顯示結果從 1 到 10 共計 11 條
    預設 Sonus Faber 推出30周年限定版 喇叭 EXTREMA
    1991年,當時的Extrema問世,一個相當獨特的喇叭設計。6 dB/octave 分音器,第一個設計訊號無電容串聯,特殊的箱體以求優化組件性能和消除後方無源輻射。
    Extrema在Sonus Faber的歷史中是一個優異的設計,在發展的過程中是一個里程碑。無論在設計或是聲音工程上,是最為接近完美的成就。這次的30周年紀念版,Sonus Faber決定以其DNA和傳統,伴隨新科技的發展、聲音研發、設計整合和材料使用來完成這次的限定版Extrema。
    THE SHAPE
    The wiry shape of the speaker breaks on purpose the tradition of the soft lines that characterise Sonus faber products, and was obtained using a reduction process in which the volume was extracted from a block of rigid material. As marble under the skilled hands of the sculptor, the raw material has been broken to obtain clean cuts and tight surfaces. Extrema is for performance without compromises and its dynamic lines mirror its character and nature.
    THE CARBON FIBER
    Carbon, a very particular chemical element at the base of all the life on our planet, is present in nature in various forms, from the softest such as graphite to the hardest such as diamonds.Today used in multiple environments, from aeronautics to vehicles, medicine and sport, carbon is well known to Sonus faber, which experimented its characteristics when producing the Huayra sound system, the latest model of supercar made by Pagani Automobili from Modena.
    THE CHASSIS
    The complex mold with 6 elements used to create the speaker frame is made to measure, making the standard production of the object extremely limited, adding exclusiveness to the character of this loudspeaker that is already a cult object for the most enthusiastic collectors.
    WOOD
    The art of lute making has always been a source of inspiration for the design of many of Sonus faber most emblematic speakers; it is not by chance that all the precious elements of the Homage collection, from Amati to Guarneri and Stradivari are named after the most famous lute makers in history.
    The new Extrema pays an important tribute to this antique art by flanking, in close contact with the ultra-modern carbon chassis, sides of red spruce from Val di Fiemme, the wood of string instruments par excellence.
    THE SIDES
    The sound of wood has always been important for Sonus faber. In the case of the Extrema project, the fact that the supporting structure of the loudspeaker is made with a carbon monocoque make it possible to use wood as the pure resounding element, exactly as in the sound board of string instruments. The choice therefore had to be the resonant spruce from Val di Fiemme, the rare and prestigious essence of which violins are made.
    BERYLLIUM AND DIAMOND
    Beryllium is an extremely rare and exclusive metal that is used in various high-technology industrial sectors, such as medicine, aerospace and experimental/applied physics. Beryllium also played an important part in the history of audio transducers, used for example in magnetic cartridges
    THE MEDIUM AND LOW FREQUENCY
    The 180 mm “Ultra dynamic linearity” mid-woofer designed by Sonus faber and equipped with a Neodymium motor, is the driver that reproduces the medium and low frequencies. A pure copper winding 6N is used on a coil support with control of the Lorentz currents. The magnetic motor, very linear and dynamic, has an optimised layout and a heat dissipator that also acts as a “mass damper”. The special diaphragm, which is personalised for Sonus faber, is obtained by means of a sandwich that uses nano-carbon hides and a special syntactic dampening foam to obtain maximum resolution.
    THE HIGH FREQUENCY
    Reproducing high frequencies is entrusted to a 30 mm transducer with mobile coil designed entirely by Sonus faber, implemented with a Sonus faber mechanical interface that optimises vibration management.The “Ultra dynamic linearity”, the result of the new Neodymium magnetic system, is optimised by the dome diaphragm of DLC (Diamond Like Carbon) Beryllium to obtain the maximum resolution possible in acoustic reproduction.
    THE ULTRA LOW FREQUENCY AND ITS MANAGEMENT
    The passive radiator is also fully designed by Sonus faber; the L’E.M.B.A.B.R (Electro Magnetic Brake Auxiliary Bass Radiator), according to Engineer Cadawas, has varied dampening. The flat piston diaphragm is optimised for this application, and is positioned structurally midway between the sandwich structures of the midwoofer cone and the “monocoque” structure. The basket is fully optimised to eliminate all resonance, thanks to the use of two high technologymetals (Ergal and Gun Metal) that are machined in CNC from the solid piece. The combination of these two metals eliminates any reciprocal resonance.
    CROSSOVER IN AIR
    The new Extrema uses a precious non-resonant Crossover in air with progressive slope, optimised by module and phase for the best space/time behaviour. The “paracross” topology is combined with best quality components that exalt the sound quality: Mundorf Supreme capacitor and Jantzen inductors. The crossover frequency is 2350 Hz, and the low frequencies can be dampened in 4 different ways, according to the listening room.
    SYSTEM
    2 way, low spurious vibration optimized suspension, E.M.B.A.B.R. (Electro magnetic Brake Auxiliary Bass Radiator), monitor on a dedicated stand loudspeaker system.
    CABINET
    The carbon fiber sandwich “monocoque”, inspired by the supercar cockpits, is the main chassis structure on which the cabinet is build up. Constrained-mode damped lateral “Val di Fiemme” harmonic fir (Violin wood) sides, hand selected, quality graded and oriented for carefully optimized resonances control. The innovative resonance control of the wood structure is obtained by a 3D thickness distribution in the shape. “New Era” avional (from “the Sonus faber” experience) exo-squeleton front and rear clamp structure.
    TWEETER
    A Sonus faber designed 30 mm moving coil driver, with Sonus faber’s vibration optimized mechanical interface. D.L.C. (Diamond Like Carbon) Beryllium dome diaphragm for maximum resolution.
    MID-WOOFER
    A Sonus faber designed 180 mm neodymium magnet system ultra dynamic linearity mid-woofer. 6N pure copper wire is used on a controlled “eddy current” former. The dynamically linear magnetic field motor has an optimized geometry and a mass damper heat sink.
    PASSIVE RADIATOR
    A Sonus faber designed race track shape E.M.B.A.B.R. (Electro magnetic Brake Auxiliary Bass Radiator) “Cadawas” variably damped passive radiator.
    CROSS-OVER
    Non-resonant “progressive slope” design, optimized amplitude/phase response for optimal space/time performance. “Paracross topology” topology. Cross-over: 2350Hz. Adjustable low frequency damping into 4 different level.
    FREQUENCY RESPONSE
    40 Hz – 40.000 Hz, E.M.B.A.B.R included.
    SENSITIVITY
    88 db SPL (2.83V/1 m).
    NOMINAL IMPEDENCE
    4 ohm.
    SUGGESTED AMPLIFIER POWER OUTPUT
    50W – 300W, without clipping.
    LONG-TERM MAXIMUM INPUT VOLTAGE (IEC-268-5)
    24V rms.
    DIMENSIONS (HxWxD)
    434 x 282 x 560 mm.
    WEIGHT
    18,6 Kg each – net weigh.
    DEDICATED STAND (HxWxD)
    Dimensions: 661 x 360 x 460 mm.Weight: 22 Kg each – net weight.
    TOTAL DIMENSIONS (HxWxD)
    1.095 x 360 x 560 mm
    TOTAL WEIGHT
    40,6 Kg each – net weight.
    http://www.sonusfaber.com/en-us/products/extrema
    此篇文章於 2014-03-28 03:21 PM 被 Ted Chen 編輯。
  2. The Following 5 Users Say Thank You to Ted Chen For This Useful Post:
    看起來好威好厲害!
  4. The Following User Says Thank You to raychen For This Useful Post:
  5. #3
    舊款的外形比較好看耶,好像黑白無常的帽子
  6. #4
    我也覺得當初那一版比較優! 價格更優, 二十幾萬的樣子!
  7. The Following User Says Thank You to edwardmos For This Useful Post:
  8. #5
  9. The Following 4 Users Say Thank You to Leo Yeh For This Useful Post:
  10. #6
    只有生產30對
    台灣只分到一對!
  11. The Following 2 Users Say Thank You to jeremywang For This Useful Post:
  12. #7
    只有生產30對
    台灣只分到一對!
    想買都買不到!
  13. #8
    太誇張了啦!外型ㄝ沒多好看哪……還好只有30對
  14. #9
    真後悔十五年前沒留下 Extrema!
    一隻體重 40kg, 腳架是金屬的版本少說有 50~60kg,只能說 - 有幸曾經擁有。
    持有 Sonus Faber 的用家,這是會增值的好東西,就算是當擺飾都漂亮!
    不要犯了我同樣的錯誤,恭喜拿到台灣唯一的 Ex3ma 幸運兒!
  15. The Following User Says Thank You to Eton For This Useful Post:
  16. #10
    日本的訂價出來了,是JPY 8,000,000 不含稅
