顯示結果從 1 到 5 共計 5 條
    住址
    A, A
    預設 想買後級推 Penaudio Cenya
    hi ,小第看中了
    densen b-330 and simaudio moon 330A 後級
    兩部的出力也是240W /4Ω
    沒有用家可給些意見? thx
    Densen B-330 Plus +1
    DENSEN B-330
    POWER AMPLIFIER
    DESCRIPTION
    The B-330 is a direct descendent from the top of the line B-350 monoblocks.
    The B-350 monoblocks act as the internal reference at Densen.
    Basically, the B-330 is a stereo power amp based on the B-350's technology, and uses the distinct monoblock cabinet with its recessed heatsinks as the basis for an extremely affordable reference power amplifier.
    The B-330 contains several exciting features. Externally on the backpanel there is a switch to adjust the gain, so it either works perfect with a traditional preamp or with a CD with variable output.
    There is also a D-Sub15 connector, allowing for Link connection to other Densen products, and for auto power on/off.
    The D-Sub connector can be daisy-chained in multiroom systems.
    B-330 is also prepared for the SAXO electronic crossover. This is done by mounting the crossover internally in the B-330 in a socket. The SAXO crossover will fit all passive speakers on the market.
    SPECIFICATIONS
    Power output in 8 ohms: 2 x 120W
    Power output in 4 ohms: 240W
    Power supply size: 750VA
    Storage capacity: 110.000uF
    THD + Noise @ rated output: Less than 0.1%
    Weight/shippingweight: 15/17 Kg
    Product dimensions (WxDxH): 440x310x64mm
    MOON SERIES
    330A Stereo Power Amplifier
    Significant Design Features:
    · 12 Volt Trigger input and output
    · A "no overall feedback" design resulting in genuine real-time amplification, a more accurate
    musical reproduction with respect to tonality, virtually non-existent intermodulation distortion
    and the elimination of common phase errors resulting from feedback
    · An oversized power supply
    · Custom proprietary toroidal transformer design with lower magnetic, electrical and thermal
    loss, yielding an improved power transfer and lower regulation factor. The result is increased
    current speed and better dynamics
    · Balanced differential circuitry
    · Class A output to 5 watts for greater efficiency
    · Proprietary MOON Bipolar output transistors with unprecedented gain linearity resulting in
    improved bass response and even more accurate sonic reproduction
    · A high damping factor yielding superior musical dynamics, improved signal speed and refined
    timbre accuracy
    · RS-232 port for (i) full unsolicited bidirectional feedback and (ii) firmware updates
    · PCB w/ pure copper tracings & gold plating that yields low impedance characteristics
    · Extremely rigid chassis construction to minimize the effects of external vibrations
    · Accurate matching of the very finest high quality electronic components in a symmetrical
    circuit design
    · Designed to be powered up at all times for optimal performance
    · Low operating temperature to ensure a longer than normal life expectancy.
    MOON 330A Power Amplifier Specifications
    Type Solid State
    Configuration Stereo
    Power Supply Transformer 400VA
    Power Supply Capacitance 85,000µF
    Class Of Operation A/AB
    Single-ended Input RCA - 1 pair
    Balanced Input XLR - 1 pair
    Input Device Type J-FETs
    Input Impedance 47,500 Ω
    Input Sensitivity 800mV RMS
    Output Device Type Bipolars - 4 per channel
    Output Binding Posts 5-way / Gold-plated / Shielded
    Output Power @ 8 Ω 125 Watts
    Output Power @ 4 Ω 250 Watts
    Output Power @ 2 Ω 325 Watts
    Output Power - Bridged Mono 400 Watts
    Frequency Response 10Hz - 125kHz (+0/-3dB)
    Output Impedance 0.02 Ω
    Damping Factor (static) 400
    Gain 31dB
    Signal-to-noise Ratio > 100dB @ full power
    Maximum Output Voltage 40 Volts
    Slew Rate 42V/µs
    Maximum Current - Peak / Continuous 28 amperes / 13 amperes
    IMD Unmeasureable
    THD @ 1 watt / @ 125 watts (20Hz-20kHz) < 0.02 % / < 0.05 %
    12 Volt Trigger Operation
    Direct Logic (0V = off, 12V=on) using a
    1/8" mini-jack with an input impedance of
    1K Ω and current requirement of 12mA
    Available Faceplate Finishes Black and Silver
    Power Consumption @ idle 36 Watts
    AC Power Requirements 120V / 60Hz 240V / 50Hz
    Fuse Replacement - 120V 6A long fast blow
    Fuse Replacement - 230V 3A long fast blow
    Shipping weight 33 lbs / 15 Kgs
    Dimensions (W x H x D) 16.9 x 3.5 x 14.0 in. (42.9 x 8.9 x 35.6 cm.)
    Features & specifications are subject to change without notice.
    DENSEN..聲底乾淨 透明度高........DENSEN B-330+1票
