第3頁,共14頁 第一第一 1234513 ... 最後最後
顯示結果從 21 到 30 共計 138 條
    引用 作者: drkao 查看文章
    在接觸CAT之前
    說什麼我都不會相信我上一篇所說的
    Berkeley Audio Alpha USB我曾經試用過
    Berkeley Audio Alpha DAC我用過一段很長時間
    問題在DAC哪知道哪個是雜訊
    哪個該濾哪個不該濾
    許多高階DAC有FILTER的功能
    我發現FILTER越少越好聽
    FILTER太強聲音就呆掉了
    還有
    我喜歡關掉over- & up-sampling
    這些運算常讓聲音變得超不自然
    Berkeley Audio 的網站特別強調兩點:
    1. 他們輸出段的電源是獨立的, 不是電腦來旳, 想當然爾。
    http://www.berkeleyaudiodesign.com/alpha-usb/
    Great care was taken in the design of the Alpha USB to isolate the noisy computer/USB environment from the digital audio output. The USB receiver and processing are powered by the computer, while the output master clocks and line drivers are powered by a separate isolated linear power supply. Two key factors combine to achieve the excellent audio performance of the Alpha USB - the unprecedented degree of electrical isolation between the USB input connection and the audio output and the very low noise/low jitter performance of the individually tested audio output master clocks
    2. 他們的跟輸出之間有絶佳的雜訉隔離, 用的應該是先進的 isolation transformer, 在這個網頁中有介詔。
    http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/15-universal-serial-bus-industry-standard-cables-connectors-and-communications-protocols-between-computers-and-electronic-devices-spdif-converters-shootout-15327/
    The 'dirty' and 'clean' sides are both isolated by a chip. The lettering on the chip was removed, but I’m pretty sure this is the ADuM* chip, isolating the I2S lines between the XMOS chip and the SPDIF output.
    *The ADuM chips are digital isolators based on the Analog Devices, Inc., iCoupler® technology. Combining high speed CMOS and monolithic transformer technologies, these isolation components provide outstanding performance characteristics superior to alternatives, such as optocouplers.
    我剛好有一台 REGA DAC 他們用的也是 isolation transformer,
    http://www.rega.co.uk/dac-r-1.html
    The USB input stage is comprised of a bit perfect XMOS USB Audio 2.0
    with asynchronous clocking. The USB input stage feeds the Optical and
    Coaxial input stage via an isolating transformer giving total isolation from
    the host computer.
    REGA 有不同的的 filters 可以選,這是在隔絕訉源雜訉之後在 Digital Domain 做的調整,照他們説聽感會不一樣, Stereophile review 有一些介紹
    http://www.stereophile.com/content/rega-dac-da-processor-page-2
    此篇文章於 2015-01-13 03:15 PM 被 SGIREM463 編輯。
  2. The Following 2 Users Say Thank You to SGIREM463 For This Useful Post:
  3. #22
    https://www.dropbox.com/sh/jmt5zxisy...GD8yQb2Da?dl=0
    唱臂升級後
    趁機將唱盤重新調整一次
    聲音大幅提升
    整個頻寬完整後
    也調整了唱放阻抗設定
    也改善左右些許不平衡
    重新錄一次
    我有聽一下錄下來的聲音
    比之前好很多
  4. The Following 3 Users Say Thank You to drkao For This Useful Post:
  5. #23
    之前po錯地方.再po一次,謝謝高醫師的園地!
    大家如果不嫌棄,我用LP轉錄了一段波里尼的貝多芬第32號鋼琴奏鳴曲(約2分鐘)的DSD 5.6檔案給大家下載(171.9M),
    請各位大大不吝指教:https://copy.com/fAyKzLHlnKeh207A
    Allen
  6. The Following User Says Thank You to allentube211 For This Useful Post:
  7. #24
    剛剛下載了高醫師6個小時前renew的1.wav, 秀出24bit/96k錄製,鋼琴的聲音極其自然,第6分鐘過後的強奏也是衝擊力與清晰度具足,果然是高手中的高手,太棒了,再來去下載其他的檔案!!謝謝高醫師~~Allen
  8. #25
    引用 作者: drkao 查看文章
    唱臂升級後
    趁機將唱盤重新調整一次
    聲音大幅提升
    整個頻寬完整後
    也調整了唱放阻抗設定
    也改善左右些許不平衡
    重新錄一次
    我有聽一下錄下來的聲音
    比之前好很多
    謝謝高醫師。我在聽1.wav這個檔案的時候,在6:10開始有爆音。不知道是我的MacMini+Vox(software player)+GeekOut 450 (DAC) + Sony MDR V-6被殺了?還是檔案本身就有爆音?
  9. #26
    引用 作者: allentube211 查看文章
    Allen
    不好意思
    我的CAT完全無法播放DSD
    抱歉
  10. #27
    有兩張黑膠非常考驗校調功力
    一張是這個SARASTRO的唱片
    他們家都是45轉
    中等難度
    另一張是大名鼎鼎的HOROWITZ in MOSKOW
    A面最後一軌
    超高難度
    曾經調到完美過
    但是螺絲一緊它就不見了
    而且再也找不到
    這是要靠緣分及機緣
    這個爆音是循軌異常
    目前是最佳狀況
    或許有一天可以調到完美
    會傳上來
    現在就只有這樣
  11. The Following User Says Thank You to drkao For This Useful Post:
  12. #28
    謝謝!我還以為我在辦公室聽音樂的設備被宰了!
    除了這個爆音之外,其它真的錄得很好。鋼琴的尾音都很穩。我知道您以前是用Goldmund的唱盤和正切唱臂, 但是後來升級了。請問您這是用的什麼唱臂?
    此篇文章於 2015-02-07 08:59 AM 被 kevintran 編輯。
  13. #29
    THALES 筷子II
  14. The Following User Says Thank You to drkao For This Useful Post:
  15. #30
    引用 作者: drkao 查看文章
    唱臂升級後
    趁機將唱盤重新調整一次
    聲音大幅提升
    整個頻寬完整後
    也調整了唱放阻抗設定
    也改善左右些許不平衡
    重新錄一次
    我有聽一下錄下來的聲音
    比之前好很多
    再上傳一張
