由原廠購入之Equalizer等化器,預售3萬
僅打開測試過而已,九成九新
已經專業人士測試過沒問題
僅接受面交喔,物品在永和
可直接來電詢問0972000796
謝謝 詳細資訊可參考http://www.bssaudio.com/en-US/products/fcs-966
Chassis 3U rack spaces Input Connectors XLR, TRS, Combicon (2 each) Output Connectors XLR, TRS, Combicon (2 each) EQ Bands 30 per channel (60 total) Filter Width (Q) Constant-Q EQ Gain +/- 15dB per band, plus - inf to +10dB overall Metering 8-segment LED per channel Bypass Switch High-Pass Filter Sweepable, flat to 250Hz Low Frequency Contour Smooth shelving filter, +/- 6dB at 50Hz High Frequency Contour Smooth shelving filter, +/- 6dB at 14kHz
