顯示結果從 1 到 10 共計 12 條
    預設 【擴大機】Rogue Audio Cronus Magnum 真空管綜擴
    這兩天聽這台真空管綜擴,聲音真的蠻不錯的,有讓我驚豔到,是好東西
    尤其是高頻的部份原本會以為比較暗,結果剛好相反,很多高頻的細節表現都非常的好
    Rogue Audio其實這幾年我到CES都有印象,美國本土管機廠商真的不算少,而且大都走平實路線的,不走天價
    Rogue Audio是其中之一,這次試聽的這台Cronus Magnum應該不到10萬台幣,無論是以聲音或是以造型用料,目前整個感覺起來都相當推薦,待我再好好聽聽
    今年CES特別幫Rogue Audio的團隊照了一張,他們展出新的Pharaoh綜擴,推Dynaudio Confidence C1,黑膠是搭配Dr. Feickert,線材是Synergistic Research,聲音表現也相當不錯,能將C1推開,豐潤溫暖
    http://www.my-hiend.com/vbb/showthre...883#post205883
    由左至右: Bill, Nick, Mark O'Brien (CEO)
    這有趣的真空管小燈,是Rogue工程師的點子
    Pharaoh綜擴的資料
    The new Pharaoh integrated amplifier is now shipping. Based on our Hydra/Medusa amplifier platform the Pharaoh is Rogue Audio's flagship integrated amp. Boasting 175 WPC into 8 ohms the Pharaoh features a tube preamplifier circuit, an MM/MC phono preamplifier with adjustable loading and gain, a tube headphone amplifier, processor loop, balanced inputs, home theater bypass and exceptional performance.
    General Features and Specifications:
    - 175 WPC/8 ohms 350WPC/4 ohms
    - Pure tube mu-follower preamplifier
    - Slow start turn on sequencing
    - Green design with extremely low power consumption
    - Damping factor > 1000
    - Discrete tube based headphone amplifer
    - Balanced XLR inputs, three line level inputs, one phono input
    - MM/MC phono w/ 40/60dB gain
    - Adjustable phono loading
    - Massive high storage linear (!) power supply
    - Mundorf EVO oil coupling caps
    - Ultra high quality components throughout
    - 39 pounds/45 pounds shipping weight
    - 18.25" wide x 18" deep (including posts and knobs) 6.5" high
    - Fully tested, burned-in, and auditioned
    - Detachable IEC power cord
    - Entirely designed and hand built in the USA
    - 3 year limited warranty (6 months on tubes)
  5. #3
    本次試聽的主角Cronus Magnum
    箱子上雖然寫的是220V,但事實上是110V的
    Rogue的Logo看起來應該是一隻老鷹,Rogue英文好像是惡棍、流氓,有兇猛之意?
    兇猛的聲音???
  7. #4
    包裝的保麗龍很密紮實,讓管機的運送可以更為安全
    主要4根功率管KT-120比較大,分開包裝,沒看到前級訊號管12AU7, 12AX7,應該是已裝上了
    果然沒錯,小管已經裝好了
    調整偏壓的指針,別有一翻風味
    原本以為放隻鉛筆幹麻,原來是調整偏壓要用到的工具
    將KT102功率管裝上
    有耳機輸出,還有Phono唱放
    調整偏壓的地方
  9. #5
    上機,管機運作半小時候,有些許的溫度就出來了,主要熱度當然是來自4隻大大的KT-120功率管
    Magnum其實是升級版本
    Titan系列共有三個產品: Atlas Power Amp, Metis Preamp, Cronus Integrated
    主要有
    - Larger power supply 更大的電源供應
    - Power supply mods
    - Polypropylene bypass capacitors 聚丙烯電容
    - Precision Dale-Vishay resistors in critical spots 更精準的Dale-Vishay電阻
    - Upgraded binding posts 升級的喇叭端子
    - Gold tube sockets 鍍金的真空管座
    - Upgraded small signal tubes 訊號管升級
    - Magnum logo on faceplate 前面版有Magnum的Logo
  10. #6
    為了要看一個地方,將上蓋給打開了,也順便一覽內部的實在好料
  11. The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
  12. #7
    今天約了小葉,到MY-END去談天說是非,現場剛好是這一台真空管綜合擴大機在推Marten Django XL, 我公司正好有這一歀喇叭,聽下來,這Rogue Audio Cronus Magnum 還真的讓我眼為之一亮,如此的價位,如此的表現,太太超值了,是有必要來公司試一試(操一下看能耐到何等境界),好好了解之後再做分享。
  13. The Following 2 Users Say Thank You to 鼎捷音響 For This Useful Post:
  14. #8
  15. #9
    這個錶頭是用來調整偏壓時可看的,原廠說明書有寫調整偏壓的方法,非常簡單
    為什麼不用自動偏壓?留待MY-HIEND雜誌第8期中解答
  16. The Following User Says Thank You to Leo Yeh For This Useful Post:
  17. #10
    這就是調偏壓的地方,對應4隻KT120功率管,只要對應著錶頭進行調整即可
