Marantz發表了SA-13S2 CD/SACD唱盤,訂價日幣262,500,預計5月底上市。箱體上方鋁板厚5mm,跟SA-11S2一樣,傳動系統為SACDM-10,其下方有2mm厚的鋼版固定,電源採用環型變壓器,並加以密封隔離,類比輸出使用HDAM-SA2模組,與SA-7S1相同。後方有光纖輸入,可當DAC使用,並支援32/44.1/48/88.2/96KHz的輸出。SA-KI-Pearl則為週年紀念版本。
<SACD部>
Frequency Range: 2Hz ~ 100kHz
Frequency Response: 2Hz ~ 50kHz (-3dB)
Dynamic range: 112dB
rate of harmonic distortion (1kHz): 0.001%
<CD部>
Frequency Range: 2Hz ~ 20kHz
Frequency Response: 2Hz ~ 20kHz
Dynamic range: 100dB
rate than harmonic distortion (1kHz): 0.0015%
<Overall>
Power consumption: 20W
Dimensions: 440W × 127H × 419Dmm
Weight: 14.5kg
www.marantz.jp
