顯示結果從 1 到 2 共計 2 條
    預設 SME M2-12R 唱臂
    SME 新的唱臂M2-12R訂價約日幣367,500,12"的設計,擁有低循軌誤差,型狀為"j",搭配S2-R可拆的鋁製唱頭蓋,並可調方位角(Azimuth),兩段的鎢製平衡錘系統。
    特點
    * The 12in construction with thin walled stainless steel tone-arm takes advantage of the reduction in maximum tracking error/distortion afforded by the greater arm length when compared with 9in models.
    * S2-R Aluminum shell detachable and interchangeable without disturbing cartridge or wiring.
    * Double draw-in pin bayonet fitting design ensures a rigid junction with the tone-arm.
    * Unique headshell to tone-arm coupling readily allows cartridge azimuth adjustment.
    * Internal constrained layer damps minute residual vibrations making tone-arm acoustically inert.
    * Stainless steel cross shaft, ground and thread ground. Carried in a substantial yoke on 10mm precision ball races.
    * Stainless steel vertical shaft, ground and thread ground, with integral 16mm diameter flange to couple shaft and yoke.
    * 23mm diameter steel pillar, heat treated, ground and honed, carries two 17mm precision ball races, widely spaced to resist tilt.
    * Anti-skate control operates through Anti-Skate weight and filament, adjustable up to 5g VTF.
    * Lowering/raising control gives smooth positive action. Height of lift can be adjusted.
    * Thumbwheel (Vertical tracking angle VTA) height adjustment.
    * Bedplate affords +/- 12.0mm movement to facilitate (Horizontal tracking angle HTA) adjustment.
    * Base slides on bedplate for horizontal tracking adjustment with double null-point protractor.
    * Tungsten-alloy balance weight inserts allow maximum centre of gravity shift to balance a greater range of cartridges up to 38g in S2-R headshell and direct plug-in heads up to 46g.
    * Precise vertical tracking force up to 5g applied in 0,5g increments via rider weight and graduated wayrod.
    * Fluid damper FD-M2 is available as an optional extra.
    * Alignment protractor designed to provide HTA settings with the greatest accuracy.
    * Internal wiring in LCOFC.
    www.sme.ltd.uk
    預設 SME M2-12R 唱臂
    12吋臂不錯
    像SME 3012R 的改款
    不過搭配的唱盤倒是要大一號
    佔據了不小的擺設空間
    找一找空盤......
    音逸音響
    www.fineaudio.com.tw/news.htm
    電話:(02)2381-0586
    行動:0918-058 031
    一~五:中午1:00 ─ 晚8:00
    週 六 :中午2:00 ─ 晚6:00
