今天開箱了Atlantic 4400劇院組合,組合中包含了4400LR左右聲道喇叭,4400C中置,4400SR環繞喇叭,444SB重低音喇叭。
Atlantic Technology(以下簡稱Atlantic)由創始人Peter Tribeman最早創立於1975年,當時便以多聲套喇叭系統奠定他們於音響界的地位。Atlantic強調,一套優質的多聲道喇叭系統,不僅要讓聽眾 感受到電影院般的逼真音效,更要讓他們身處於電影情境中。也因為如此,Atlantic的旗下喇叭皆獲得THX認證。
4400LR左右聲道喇叭
網罩為磁鐵式,對準靠近就會吸附,拿下來也很方便。
背板設定可依需求調整。
環繞喇叭兩隻。
上方撥桿可調整。
4400C中置喇叭。
444 SB 重低音,體積並不是非常大。
Model 4400 LR 4400 C 4400 SR Type Sealed-box, 2-way
M-T-M arraySealed-box, 2-way
M-T-M arraySealed-box, Dipole/Bipole surround speaker Drivers Woofer (2) 5 ¼” GLH (2) 5 ¼” GLH (2) 4 ½” GLH Tweeter (1) 1" silk dome (1) 1" silk dome (2) 1” silk dome Frequency Response 80Hz – 20kHz ±3dB 80Hz – 20kHz ±3dB 80Hz – 20kHz ±3dB Nominal Impedance 8Ω 8Ω 8Ω Crossover Frequency 2.5kHz 2.5kHz 3kHz Crossover Type Computer designed Butterworth 4th-order asymmetrical (time aligned)
Linkwitz-RielySensitivity 90dB 90dB 90dB Recommended Amplifier Power 10 – 150 Watts RMS 10 – 150 Watts RMS 10 – 150 Watts RMS Magnetic Shielding Yes Yes No Dimensions w/ grilles (W x H x D) 8.3 x 15 x 9.5"
211 x 382 x 242mm18.4 x 8.4 x 9.7"*
467 x 213 x 246mm10.9 x 12.4 x 7.5"
277 x 315 x 191mmWeight (ea) 15lbs; 6.8kg 17lbs; 7.7kg w/base 11lbs; 4.99kg
Model 444 SB Type/Features Powered subwoofer, sealed enclosure
2-inch, four layer vented aluminum voice coil, vented motor
Continuous 40–140Hz crossover, 18dB/octave low pass output
Variable low level stereo inputs and low level outputs
Absolute phase invert switch
Auto signal sensingBass Driver 12” long-throw composite cone Output Power 325W RMS Distortion (amplifier) <0.5% Frequency Response 25Hz – 250Hz ±3 dB Low Level (line) 10k ohms Peak Output 105dB SPL into 2000 cubic Feet Dimensions (WxHxD)
including grille16.5 x 16.9 x 16 in.
418 x 430 x 407mmWeight 42 lbs/19.1kg Power Requirements 110-120/220-240V, 50/60Hz
