顯示結果從 1 到 4 共計 4 條
    預設 【新品】TEAC推出攜帶式DAC耳擴 HA-P50
    在iOS和PC系統下支援24bit/96kHz高解析檔案
    內建BurrBrown PCM5102 D/A解碼晶片
    可直接連接iPod或Android裝置播放音樂,也可直接連接類比輸出的音樂訊源
    使用OPA1652 Op-Amp放大電路,並有高低增益可切換
    可在APP商店或是TEAC網站下載免費TEAC HR(高解析)播放軟體
    可匹配耳機阻抗為8~600歐姆
    單邊最大功率為160mW(32歐姆)
    耳機輸出端和類比輸入端為1/8吋耳機插孔
    數位輸入端有USB-A和USB Micro B
    電池約可連續使用八小時
    重量:210g
    大小:64 x 21.7 x 112 mm
    MAIN FEATURES:
    “Reference To-Go” Portable Headphone Amplifier
    24bit/96kHz High-resolution Playback from iOS Devices
    24bit/96kHz High-resolution Playback from PC (Windows/Mac)
    Digital Direct Connection from iPod and Android Devices*
    Optical Digital Audio Player for Digital Audio Devices
    Analog Audio Input for Conventional Music Player
    BurrBrown PCM5102 D/A Converter
    Discrete Push-Pull Circuit Output Stage with OPA1652 Op-Amp
    High/Low Gain Selector
    Volume Control
    High-resolution Audio Playback Software TEAC HR Audio
    Player for iOS is available at Free of Charge from AppStore
    Player is available at Free of Charge from TEAC Website.
    Auto Power Save Mode
    * Android Device with AOA2.0
    General Specifications:
    Headphone Output Power: 160mW + 160mW (32ohms)
    Total Harmonic Distortion: 0.001% (100mW + 100mW )
    Analog Audio Input: 1/8” Stereo Mini
    Digital Audio Inputs: USB Type-A, USB Micro B
    Headphone Output: 1/8” Stereo Mini
    Compatible Headphone Impedance: 8 to 600 ohms
    Battery: Lithium Battery (2100mAh)
    Battely Life: Approx. 8 Hours
    Dimensions (W x H x D): 64 x 21.7 x 112 mm, 2.5” x 0.85” x 4.4”
    Net Weight: 210 g, 0.46 lbs.
    TEAC: http://teac.jp/
    台灣代理 勝旗: http://www.winkey-audio.com.tw
    此篇文章於 2014-03-13 03:39 PM 被 Ted Chen 編輯。
  2. The Following 2 Users Say Thank You to Ted Chen For This Useful Post:
    那軟件好像不支授 ALAC 及 AIFF 的。
    Supported File Formats
    dsf 2.8/5.6MHz PCM(wav) 44.1k-384kHz, 16-32bit mp3 32k-320kbps
    diff 2.8/5.6MHz FLAC 44.1k-384kHz, 16-32bit
    來源 官方網站: http://www.teac.com/product/hr_audio_player/
    引用 作者: ManAtWork 查看文章
  5. #4
    官網中支援裝置沒有Ipod classic 160G,請問是否不支援
    Evil is Evil. Lesser, greater, middling… Makes no difference. The degree is arbitary. The definition’s blurred. If I’m to choose between one evil and another… I’d rather not choose at all.
