顯示結果從 1 到 9 共計 9 條
    預設 Porsche與Burmester合作
    新的Porsche Panamera將配載著Burmester High-End系統。
    特點
    ‧使用16的聲道獨立的擴大機,總共超過1,000W (16 separate amplifier channels with an overall rated output power of more than 1000 watts)
    ‧16顆單體振膜面積超過2,400cm2 (a record-breaking total diaphragm area of 2,400 cm2 distributed to 16 loudspeakers that were especially designed for the Panamera, are the foundation and requirement for the distinctive Burmester sound.)
    ‧很輕 (the sound system has a remarkably low total weight.)
    ‧單體、分音器與絲帶高音為Burmester高等級產品的直接移植,汽車上首見 (The loudspeaker cones, the crossover network technology, and the ribbon tweeter (Air Motion Transformer, AMT), characteristic traits of Burmester loudspeakers, are directly transferred from the High End Home Audio division. In this particular form, they are displayed in a production vehicle for the first time.)
    ‧特別設計的軟體可針對座位位置最佳化 (Specially developed software-supported menu functions allow an exact sound-adjustment for each individual seating position. They compensate cabin noise and can be intuitively operated with comfort and ease. In conjunction with the sound-algorithms, exclusively developed for Porsche)
    PDF下載
    Burmester
    www.burmester.de
    Porsche
    www.porsche.com
    勝旗 (Burmester代理)
    www.winkey-audio.com.tw
    近年來高級車流行跟音響大廠掛勾, Porsche 也趕流行啊...
    以“保时捷”的脾性,应该和AUDIONET更合拍些!
    呵呵,這個應該由上海的AUDIONET達人Jacklu866兄來形容更合適些。。。
    他今天去杭州看書了...(mm)(mm)(mm)
    引用 作者: affeii 查看文章
