顯示結果從 1 到 10 共計 11 條
    預設 B.M.C. Audio 推出三款新機:UltraDAC, PureAmp, PureMedia
    德國B.M.C. Audio (Balanced Music Concept) 一口氣推出三款新機,UltraDAC, PureAmp, PureMedia
    UltraDAC
    UltraDAC是PureDAC更高階的機種,擁有更具參考級的聲音品質,其是帶有平衡前級的DAC,參考等級的平衡耳擴,還有B.M.C.專有的數位智慧增益管理 Digital Intelligent Gain Management (DIGM)。UltraDAC的前級與DAC的電流/電壓轉換整合,可減少對輸出級的需求。前級與耳擴都有用上B.M.C.專有的Load Effect Free (LEF)技術,讓電流需求與電壓需求可以分別處理,自然能避免了失真的產生。UltraDAC前級與耳擴的音量控制是獨立的,搭載了高解析的非同步USB、AES/EBU, 光纖與同軸等數位輸入,平衡與RCA類比輸出,還有B.M.C. link可與B.M.C.後級連動控制。平衡輸出能與B.M.C專有的Current Injection (CI)技術的後級相容。
    UltraDAC與PureDAC不同的地方
    • 更好的時鐘 Top level local clock oscillator with super low phase noise and jitter
    • 70%更大的電源供應70% larger power supply for perfect stability under all conditions
    • 新的混合式LEF耳擴 New hybrid LEF headphone amplifier with 15A bipolar voltage output devices and MOSFET current sources.
    • 非平衡耳機輸出的重大進步 Vastly improved unbalanced standard headphone output with separate stage.
    • 新的混合式LEF輸出級 New hybrid LEF line stage with bipolar voltage output devices and MOSFET current sources.
    • SPDIF inputs with full 192kHz support.
    • 更安靜的箱體Quiet cabinet with damping.
    • 有固定音量的輸出選擇 Operation with fixed line output available.
    • 搖控器也能與PreAmp通用 Remote control includes PureAmp functions.
    規格特點 Features
    • Top-grade Digital/Analog Converter with Current Injection current-to-voltage (I/V) conversion
    • High-resolution asynchronous USB interface up to 32bit/384kHz
    • USB PCM: 16...32bit; 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384kHz.
    • DXD support without FIR filtering.
    • USB DSD: DSD64, DSD128.
    • ASIO driver for Windows; Linux and Mac compatible
    • AES/EBU, coaxial and Toslink digital inputs up to 24bit / 192kHz
    • Balanced, reference-class headphone amplifier with digital/analog power convertion (DAPC), load-effect free (LEF) technology, 15A bipolar Voltage output devices combined with MOSFET current sources, a super-low impedance LEF output stage, and lossless Digital Intelligent Gain Management (DIGM) volume control.
    • Balanced LEF, CI-compatible preamp that optionally operates in B.M.C. Mode, with DIGM and bipolar voltage source combines with a DMOS current source and LEF-balanced output stage.
    • Separate volume controls for the line and headphone sections (the line volume position 59 represents a DAC standard output level)
    • Second-generation DIGM with optimized gain distribution between power amps and internal and DIGM volume levels
    • Optical B.M.C. Link for connecting with B.M.C. amps like the PureAmp
    • Remote Control including PureAmp functions.
    • Top grade parts like MPP (conductive film polypropylene, non inductive) and balanced current capacitors, precision metal film resistors...
    • Massive and stylish extruded aluminum chassis
    • Dimensions: 14.37 x 4.06 x 12.91 inches, W/H/D (365 x 103 x 328 mm)
    • Weight: 7 kg
    The UltraDAC is available for order from factory.
    PureAmp 後級
    PureAmp讓B.M.C. PureLine的產品線更為完整,其每聲道有100W輸出(8 Ohms),本體為鋁合金,採用B.M.C.一貫的箱體設計,包括前方有個輸出顯示錶頭。PureAmp可透過B.M.C.獨有的Load Effect Free (LEF)、與B.M.C. DAC相連接,透過CI (Current Injection),變成有如綜擴的功能。PureAmp使用了B.M.C.獨有的多項技術,包括LEF Amplification, Current Injection (CI), and Discrete Intelligent Gain Management (DIGM),但價格非常吸引人。透過LEF Amplification技術,PureAmp一開始就可避免掉因為負回授有的失真問題。其使用了大型300W的環型變壓器,更多的能量儲存,並且比傳統A類的溫度更低,有著非常好的冷卻系統也是這麼小體積能提供這麼大輸出的原因。
    PureAmp上的B.M.C.三樣專利技術
    • Load Effect Free (LEF) Technology handles a speaker's current demand separately from the voltage demand. This helps the amplifier achieve high output and high-quality reproduction. It provides a top-level signal without loading the signal transistors, thus avoids distortion and increases efficiency. The result is a level of musical complexity that brings to life delicate details, rock-shaking power, high dynamics, sonic vitality, and accurate imaging.
    • Current Injection (CI) Technology processes the input current from a signal source through a special XLR-CI input and the amplifier's circuitry until it attains the desired output voltage for the loudspeakers, increasing the purity of the amplified signal and the immediacy of its musical reproduction, by skipping any gain stage and using an original source signal.
    • Digital Intelligent Gain Management (DIGM) is a volume and amplification control system that recalibrates gain without dividing and downgrading the input signal. It lets users adjust left/right output balances in 66 1.5-decibel increments. It also avoids unnecessary attenuation of the input signal and excessive amplification, eliminates the need for a preamp circuit, and allows a DAC or other sound sources to directly connect to the amplifier. Less amplification means less distortion and noise, which leads to a more natural musical quality
    PureAmp的輸入與輸出有XLR, RCA與光纖,所搭載的遙控器也能遙控PureDAC,後方有兩組平衡XLR-CD輸入、兩組RCA輸入、兩組Neutrik SpeakOn喇叭輸出,兩組光纖輸入(B.M.C. Link)。
    The PureAmp Stereo Integrated Amplifier is available Late October 2014 from authorized B.M.C. Audio dealers, B.M.C. dedicated shops and online at www.bmc.audio.de . It can be seen with B.M.C.’s other outstanding products at the Axiss hall during, Tokyo International Audio Show, Japan and at the in the Denver Mariott Tech Center, Atrium 561 during the Rocky Mountain Audio Fest.
  5. #3
    PureMedia
    PureMedia的誕生讓PureLine系列裡的播放功能更為全面。
    特點Features:
    - 專業的檔案伺服器/儲存管理 Professional file server / storage management
    You can up/download/stream files from any computer in the home. Store all music, pictures and videos.
    - 最高等級的播放規格 Highest grade audio player without any stream manipulation.
    Plays PCM files up to 32bit/384kHz, DSD64 and DSD128 via compatible USB2 DAC, with direct hardware access without sound manipulation.
    - 可透過手機、平板、電腦控制 Remote controllable from smart-phones or tablets, or any desktop computer.
    - 無DAC,可與其他DAC搭配使用 No internal DAC, compatible to any USB DAC following industry standards (e.g. PureDAC, UltraDAC, DAC1)
    - Audiophile CD ripper (with external USB drive only)
    - 高解析影像播放 High resolution video player
    You can have the picture via HDMI while getting the sound via USB.
    - 串流主機 Streaming server
    Plays content from your mobile on PureMedia, or play content from Puremedia on other devices.
    - WiFi access point with transparent NAT
    Generally PureMedia will be located in living rooms, so you get a better WiFi signal and fast access to the PureMedia.
    - Remote control with integrated air-mouse / handheld-keyboard
    - 2TB standard storage (special versions available as separate service only)
    - Up to 24TB available (18TB free with a RAID)
    - Up to 8TB available with full SSD
    - Backup synchronisation software.
    B.M.C. also supplies backup solutions for protecting your valuable media collection.
    - Multilingual
    - Simple wizards for important settings
    The PureMedia will be available from December 2014 from authorized B.M.C. Audio dealers, B.M.C. dedicated shops and online at www.bmc.audio.de . It can be seen with B.M.C.’s other outstanding products at the Axiss hall during, Tokyo International Audio Show, Japan and at the in the Denver Mariott Tech Center, Atrium 561 during the Rocky Mountain Audio Fest.
    www.bmc-audio.com
  6. The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
  7. #4
    pure amp的喇叭端子還真酷
    不知道葉大到時有無開箱文?
  8. The Following User Says Thank You to waokgla For This Useful Post:
  9. #5
    有機會一定會報導的
  10. The Following 2 Users Say Thank You to Leo Yeh For This Useful Post:
  11. #6
    期待葉大的報導
    除了高價音響也需要平衡一下
    來個平價音響讓大家能夠進入hi-end的世界
  12. The Following 2 Users Say Thank You to waokgla For This Useful Post:
  13. #7
    引用 作者: waokgla 查看文章
    pure amp的喇叭端子還真酷
    不知道葉大到時有無開箱文?
    看造型很像PA用的4PIN端子
  14. #8
    引用 作者: jacob604 查看文章
    看造型很像PA用的4PIN端子
    PA擴大機常見的speakON端子。http://www.neutrik.com/en/speakon/sp...speakon-combo/
  15. The Following User Says Thank You to kevintran For This Useful Post:
  16. #9
  17. #10
    SpeakON端子在ProAudio是standard。用過一次後就不會再想念普通的binding post,再也不會有鬆動的接口,不會短路,鏈接速度超快!
  18. The Following User Says Thank You to Sound of Nature For This Useful Post:
