顯示結果從 1 到 3 共計 3 條
    預設 Chord CYAN Click
    Chord發表了一台全新概念的產品:CYAN Click,售價未知,其體積不比QBD76大,其卻是一台綜合擴大機與DAC,有數位及類比輸入,並支援Chord獨特的無線藍芽數位傳輸(A2DP)。為了能推動更大的喇叭,Cyan Click有兩個輸出的版本可供選擇,不過都一樣使用high frequency power supplies。類比有XLR或RCA輸入,可同時使用。數位輸入則有BNC coax、TOSLink或USB。
    Pre-Amp Section
    Unbalanced Input: 1 pair RCA phono
    Balanced Inputs: 1 pair of 3-pin female XLR inputs
    Digital Inputs: Coax BNC, TOSLink Optical, B type USB
    Wireless Input: Bluetooth A2DP
    Signal to Noise Ratio: -90dB all inputs
    Frequency Range: 2.5Hz – 200kHz (-3dB)
    Harmonic Distortion: 10 Hz –91dB, 1kHz –93dB, 10kHz –90dB, 20kHz –87dB
    Channel Separation: 10 Hz 90dB, 1kHz 90dB, 10kHz 90dB, 20kHz 85dB
    Channel Balance: 0.01dB
    Input impedance: Unbalanced 47kOhms, Balanced 94kOhms (Line 1 & Line 2)
    Power Amp Section
    Output Power 90 rms per channel @ 0.05% distortion into 8 Ohms
    ( High Power Version ): 120Wrms per channel into 4 Ohms
    Output Power 50 rms per channel @ 0.05% distortion into 8 Ohms
    ( Low Power Version ): 65Wrms per channel into 4 Ohms
    Frequency Response: -1dB, 0.8Hz to 46kHz (8 Ohms)
    -3dB, 0.8Hz to 77kHz (8 Ohms)
    -1dB, 0.8Hz to 39kHz (4 Ohms)
    -3dB, 0.8Hz to 75kHz (4 Ohms)
    Signal To Noise Ratio: Better than –103dB, ‘A’ weighted two thirds
    Channel Separation: -80dB
    Output Impedance: 0.03 Ohms
    Output Inductance: 2.6mH
    Output Connections: 2 x rhodium binding posts
    Slew rate: 70V per S, 1kHz 20V square wave
    Gain: 30dB
    Stability: Unconditional
    Dimensions: 338 x 60 x 145mm (Width x Height x Depth)
    Weight: 7Kg
    PDF
    www.chordelectronics.co.uk
    預設 沒開蓋的cyan Click
    葉大,怎麼這次看不到內容物啊!!!!!!!!!!!!:O:P
