第16頁,共31頁 第一第一 ... 6141516171826 ... 最後最後
顯示結果從 151 到 160 共計 302 條
主題: 音響兩三事
  1. #151
    Purist HDR6-DA
    Designet i samarbeid med Hush Tech.
    €16000 inkl BD og 2 TB intern harddisk.
    Unterstütze Sampling-Frequenz (PCM) 10kHz bis 200kHz
    Bitrate / Auflösung (PCM) 16 bis 24 Bit
    Datenübertragung intern 2,5Gb/s ASIO Interface Studio-Standard
    Übertragungsbandbreite pro Kanal DC(0Hz)-100kHz
    Rauschabstand > 120dB
    Jitter durch Re-Clocking < 150ps
    Kanaltrennung > 135dB
    Digital-Out AES/EBU XLR
    Digital-In AES/EBU XLR
    Clock-Master In BNC
    Clock-Master Out BNC
    Analog-Out XLR stereo
    Analog-Out Cinch stereo
    Massives aus einem Stück gefrästes HF geschirmtes 6- Kammer Aluminium Gehäuse"
  2. #152
    這台也在慕尼黑看過,感覺也像電腦優化
  3. #153
    Raysonic
    Quartet Tube Integrated Amp, Tuner, CD Player, iPod ML-6
  4. #154
  5. #155
    日本味十足的器材,但猜猜看是那一國的?
    http://www.musical-laboratory.com
    質感不錯
    原廠網頁寫的是"韓國":O:O:O
  6. #156
  7. #157
    ECR 1 FM/RDS/DAB/Internet Radio with Balanced Output
    May 18th 2009
    Electrocompaniet is proud to introduce our new ECR 1 Tuner. This model has been developed to extend the Electrocompaniet product range with a long awaited FM/RDS/DAB/Internet radio.
    With the ECR 1 our customers can finally compliment their system with high-end radio reception in a design matching the rest of their Electrocompaniet equipment. It also includes RDS (Radio Data System) for viewing your favourite stations call letters and music material that they are broadcasting.
    A fully fledged 192kHz/24bit DAC section including sample rate converter is included to handle the delicate digital to analogue conversion of the digital radio. Three digital inputs are also provided letting the ECR 1 be used as a stand alone high-end external DAC. This means that through the S/PDIF interface you can connect your CD/DVD player to our new ECR 1 model.
    Optional plug-in modules are available to include DAB and/or internet radio, a USB interface will also be made available.
    Fully balanced
    Like all other models in our Classic line the ECR 1 features a fully balanced and symmetrical analogue output section, terminated in a balanced and single-ended output connection.
    Made in Norway
    www.electrocompaniet.no
  8. #158
    Boulde 1008 Phono Preamplifier
    USD 12,000
    Discrete first gain stage for lowest noise possible in any transformerless electronics.
    Two inputs for multiple turntables or tonearms.
    Cartridge Personality Card for each input to adjust loading and gain.
    Two pairs of output connectors.
    Low cut filter.
    Dual mono construction
  9. #159
  10. #160
