第421頁,共435頁 第一第一 ... 321371411419420421422423431 ... 最後最後
顯示結果從 4,201 到 4,210 共計 4343 條
  1. #4201
    先登記再喬看看
    喬不下來的話
    以後就只有看到我很GY的拿這個去音響展偷偷踢館~~~~~~~~~~~~
    請問小葉站長,這個有機會團到嗎?
    我也想報名買一個,感謝。
  2. #4202
  3. The Following User Says Thank You to hojuiyang111 For This Useful Post:
  4. #4203
  5. The Following 2 Users Say Thank You to hojuiyang111 For This Useful Post:
  6. #4204
    asr upgrade ic ,感覺聲音比較流暢, run 幾天再說了..
  7. The Following 2 Users Say Thank You to hojuiyang111 For This Useful Post:
  8. #4205
    The first stage of modification consists of 3 things to do :
    1. exchange the 10 K resistance with one 68K1, that has the largest effect on sound
    2. Offset ICs "O" instead of TL 72 - the IC marker shows always to the front panel
    3. IC input "I" instead of AD 843 SQ or 551, at the left side the IC marker is in direction
    to the front, at the right channel the marker shows to the back plate.
    The AD 843 SQ may remain at originally place depending on personal taste,
    the Emitter that sounds a little softer compared to the new input IC "I"
  9. The Following User Says Thank You to hojuiyang111 For This Useful Post:
  10. #4206
    再滿了就只好放頂樓了
  11. The Following 3 Users Say Thank You to hojuiyang111 For This Useful Post:
  12. #4207
  13. The Following User Says Thank You to hojuiyang111 For This Useful Post:
  14. #4208
    新 op 帶來新聲音,搭配它作了小調整,break in 後有不同的風貌.更平順自然是主要的優點.保留 AD 843 SQ 也有不同風情,試來試去,頭都昏了..
  15. The Following User Says Thank You to hojuiyang111 For This Useful Post:
  16. #4209
    蔡克信醫師在給我的書上簽名
  17. The Following User Says Thank You to hojuiyang111 For This Useful Post:
  18. #4210
    那麼貴的系統,好聽似乎是合理的,
    常有燒友說有些系統貴卻不好聲.
    可是為什麼不好聲呢?
    如果您評論不好聲,您可以指出不好聲的原因嗎?並作修正嗎?
    如果連您也不能,不好聲不也正常?
  19. The Following User Says Thank You to hojuiyang111 For This Useful Post:
