顯示結果從 1 到 4 共計 4 條
主題: 【前後級】Simaudio 740P前級、860A後級
    預設 【前後級】Simaudio 740P前級、860A後級
    740P前級與860A為Simaudio最新一代的前後級,也是立體聲前後級的次旗艦 (旗艦是850P跟870A,880M是單聲道後級)
    在外觀上仍保持的該廠一樣的傳統,並無太大的更動
    但是內部已經有許多的進化
    【燒喔】MY-HIEND FACEBOOK "讚"
    【教學】如何使用本站相簿與貼圖
    【好康】與商家交關時請報是MY-HIEND會員,以享有更好的服務喔!
  2. The Following 11 Users Say Thank You to 小葉 For This Useful Post:
    Moon 860A 內部大公開
    200 watts into 8Ω and 400 watts into 4Ω
    zero global feedback
    Custom proprietary toroidal transformer
    http://www.simaudio.com/moon860A.htm
    The Evolution of power amplification ...
    The MOON 860A Power Amplifier is a balanced differential dual-mono design that effortlessly outputs 200 watts into 8Ω and 400 watts into 4Ω. Transparency and soundstage are exceptional, despite this amplifier's high power rating. Ultimately, the 860A will mate seamlessly with any loudspeaker allowing it to reach its full sonic potential, regardless of its load.
    Several in-house developed advancements allow the MOON 860A to perform with both accuracy and grain-free character; These include (i) MOON output transistors, specifically designed for use in our amplifiers, providing tighter and more visceral bass performance, as well as unprecedented linearity thoughout the entire frequency spectrum; and (ii) our advanced "zero global feedback" circuit, commonly referred to as Lynx.
    Of course, both RS-232 and 12 Volt triggers for custom-install environments are included as well as a plethora of user selectable cosmetic options that are available at the time of purchase.
    Significant Design Features:
    · Full unsolicited RS-232 bidirectional feedback
    · Lynx circuitry which is a "no overall feedback" design resulting in genuine real-time amplification,
    a more accurate musical reproduction with respect to tonality, virtually non-existent IMD and the
    elimination of common phase errors resulting from feedback
    · Precision matched and fully decoupled proprietary MOON Bipolar output transistors with
    unprecedented gain linearity resulting in improved bass response and even more accurate
    sonic reproduction
    · Custom proprietary toroidal transformer design with lower magnetic, electrical and thermal
    loss, yielding an improved power transfer and lower regulation factor. The result is increased
    current speed and better dynamics
    · An oversized power supply
    · 12 Volt trigger input/output for remote operation
    · "Class A" output to 5 watts for greater efficiency
    · A high damping factor yielding superior musical dynamics, improved signal speed and refined
    timbre accuracy
    · A very short capacitor-free signal path for a faster transient response
    · Stable to any known speaker impedance
    · 4-Layer PCB’s with pure copper tracings for a much shorter signal path; This results in
    greater sonic accuracy and a dramatically improved signal-to-noise ratio
    · Ultra rigid chassis construction to minimize the effects of external vibrations
    · Accurate matching of the very finest quality electronic components in a symmetrical circuit design
    · Designed to be powered up at all times for optimal performance
    · Low operating temperature for a longer than normal life expectancy.
    【教學】如何使用本站相簿與貼圖
  4. The Following 4 Users Say Thank You to 小葉 For This Useful Post:
  5. #3
    Moon 740P 內部大公開
    全平衡雙單聲道設計
    http://www.simaudio.com/moon740P.htm
    · A dual-mono oversized power supply using 2 toroidal transformers in conjunction with 5 stages
    of DC voltage regulation and extensive choke filtering
    ·4 stages of our newly developed M-LoVo (MOON Low Voltage) DC regulation circuit; a highly
    sophisticated circuit made up of a clever combination of IC’s and discrete parts that is virtually
    free of noise, yielding an exceptionally fast, precise, and stable DC voltage. The result is a
    power supply with a virtually unmeasureable noise floor
    · SimLink controller port for 2-way communications with other compatible MOON components
    · M-eVOL2 volume control circuit using MDAC’s (operating in a current steering R-2R configuration)
    which alter the audio signal’s amplitude yielding no sonic degradation of the signal, regardless
    of the selected volume setting
    · 530 individual volume steps in 1dB and 0.1dB increments
    · M-Lock for “user selectable” maximum volume setting lock-out for each line input
    · Power supply voltage regulation includes i²DCf (Independent Inductive DC Filtering); There is
    one inductor dedicated to each integrated circuit type component (DAC, Op-Amp, etc.) in the
    audio circuit’s signal path - 24 stages in all
    · “Gain offset” for each individual line input with a ±10dB range
    · Each line input is fully configurable to be “home-theater ready”, where the gain section of the
    740P is bypassed
    · 12 Volt trigger output for remote operation
    · Improved reliabilty through the elimination of moving parts
    · Includes FRM-3 all-aluminum back-lit remote control.
    【教學】如何使用本站相簿與貼圖
  6. #4
    【教學】如何使用本站相簿與貼圖
  7. The Following User Says Thank You to 小葉 For This Useful Post:
