of the world and is viewed as the benchmark in the realm of the audiophile. In celebration of ten years production of this ‘audio classic’ this limited edition signature models has been conceived.
Dubbed the Signature model, it display all the ultra high definition and finesse of the current i series design with added refinement and transparency in the mid, vocal range. The key to this enhancement is the fine tuning to the crossover networks which has been carried out Peter Thomas himself - designer and founder of PMC.
Such is the confidence in build quality and engineering excellence the warranty period has been doubled to match the ten phenomenally successful years since their launch.
The beautifully handcrafted British cabinets are finished in the distinct and rare Rose Palissandre veneer. A chic enhancement for any modern or traditional interior.
The exclusive, limited edition models include:
* PMC ATL™ (Advanced Transmission Line)
* PMC/SEAS®, 27mm SOLONEX™ soft dome tweeter, ferro fluid cooled
* PMC designed 170mm Doped LF driver with cast magnesium chassis
* Improved vocal transparency over standard iseries
* 10 year extended warranty
* Luxury Rose Palissandre finish
* Hand signed certificate from Peter Thomas, designer & founder
* Brush aluminum serial number plate & nickel fixings
The TB uses the professionally proven six and half inch bass unit and the precision built SOLONEX™ domed tweeter which results is a vast, vivid audio picture and deep rich bass which can be experienced throughout the room.
Specifications TB2i Signature
Freq response 40Hz-25kHz
Sensitivity 90dB 1w 1m
Effective ATL™
(Advanced Transmission Line) 1.5m 5ft Length
Drive Units LF - PMC, 6.5” Doped with cast Alloy Chassis
HF - 27mm SOLONEX™ Soft dome Ferro-fluid cooled
Crossover Freq 2 kHz
Input connectors 2 pairs 4mm sockets
Dimensions H 400mm 15.75"
W 200mm 7.87"
D 300mm 11.81" + grille
Weight 8.5kg 18.70 lbs
Finish Rose Palissandre
PMC FB1i Signature Loudspeakers
£2502.50
Product Information
The FB1i has received accolades from all corners of the world and is viewed as the benchmark in the realm of the audiophile. In celebration of ten years production of this ‘audio classic’ this limited edition signature models has been conceived.
The FB uses the professionally proven six and half inch bass unit and the precision built SOLONEX™ domed tweeter which results is a vast, vivid audio picture and deep rich bass which can be experienced throughout the room. The FB1i Signature’s longer ATL™ (Advanced Transmission Line) it provides even greater bass extension and therefore has the ability to fill a larger listening room with aplomb.
Specifications FB1i Signature
Freq response 28Hz-25kHz
Effective ATL™
(Advanced Transmission Line) 3.0m 9.8ft Length
Drive Units LF - PMC, 6.5” Doped with cast Alloy Chassis HF - 27mm SOLONEX™ Soft dome Ferro-fluid cooled
Dimensions
H 1000mm 39.37" + Plinth
W 200mm 7.87" + Plinth
D 300mm 11.81" + Plinth
Weight 17kg 37.40 lbs
www.pmc-speakers.com
