OPPO HA-2 隨身型 DAC/耳擴
OPPO日前推出隨身型DAC/耳擴,繼多功能的強力HA-1的桌上型DAC/耳擴/前級後推出的HA-2在本質上和HA-1有很大的差異,雖然說型號上只是數字不同,但是產品的訴求並不相同。
兩者都是具有DAC的耳擴,HA-1目標是讓入門發燒友有一個多功能的選擇,HA-1不但具有強力的耳擴推力,還配置可以解碼DSD 256的高規格DAC,更能夠擔綱兩聲道系統中的前級擴大機工作,各種功能可以說是一應俱全,買一抵三。
HA-2就單純很多了,雖然在DAC和耳擴上看起來功能是一樣的,但是HA-2完全是以隨身攜帶為導向,而且老實說,外觀上HA-2比起HA-1較為功能型的外表精緻時尚了非常多,設計不但輕薄很有質感,而且和其他隨身DAC耳擴的外觀有不小差異,攜帶HA-2搭配各樣訊源如蘋果手機或是各個時尚耳機都毫不遜色。
OPPO HA-2 基本規格介紹:
HA-2是一款高解析的USB DAC for apple/android/MAC/PC,採用ESS Sabre32參考級ES9018-K2M DAC晶片,可解碼32bit/384kHz的PCM檔案和DSD 256的音樂檔案,內部的耳機擴大電路採用AB類擴大,有兩種增益模式可供切換以搭配各式耳機,可充當行動電源為手機充電。
輸入端有一個3.5mm的類比輸入,數位輸入有一個USB for iOS裝置,另一個USB micro-B給使用USB OTG的其他智慧型手機和電腦。輸出端為一個3.5mm的耳機輸出,和一個3.5mm的線級輸出(line-out)。
General Dimensions (W x H x D) 2.5 x 6.2 x 0.5 inches, 68 x 157 x 12 mm Weight 6.2 oz, 175 grams Frequency Response 20 Hz - 200 kHz Audio-in Level 1 Vrms Line-out Level 1 Vrms Recommended Headphone Impedance 16 Ohm - 300 Ohm Maximum Headphone Output Power 300 mW into 16 Ohm
220 mW into 32 Ohm
30 mW into 300 OhmOutput Jacks 3.5 mm stereo headphone
3.5 mm stereo line-outInput Ports Analog: 3.5 mm stereo audio-in
Digital: USB A for iPod / iPhone / iPad; USB micro-B for smartphones with USB OTG feature and computers.DAC Chip ESS Sabre32 Reference ES9018-K2M Input Format Stereo PCM, Stereo DSD (DoP v1.1 or native) PCM Sampling Frequencies 44.1 kHz - 384 kHz, 16 / 24 / 32-bit DSD Sampling Frequencies 2.8224 MHz (DSD64), 5.6448 MHz (DSD128), 11.2896 MHz (DSD256, native mode only) Profile USB 2.0, USB Audio 2.0 Included Accessories Power Supply Unit (Rapid Charging Charger)
USB A - USB micro-B data and rapid charging cable
USB A - Lightning data cable (for Apple devices)
USB micro-B to micro-B data cable (for Android and other smartphones)
3.5 mm - 3.5 mm stereo audio cable
Silicone rubber band (2 pieces)
User guide and warranty documentsBattery Built-in Battery type 3000 mAh lithium polymer rechargeable battery Battery Operation Time Approx. 13 hours for analog source via Audio-in; approx. 7 hours for digital sources via USB Charging Time Approx. 1 hour 30 minutes
開箱照片:
OPPO HA-2的包裝非常簡潔俐落,外盒可以清楚看到產品的寫真,右上角標示著高解析音樂。
在外盒的後方除了有規格圖以外,更清楚說明每個部位的中文使用說明,即便是沒使用過相關產品的朋友也能很快看懂。
在外盒的側面有更進一步的規格解說,包含了產品特點和能夠對應的音樂檔案。
拿掉外盒後,內部還有一個非常堅固的箱盒保護HA-2。
打開上蓋,可以看到HA-2很安穩地躺在裡面,右方有個簡單的HA-2字樣。
仔細看一下,HA-2的主體都幾乎用皮革包覆,上面有漂亮乾淨的縫線,露出的部分都是鋁合金製的,既低調又吸睛,帶出門如果朋友注意到,肯定會好奇這到底是手機還是筆記本。
側面的部分是音量旋鈕,外觀一樣是鋁製。
側面除了電源外,還有可以增加低音量感的切換鈕,以及搭配不同耳機需要用到的增益切換LOW和HIGH。
在頂端就是輸出端,耳機輸出和線級輸出在此,皆為3.5mm,另外line-out的3.5mm也同時可當作Audio-in的輸入端,使用不同的輸入時,要記得在底部的輸入源檔次做切換。
底部則是兩個USB數位輸入插槽,左方有輸入源檔次的切換。
開啟時會有燈號顯示內部電池的剩餘電量。
需要的配線和線材都有附贈,包含了充電插頭,每一個配件上都有打上OPPO的字樣,另外還有兩條收納線用的橡皮束帶。
OPPO DIGITAL: https://www.oppodigital.com/
