第1頁,共3頁 123 最後最後
顯示結果從 1 到 10 共計 28 條
    預設 《品牌》OPPO
    OPPO過往最受矚目的是藍光播放機,BDP-95和BDP-105也獲得了很大的成功,現在OPPO將觸角延伸到了耳機擴大機,期待在新的領域繼續得到各方的肯定。
    HA-1耳機功率擴大機採用A類放大,DAC晶片使用ESS 9018 Sabre32 Reference DAC。可做非同步的USB DAC,STEREO前級使用。並可作數位訊號的接收,備有藍芽傳輸,全平衡輸出。使用環形變壓器、線性電源穩壓器、定製電容濾波器,確保乾淨和充足的電源。功率放大部分採人工選料並配對,確保平衡對稱。用家可選擇以XLR平衡輸出或1/4英吋耳機插孔輸出。
    數位輸入包含同軸、光纖、平衡AES/EBU、和非同步USB,支援PCM或是DSD格式的音樂檔案。透過USB可以連接電腦,播放電腦中的音樂檔案,OPPO並正在與智慧型手機製造商研究,未來將可能可使用行動裝置控制和播放音樂檔案。
    The OPPO HA-1 Headphone Amplifier builds upon the success of our BDP-95 and BPD-105 audiophile universal Blu-ray Disc players. The BDP-95 and 105 have been selected as "Recommended Components" by prestigious publications such as Stereophile and The Absolute Sound. Discerning listeners describe the players’ DAC and analog output stage as very detailed, transparent and engaging. Bench tests indicate the players’ performance approaching the measurable limit of audio analyzing instruments. Drawing upon the proven circuit design of these award-winning players, the HA-1 combines an uncompromising Class A balanced power amplifier section with the performance of the ESS 9018 Sabre32 Reference DAC.
    OPPO designs the HA-1 headphone amplifier with the same universal approach as our Blu-ray players. The HA-1 is a high performance headphone amplifier, and it doubles as an asynchronous USB DAC, a stereo pre-amplifier, a digital audio dock for mobile devices, and a Bluetooth audio transport. Its fully balanced design and numerous inputs ensure the best in fidelity and versatility.
    The analog audio section of the HA-1 is a fully balanced design with an emphasis on keeping the audio signal in the analog domain once it leaves the DAC. The HA-1 is anchored by a beefy toroidal power transformer. Linear power regulators and filters with custom made capacitors ensure that the headphone amplifier has a clean power source with plenty of reserve energy. The power amplification section uses hand-picked and paired discrete components to ensure symmetry.
    A motor-driven precision volume control knob enables both hand adjustment and remote control while keeping the audio in a pure analog audio path. Users have a choice of using the 4-pin balanced XLR or the traditional quarter-inch headphone jack. Line level analoginputs and outputs are provided with both RCA and balanced XLR sockets. Built-in monitoring and protection circuitry guards against any mishaps such as short-circuiting, overloading, and DC offset that could lead to degraded performance.
    The HA-1 is especially suitable for high-resolution digital audio. Its digital inputs include coaxial, optical, balanced AES/EBU, and an asynchronous USB DAC that supports both PCM and DSD formats. The same ESS 9018 Sabre32 Reference DAC and output driving stage used in our audiophile Blu-ray players ensures extremely low noise and low distortion performance. It is easy to connect the HA-1 to a computer via USB and enjoy jitter-free music using your favorite playback software. OPPO is also working with a leading smartphone and tablet manufacturer to certify the HA-1 so it can pass the required authentication and take digital audio from those popular mobile devices. For additional convenience, the Bluetooth audio transport with high quality Apt-X CODEC sets music in your mobile phones free with a performance boost.
    The HA-1 sports a classic design with contemporary elements. It is a desktop component housed in an aluminum chassis, and the familiar volume and source selection knobs are aided by a 4.3-inch screen for easy operation. Depending on your preference or even the mood of the music being played, you can choose between a classic VU meter, a modern spectrum display, or a simple informational summary on the screen. A supplied IR remote and a smartphone app via Bluetooth provide complete control and convenience.
    With its exemplary sound quality, versatile connectivity, and energetic driving power, the HA-1 headphone amplifier is a good match to any high performance headphone or stereo sound system.
    http://www.oppodigital.com/future/HA...Amplifier.aspx
  2. The Following 2 Users Say Thank You to Ted Chen For This Useful Post:
    預設 OPPO 耳機討論區
    親愛的粉絲,大家好:
    OPPO耳機特此設立專屬討論區
    歡迎各位玩家來討論您使用上的心得與看法
    若各位玩家對於使用OPPO耳機有任何問題
    也歡迎您在此討論區做提問
    將會有專人為您服務!
    感謝各位玩家與粉絲對OPPO耳機的支持與愛護~~~
    此篇文章於 2014-10-21 02:50 PM 被 OPPOservice 編輯。
    預設 [轉帖]業界革命,OPPO發佈全球最高靈敏度平面振膜耳機PM-1
    近日,OPPO在香港五星級Mira酒店隆重舉行了以“極致原聲、稀聲無遺”為主題的新品發佈會,展示了其最新推出的擁有全球最高靈敏度的PM-1平面振膜耳機及全功能HA-1耳機擴音機。
    這次發佈會堪稱香港史上最具規模的耳機產品發佈會。這也是繼OPPO被譽為“旗艦雙雄全球巡禮”之後的首次亞太亮相,吸引了眾多Hi-Fi發燒友、來自香港主流媒體、臺灣、內地多家專業影音媒體,共90多家媒體參加。
    OPPO高端耳機專案首席聲學專家及材料學家——Mr. Igor Levitsky出席發佈會,並詳細講解了OPPO PM-1平面振膜耳機及HA-1耳機擴音機的各項專有技術及嶄新功能。香港發燒界享譽盛名的歌唱家,《霍元甲》等影視主題曲演唱者葉振棠先生也特別到場慶賀並和與會者互動。更有旨在表現PM-1左右耳完美配對的雙胞胎美女模特現場演繹,氣氛空前熱烈。
    图1:OPPO PM-1香港發佈會現場Mr. Igor Levitsky講解PM-1所用技術
    图2:尚未盡興的媒體記者和耳機發燒友在發佈會後與Mr. Igor Levitsky座談
    图3:雙胞胎美女模特現場演繹PM-1左右耳完美配對
    此前,OPPO,一直致力於研發發燒級專業藍光播放機,憑藉其尖端技術、精湛設計、頂級器件、傑出工藝及優質服務,屢獲國際殊榮,被業界推崇為超值五星級影音產品,贏得了全球市場消費者的高度評價和青睞。
    近年來, OPPO進入Personal Audio領域,發力高端耳機市場,經過8年研發攻堅,首款產品便一鳴驚人。此次,OPPO打破幾十年來平面振膜耳機行業無法擺脫的魔咒,創世紀地使PM-1的靈敏度提升到了102 dB的水準,使全行業尖叫。PM-1平面振膜耳機、HA-1耳機擴音機旗艦雙雄的推出,為OPPO“榮譽家族”再添兩員大將,為廣大發燒友再添福音,獲得了國內外廣泛關注和高度讚譽。
    OPPO高端耳機專案首席聲學專家及材料學家Mr. Igor說:“我們花費了大量時間,為了使PM-1成為一款卓越的、奢華的、能同時吸引音樂發燒友和各類音樂愛好者的耳機產品。”
    PM-1採用平面振膜驅動單元,其振膜以獨有的七層透薄材質製造,在高靈敏度、相位一致、高穩定性及專有平面振膜技術上,為個人監聽級耳機重新定義。如此全平衡的獨具匠心的設計,確實帶給用戶更豐富及震撼原音體驗。正如發佈會主題“Larger than Life Sound. To Hear the Smallest Detail——極致原音、稀聲無遺”,OPPO PM-1 及HA-1 以再現聲音原貌為設計理念,並沒有特別把某一頻率的範圍加強,而是純粹將原音完整呈現。音樂愛好者及耳機發燒友,可透過OPPO PM-1 及HA-1 得到最原始而又不偏不倚的聲音。
    另外,PM-1的高靈敏度使其可以輕鬆地回饋任何微小的細節聲音,不錯過音樂的任何細節,從而使音質更加出色,回應速度更快,不拖泥帶水。與其他競品相比,OPPO PM-1有著更“隨和”的個性,即使用手機,iPad等移動電子設備推動,也能擁有同樣傲人的聲音表現。
    图4:OPPO PM-1平面振膜耳機與HA-1耳機擴音機
    OPPO一直專注高端影音領域,低調地踐行對極致影音的追求。其實早在OPPO香港發佈會之前,OPPO PM-1與HA-1已經在國際上載譽頗豐。
    自從2013年10月美國CanJam RMAF展OPPO PM-1平面振膜耳機首度亮相以來,這款設計獨特的高端耳機就引發了全球耳機發燒友的熱烈討論。今年4月份PM-1在美國首次發佈,便贏得了專業測評機構和消費者的一致好評。
    2014年4月11日,OPPO在倫敦舉辦發佈會,PM-1在英國乃至歐洲得到盛讚。全球最大的耳機論壇Headfi上,關於OPPO PM-1耳機的討論帖居高不下,非常熱門。
    歐洲一位骨灰級耳機發燒友Scootermafia 評論道,“PM-1品質卓越,易驅動,輕便舒適,配件豐富,擁有較同等產品更為優惠的價格,可以毫不猶豫入手。像OPPO PM-1,Alpha Dogs,LCD3,HD800和K812發燒友們擁有其中的任何一副,都是件幸事。”
    图5:OPPO PM-1倫敦發佈會成功舉辦
    5月10日-11日,OPPO參加了東京2014年春季Fujiya Avic耳機展, 新款耳機PM-1大受歡迎。人們在展臺前排起了長龍,個個對PM-1躍躍欲試。
    John H. Darko在Digital Audio Review中寫道:“整個週末你無法靠近Emilai展臺。排隊的隊伍總是裡裡外外至少有三層。原因是什麼呢?是OPPO PM-1和它的‘搭檔’HA-1耳擴。”
    图6:日本發燒友們在Fujiya Avicer耳機展現場用OPPO PM-1和HA-1認真聆聽
    5月15日-18日,OPPO參展了慕尼克高級音響展,在眾多頂級影音產品中脫穎而出。
    Michael Piskor 在The Sound Bar中感歎道:“我仍然記得2013年OPPO新款平面振膜耳機平面圖首次發佈時,我不由自主在辦公桌前流口水的樣子。如此時尚而且吸引人的設計對我來說簡直太誘人了,讓我無法抗拒。”
    图7:慕尼克音響展會現場,OPPO PM-1和HA-1引眾多發燒友駐足試聽
    而在澳大利亞,乘坐維珍航空的各國“空中飛人”們,也將有幸在五月的航空雜誌上欣賞到OPPO PM-1及HA-1的精緻。
    美國福布斯網站發表評論說,“毫無疑問,OPPO PM-1平面振膜耳機是一款精妙絕倫的耳機。”PM-1在各方面的卓越表現,讓它一鳴驚人,一上市就和眾多行業名品一起,被發燒友列入了“最值得擁有”“有幸擁有”“強烈推薦”的Hi-Fi耳機之列。OPPO PM-1在國際上大放異彩。與其他競品相比,OPPO PM-1有著更“隨和”的個性——對耳放不挑剔,更高的性價比,但卻擁有同樣傲人的聲音表現。
    據悉,自今年四月份起,OPPO PM-1耳機開始陸續在美國、歐洲、日本、香港、新加坡、澳洲、俄羅斯發佈並上市。相信不久之後,更多的國家和地區的耳機發燒友都將有機會感受到PM-1的奢華質感和極致原聲。
    图8:發燒友的PM-1開箱體驗
    图9:PM-1由外而內的極致體驗
  5. The Following User Says Thank You to traboo For This Useful Post:
  6. #4
    引頸期待的OPPO耳機&耳擴即將上市囉!
    開箱文搶先看~~~
    詳細連結網址:
    https://www.facebook.com/notes/oppo-...87268261392214
  7. #5
    再現聲音原貌!OPPO鑑聽級組合
    PM-1平板耳機及HA-1耳機前級擴大機
    詳細連結網址:
    http://www.cool-style.com.tw/wd/archives/93486
    感謝潮流COOL報導~~~
  8. #6
    恭喜OPPO PM-1耳機 榮獲歐洲頂級影音雜誌WHATHIFI 五星推薦
    詳細連結網址:
    https://www.facebook.com/notes/oppo-...95305860588454
  9. #7
    【OPPO PM-1獲得了歐洲影音界最高榮譽的獎項】
    EISA 2014-2015最佳HI-FI耳機大獎
    今天,這款被EISA官方評為
    今年最令人興奮的耳機載譽而歸。
    在它身上,掩藏了多少不為人知的光芒,關注PM-1
    一起探尋極致的完美。
  10. #8
    【OPPO PM-1極致原音 細聲無遺】
    每天檢驗成千上萬的零件
    一千個製作精細的零件裡
    往往只能挑選出一個真正的零瑕疵
    這不是偏執,這是PM-1的標準
  11. #9
    PM-1的每一對揚聲器
    都堅持手工組裝
    一天只能完成五十對
  12. #10
    預設 【新品速報】 OPPO PM-3 平面振膜耳機 10/29北京首次曝光
    前段時間在美國RMAF 2014洛磯山音響展中,OPPO Digital展出了兩款正在研發中的新產品:可擕式耳擴HA-2和封閉式耳機PM-3。隨後網友在著名耳機發燒論壇Head-Fi上曝光了這兩款新產品的照片,通過對PM-1和HA-1的對比,講述了PM-3耳機和HA-2耳擴所繼承的優良傳統以及新亮點。
    [IMG]據官方公佈,OPPO將在10月29號也就是本週三,首次在國內發佈新一代可擕式平面振膜耳機PM-3。從Head-Fi論壇的帖子看來,PM-3這次也將延續OPPO的螺旋增壓平面振膜的創新技術,並且區別於之前兩款產品,PM-3將會以便攜為主打元素,講求如何讓發燒友們突破地域和設備的局限,隨心所欲隨時隨地的享受高品質音樂。 並且還有消息稱,PM-3將不再局限於PM-1/PM-2的黑白兩色,此外提供更多顏色供選擇,不得不說這符合了“便攜”用戶的青春、時尚。[/IMG]
    據HeadFi論壇帖子稱,PM-3採取了封閉式設計,隔音效果會更好,即便帶出街,也不會被外界熙熙攘攘的嘈雜聲影響。
    除了耳機PM-3以外,高端耳機的搭檔 OPPO HA-2耳擴也在發佈新產品之列。從圖片看來,小編覺得HA-2更為小巧優雅,乍一看還以為是一部手機或手寫筆記本。
    在耳機發燒友中有這樣一個普遍的認識,那就是平面振膜耳機對聲音細節的處理更豐富,更可靠,同時它也存在一個工藝複雜,價格偏高的問題。由於這個缺點使得它(平面振膜耳機)一直局限于高端發燒友的圈子裡,沒能走向大眾。 OPPO PM-1作為2014—2015 EISA HIFI耳機大獎的得主,而PM-3作為PM-1的移動便攜版,它是否能夠成為今年最佳出街平面振膜神器?這還要看它的定價,讓我們來期待本週三在新加坡北京兩地同步進行的OPPO發佈會,OPPO 影音將會給我們帶來什麼樣的驚喜吧。
