第1頁,共4頁 123 ... 最後最後
顯示結果從 1 到 10 共計 40 條
    原来对usb接口有怀疑.看了此篇吃螃蟹的介绍,算是有些打消. 会是高C/P的hi-end发展趋势... ... 听过较好的数码母带重播,更丰满更鲜活的音乐.自然使你对脱水减肥后的CD骨感美女会产生厌情... ... 谢谢推介!
    預設 建議一下
    小葉您可以試試
    找一台電腦把不用的清一清
    把會振動的移出電腦
    風扇全拿掉
    您絕對會嚇一跳
    差很多
    在高sir那領較過厲害,感謝寶貴的提醒
    Charles Hansen 8月份在討論區回覆升級的部份,基本上要等新的晶片,且出來後升級價不會太貴
    This will require a hardware upgrade. The TAS1020B used as the USB receiver chip is only capabole of USB 1.1. Texas Instruments was planning to make an upgraded pin-compatible part with USB 2.0 capability, but the economic slump jammed a wrench into the works on that one.
    So a hardware upgrade will be required. Specifically, the USB input receiver is on a separate PC board, which minimizes the cost of this upgrade. Beyond that I don't have any details because the upgrade doesn't exist yet. I am estimating that it will be available around the end of the year, but that is just a rough guess. As far as cost, I am sure that it will be less than 10% of the price of the unit.
    And don't forget that only Mac OS X supports the Class 2 Audio spec at this point. The initial release of Windows 7 will not, although I would guess that a Service Pack will address this in another year or so.
    Another problem is finding high-sample rate source material.
    http://www.audioasylum.com/forums/hi...26/260859.html
    不知道有人有用過pacemaker當做數位訊源嗎
    感覺很不錯
    http://www.pacemaker.net/Default.aspx
    想買來接再DAC
    效果不知與MAC比起來如何
    酷是酷,但沒寫出取樣頻率可支援到那
    再來好像是DJ玩的?
    請問能否直接播放USB隨身碟24/96的音樂檔案?
    不行..............介面不一樣
    要透過電腦
    USB port有兩種
    一種是USB port純讀檔案,無DAC
    一種是USB port有DAC chip
    Ayre是USB DAC,一定要透過電腦,要讀隨身碟音樂檔也是要透過電腦,一樣可到24/96
