610LP Detailed Specifications |
Type |
Solid State |
Configuration |
Fully balanced, dual-mono |
Power Supply Transformer |
25VA |
Power Supply Capacitance |
40,000µF |
Balanced Inputs (XLR) |
1 pair |
Single Ended Inputs (RCA) |
1 pair |
Input Impedance - Adjustable |
64 settings from 12.1Ω to 47KΩ |
Input Capacitance - Adjustable |
16 settings from 0 to 470 pF |
Gain - Adjustable |
16 settings from 40dB to 70dB |
Balanced Output (XLR) |
1 pair |
Single-ended Output (RCA) |
1 pair |
Input overload @ 40dB gain |
200mV RMS (XLR) / 100mV RMS (RCA) |
Input overload @ 55.5dB gain |
30mV RMS (XLR) / 15mV RMS (RCA) |
Input overload @ 60dB gain |
20mV RMS (XLR) / 10mV RMS (RCA) |
Input overload @ 65dB gain |
10mV RMS (XLR) / 5mV RMS (RCA) |
Input overload @ 70dB gain |
5mV RMS (XLR) / 2.5mV RMS (RCA) |
Signal-to-noise Ratio (fs @ 40dB gain) |
112dBr |
Signal-to-noise Ratio (fs @ 55.5dB gain) |
106dBr |
Signal-to-noise Ratio (fs @ 60dB gain) |
103dBr |
Signal-to-noise Ratio (fs @ 65dB gain) |
98dBr |
Signal-to-noise Ratio (fs @ 70dB gain) |
93dBr |
Maximum Output (1kHz @ 10kΩ) |
20.0 Volts (XLR) / 10.0 Volts (RCA) |
Output Impedance |
50Ω |
IEC Curve Effect |
-7dB @ 10Hz |
Frequency Response |
20Hz - 20kHz (±0.1dB) |
Crosstalk @ 1kHz |
-106dB |
IMD |
< 0.002% |
THD (20Hz - 20kHz) |
< 0.001% |
12 Volt Trigger Output Operation |
Direct Logic (0V = off, 12V=on) using a 3.5mm
mono jack with an output impedance of 1000Ω
and current requirement of 12mA |
Available Faceplate Finishes |
Black and Silver |
Power Consumption |
6 Watts |
AC Power Requirements |
120V / 60Hz 220-240V / 50Hz |
Fuse Replacement 120V / 220-240V |
200mA short slow blow / 100mA short slow blow |
Shipping weight |
40 lbs / 18 kgs |
Dimensions (W x H x D) |
18.75 x 4.1 x 16.81 in. (47.6 x 10.4 x 42.7 cm.) |
Specifications are subject to change without notice. |
