第124頁,共274頁 第一第一 ... 2474114122123124125126134174224 ... 最後最後
顯示結果從 1,231 到 1,240 共計 2737 條
  1. #1231
    The Lava Ultramafic
    極致透澈的鍍銀導線
    材質.....聲音的基礎
  2. The Following User Says Thank You to liukuang For This Useful Post:
  3. #1232
    引用 作者: 999369 查看文章
    音響一時還無法動工[電源及Amp電源線]Amp電源線有一條要拆了重新做,先把吉他音箱接上了好練琴
    天天沒事作今天把這喇叭箱打開。
    總是覺得音不均衡[中頻不好],內部線材也加強一下
    拆~~~~~
  4. #1233
    這喇叭箱可打開背面中間的板[開放式或閉封式]
    背景亂隨意照的~~~~
  5. #1234
    背板拆下耳朵靠近內箱聽到很清楚 低頻內部反射嗡聲[早晨涼快房間開了兩部風扇一台抽風一台送風]
    所以反射音問題是一定存在的。
    這箱做的是算紮實 但實說並不算是好的吉他用音箱,沒有了木箱共鳴的音[原木箱更隹]
  6. #1235
    為了可用不同輸入方式[雙單聲道方式及雙喇叭並聯單聲道方式]有了輸入線路板[音質會損失一些]
  7. #1236
    Custom Tele 今天看到這支琴不錯[又便宜]
    這型一直想收一支
    I have here a really Sweet custom Tele using all high end parts, the body is a B-Hefner vintage specs, the neck is from a Fender American Vintage 1952 Reissue 1993 Hector Montes who use to do necks for Fenders custom shop (Google it), it has been refretted with medium jumbo frets and refinished in Nitro with a bone nut, I am not sure of the finish on the body? I don't think that it is nitro but it is thin and looks real nice with the grain showing through, pickups are Rio Grande and sound amazing, this Tele was just recently set up by Dan's Guitar so you know that it plays like a million bucks, it has no play wear, it plays sounds and feels amazing, the weight is around 7 to 7 1/2 lbs
  8. #1237
    在家自拍的還不錯吧!在朋友店試了音不錯清鬆好聽
  9. #1238
    Swamp Ash琴身?
  10. #1239
    引用 作者: DeadHeart 查看文章
    Swamp Ash琴身
    這我就不知道了
    賣琴的人專愛自組仿古的電吉他,也買進賣出不少好吉他音箱。
    這把琴也算是組合起來的[便宜],但我看琴頸不錯,琴身也是一体原木[高硬度]。
    Tel琴一直想多收一把所以就正好選用這把。
    昨晚花了5_6小時全拆了全部整理過了,很多DIY的人組裝的很差這把也是。
    這把琴算是不錯的音可贏過Fender Tel~千多美元的吉他,昨夜又試了可說是非常滿意。
    $550美元 賣方說他花了近一千美元組合的
  11. #1240
    預設 Victoria Silver Sonic Amp
    20 watts of power
    -Classic 5F6-A architecture
    -100% tube reverb and harmonic filter vibrato
    -1XGZ-34, 2 X 6V6GT, 5 X 12AX7, 1 X 12AT7 (NOS)
    -1x12” Victoria speaker
    -Available in Sonic Blue or Black tolex
    真要命又看到了一台新出的好吉他Amp
