顯示結果從 1 到 1 共計 1 條
    預設 TEAC CD-2000 台灣全新到貨
    TEAC CD-2000 擁有USB輸入的CD/SACD 播放機
    可支援192kHz/24bit的DA系統,動態範圍超過100dB。還可透過USB連接到電腦或其他裝置,聆聽FLAC、WAV或蘋果無損檔案。後面板具備一對XLR平衡類比輸出和RCA非平衡類比輸出,以及一組同軸的數位輸出。包含一個遙控器,目前外觀有銀黑兩種色調。
    The CD-2000 is one of a series of the finest CD/SACD players ever made by TEAC, with the addition of being a high-quality computer output interface as well. The CD-2000 features a solid optical transport with an aluminum front panel and tray bezel for stable reading. It contains a 192kHz/24-bit D/A converter (CS4398) and meticulously designed output stage boasting dynamic range over 100dB and signal to noise over 110dB.
    In addition to disc playback, the USB input of the CD-2000 can be connected to a Mac or Windows computer for streaming playback of your computer’s music library. It’s ideal for listening to high-resolution audio formats such as FLAC, WAV and Apple Lossless files. The rear panel of the CD-2000 features a pair of XLR balanced and RCA unbalanced line outputs and a coaxial digital output. It includes a wireless remote control and detachable AC cord. The product is available in black or silver.
    TEAC’s Distinction series is a new line of high-end products for listeners looking for exquisite sound quality from their components. Engineers from Esoteric, our exclusive audiophile brand, were involved in the voicing phase of their product development.
    CD Player Supports SACD, CD, CD-R/RW Disc
    USB Audio Class2 High-speed Input from PC/Mac (192 kHz at 24 bits asynchronous max)
    24bit/192kHz D/A Converter (CS4398)
    Fluorescent Display
    Detachable AC Socket
    Aluminum Front Panel and Tray Bezel Remote Control
    Dynamic Range: more than 100dB
    Signal-to-Noise Ratio: more than 110dB
    Total Harmonic Distortion: less than 0.0015%
    USB Input: x 1 (USB 2.0)
    Balanced Analogue Audio Output: x 1 (XLR)
    Audio Output: x 1 (RCA)
    Digital Audio Output: x 1 (Coaxial)
    Operation: 120V AC, 60Hz (US), 230V AC, 50Hz (EUR)
    Dimensions (W x H x D): 17-1/8" x 4-5/8" x 13-1/4" (435 x 116 x 366 mm)
    Weight: 15 lbs. 14 oz. (7.2 kg)
    TEAC官方網站: www.teac.com/
    台灣代理 勝旗: www.winkey-audio.com.tw
