顯示結果從 1 到 8 共計 8 條
    預設 ASR Emitter Ⅱ Exclusive
    有個問題困擾很久想請教ASR擴大機玩家,我的擴大機不管是開機或關機,經常都會突然發出噹的聲響,這是正常現象嗎?如果是正常,那這噹聲又是代表何意?
    應該是relay聲音
  3. The Following User Says Thank You to alain For This Useful Post:
    引用 作者: alain 查看文章
    應該是relay聲音
    如果是relay,那算正常嗎?
  5. #4
    我的也會。
    不知道其他用家是否也會?
  6. #5
    好像是 散熱片 升溫跟壓克力機殼固定螺絲 間隙。 說明書 說 把 散熱片 螺絲放鬆即可
  7. The Following 3 Users Say Thank You to Benny Fan For This Useful Post:
  8. #6
    5.7 Noise from the main unit while warming up/cooling down
    The main unit of the ASR Emitter is assembled with acrylic glass and heat sinks of aluminium. These two materials expand differently during the warming up/cooling off-phase of the amplifier.
    This may result in some crackling noises during warming up or cooling down.
    Remedy: loosen the screws (located in the heat sinks) of the front- and/or back plate of the ASR Emitter.
  9. The Following 4 Users Say Thank You to Benny Fan For This Useful Post:
  10. #7
    這問題以前有發現,答案就如同Benny說的.............我是沒去管他啦
  11. The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
  12. #8
    引用 作者: Benny Fan 查看文章
    感謝Benny兄幫忙解惑。
  13. The Following User Says Thank You to Sauret For This Useful Post:
