			 AUDIO-TECHNICA ATH-W1000X、ATH-ES10、ATH-WS70、HP-PRO700 GD
					AUDIO-TECHNICA一次發表了四款耳機
 ATH-W1000X
 W系列的第10代產品,訂價約日幣71,400
 Type: Closed dynamic type、Driver: φ53mm, 6N-OFC voice coil、output sound pressure level: 100dB/mW、Playback frequency: 5 ~ 42,000 Hz、Maximum input: 2,000 mW、Impedance: 42Ω、Weight: 350g (excluding code)
 ATH-ES10
 訂價約日幣47,250
 Type: Closed dynamic type、Driver: φ53mm, OFC voice coil bobbin、output sound pressure level: 102dB/mW、Playback frequency: 5 ~ 40,000 Hz、Maximum input: 2,000 mW、Impedance: 42Ω、Weight: 200g (excluding code)
 ATH-WS70
 訂價約日幣12,600
 Type: Closed dynamic type、Driver: φ40mm、output sound pressure level: 100dB/mW、Playback frequency: 10 ~ 25,000 Hz、Maximum input: 1,000 mW、Impedance: 47Ω、Weight: 230g (excluding code)
 ATH-PRO700 GD
 限量5000支,訂價約日幣16,680
 Type: Closed dynamic type、Driver: φ53mm、output sound pressure level: 105dB/mW、Playback frequency: 5 ~ 33,000 Hz、Maximum input: 3,500 mW、Impedance: 36Ω 、Weight: Approximately 340g (excluding code)
 www.audio-technica.co.jp
		您不可以發表新主題您不可以發表回覆您不可以上傳附件您不可以編輯自己的文章  討論區規則 |
