顯示結果從 1 到 10 共計 19 條
    預設 Verity Audio Monsalvat
    USD 325,000
    2011 發表
    System description:
    Monsalvat complex system consisting of two main buildings . The system includes two separate bass case and a unique crossover. Active crossover must be installed between your preamp and amplifier. The system includes six separate channels of amplification. Our study showed that strengthening the system of columns, the best results are achieved when the entire system increases one unit , so bass unit Monsalvat has no built-in amplifier . The user can select the type and number of amplifiers.
    ・Housing system:
    Shells are composed of two different modules : the medium - high-frequency module and a
    bass module. These two sections together to create a column height of approximately as
    Lohengrin II. At the same time , the depth of columns exceeds the size of Lohengrin II and to
    the rear , they are dwindling. Thus improved performance surround sound . For the stability of
    the column are fixed on solid aluminum base with the possibility of adjustments .
    ・Medium and high frequencies :
    In this unit consists of two dynamics: tweeter and midrange speaker . Twitter production
    Verity with a range of 6-60 kHz , mid range is based on the dynamics of Sarastro II. The
    difference in sensitivity : Sarastro II has a rate of 93 dB 1w/1m, Monsalvat has a sensitivity of
    99 dB 1w/1m, made possible by hard work .
    ・Bass / midrange drivers :
    Speakers for midvufera frequencies identical Lohengrin II. Their overall sensitivity equals
    average sensitivity of the speakers at high frequencies. Range of 60-500 Hz. Modules are very
    powerful , their combined use provides a very powerful sound with minimal distortion and
    displacements.
    Tower woofers ( bass part ):
    Each of the towers vufernyh Monsalvat vufernymi with 4 modules . Each of them is equipped
    with a 15 inch speaker , identical Lohengrin II. These modules are designed for installation in
    front of the room , the sound is spread throughout space . So they can be positioned
    horizontally in front of the angle of the wall and floor. Modules are very powerful , their
    combined use provides a very powerful sound with minimal distortion. These modules cover a
    range of 15-60 Hz.
    ・Active crossover:
    Experience with digital crossovers shown us that this type of device is not transparent sound .
    That's why we Monsalvat ispolschuem exclusively analog filters . At the same time, we have developed high-precision digital delay circuit for the entire system, effectively and accurately a harmonizing sound. The system uses the delay AD and DA converters , as well as the repository of memory. As a result , we have an active crossover system with a completely transparent sound.
    www.verityaudio.com
    哇...怪獸..
    主要的音箱這麼深了
    還加低音柱
    不打到吐血才怪
    讚讚讚
    USD 325,000
    看來口袋也要很深...
  5. #4
    不是猛龍不過江,一出手就知道厲害,代理商應該很興奮
  6. #5
    國外訂價大約1000萬台幣...四件式不算高價的吧....台灣會訂多少呢?
  7. #6
    Verity Audio 多件式超級旗艦(inlove)代理商正在橋
    音逸音響
    www.fineaudio.com.tw/news.htm
    電話:(02)2381-0586
    行動:0918-058 031
    一~五:中午1:00 ─ 晚8:00
    週 六 :中午2:00 ─ 晚6:00
  8. #7
    巨獸~~~~~~~:O:P效率有99db~~~~~:O
  9. #8
    太威了.....32萬....
    很有趣的是,圖片的意思是低音要靠牆角擺!?
  10. #9
    有钱人的大玩具,全套设备没有3000万台币估计是搞不定,再加上豪宅,吓死人
  11. #10
