第5頁,共5頁 第一第一 ... 345
顯示結果從 41 到 50 共計 50 條
  1. #41
  2. #42
    SV-91BII
    Tube used: WE328A * 4, Prime 300B ver.3 * 2, GD274B * 1
    Output: 10W +10 W (8Ω, THD: 10%)
    Frequency response: 12.5Hz ~ 60kHz (1W 8Ω-3dB)
    Gain: 27dB (8Ω)
    Load Calibration: 4/6/8/16Ω when produced from a selected strain
    Size (including protrusion ball): W400 × D300 × H220
    Weight kg: 23
    288,000 yen
  3. #43
    SV-310
    Format: preamp output transformer
    Tube used: Russian 310A * 2, GD/5U4G * 1
    Frequency response: 10Hz ~ 150kHz (1V 10KΩ-3dB)
    Gain: 10dB
    Size (including protrusion ball): W330 × D280 × H210
    Weight kg: 12
    168,000 yen
  4. #44
    WS-350B
    Tube used: 6SN7 * 2,350 B * 2
    Output: 8W +8 W (8Ω, THD: 10%)
    Frequency response: 10Hz ~ 100kHz (1W 8Ω-3dB)
    Gain: 32.5dB (8Ω)
    Load Calibration: 6/8Ω
    Size (including protrusion ball): W260 × D280 × H200
    Weight kg: 10
    69,800 yen
  5. #45
    上方為Model2 DAC,下方為CEC轉盤
    Model2 DAC
    Tube formula 96KHz/24-bit DA converter
    Format: tube-buffered D / A Converter
    Tube use: 6922 * 2
    Output: 2V (0dB digital signal regeneration)
    Corresponding sampling 32KHz ~ 96KHz, 16bit ~ 24bit
    Analog Output: RCA coaxial * 1 strains
    Size (including protrusion ball): W300 × D260 × H100
    Weight kg: 4.0
    63,000 yen
  6. #46
    SV-722 (Marantz 7)
    Format: MM / MC preamp with EQ
    Tube used: SOV/12AX7LPS * 6
    Frequency response: FONO: 20Hz ~ 30kHz (RIAA deviation ± 1dB) amplifier Flat: 5Hz ~ 200kHz
    MC(L):92dB Gain: MC (L): 92dB
    Size (including protrusion ball): W420 × D360 × H130
    Weight kg: 7
    128,000 yen
  7. #47
  8. #48
    整套的SUNVALLEY前後級與DAC、唱頭放大,聽起來如何?韻味十足,輕鬆溫暖,ProAc Response 3的表現相較於當時價位,在現在更顯超值,cyyc的咖啡相當好喝,有緣者千萬不要錯過!
  9. #49
  10. #50
    同为proac用家,可惜没有用过胆机。
    我是d25,不知可有合适胆机推荐?ARC vsi60 不知如何?
