顯示結果從 1 到 7 共計 7 條
    預設 Esoteric兩款新電源線
    Esoteric發表了兩款新的Stressfree電源線:7N-PC7300、6N-PC5300,1.5M訂價分別為日幣231,000與103,950,11月中、下旬上市。7N為99.99999%、6N為99.99997%的高純度銅,銅來自於Mitsubishi Cable Industries。電源公母頭外殼一樣使用了Carbon Fiber,端子為鈹銅(Beryllium Copper)合金或磷青銅合金(Phosphor Bronze)鍍上厚金。
    7N-PC7300
    ● Conductors: Stressfree 7N copper × 2 (core wire: 0.26φ × 100 suit strand), 4.5N Super anneal copper × 1 (core wire: 0.26φ × 100 suit strand) ● Insulation: Polyolefin polymer ● Shield: Polyurethane Braid coated copper wire (4N) + copper Mairatepu ● Structure: three-core stranded structure ● inner sheath: polyolefin hybrid polymer (powder mixing tungsten + carbon powder amorphous + VAT) ● External sheath: UV-resistant polyurethane ● Plug Power: Special beryllium copper Daburubafu (mirror) processing (0.5μ plated palladium platinum plating +0.3 μ) ● IEC connectors: beryllium copper special (0.5μ plated palladium platinum plating +0.3 μ) ● Cable diameter: about 16mm ± 0.3
    6N-PC5300
    ● Conductors: Stressfree 6N copper × 2 (core wire: 0.26φ × 100 suit strand), 4.5N Super anneal copper × 1 (core wire: 0.26φ × 100 suit strand) ● Insulation: Polyolefin polymer ● Shield: Mylar copper Tape ● Structure: three-core stranded structure ● inner sheath: polyolefin polymer sheath ● Exterior: UV-resistant polyurethane ● Plug Power: Daburubafu special phosphor bronze (mirror) processing (24K thick plated palladium plating Kon Tadashi +) ● IEC connector: Special phosphor bronze (thickness Kon Tadashi + plated palladium-plated 24K) ● Cable diameter: about 16mm
    www.esoteric.jp
    如果銅來自於Mitsubishi Cable Industries應該是Mitsubishi在2009得AEx獎的D.U.C.C.導體了.
    7N-PC7300這條很有質感的樣子!!:*
    引用 作者: 將軍 查看文章
    跟之前的7N-PC7100 幾乎一樣,初步看它的規格應該一樣,只是價格提高一些罷了.
    引用 作者: nanshinco 查看文章
    日幣231,000...的確價格是提高了一些.
    銅純度佳是好事,這是線材必備之一,其它因素也是很重要的.
    功成何必在我
    功成不必在我
    功成之日
    離開之時
    Esoteric Mexcel
    Power Cable
    Stressfree
    7N-PC9300 MEXCEL
    日幣 367,500
    2010年3月上旬發售
    限量350條
