第1頁,共3頁 123 最後最後
顯示結果從 1 到 10 共計 26 條
    預設 加拿大 Hansen Audio Emperor E 喇叭
    今年CES上公開亮相的全新Hansen Audio E系列,這次音響展上代理商也引進了
    今回開箱的是Emporer E
    奢華皮革包覆的版本(非動物皮):Luxury Leather TERRA COTTA
    Emporer E為3音路6單體的設計,後方也多了一顆高音單體
    所有Hansen單體使用多層複合三明治結構的錐盆
    箱體也全新設計,研發出Diffraction Distortion Elimination technology的技術
    讓相位更為一致,並且共振與失真最小
    一個箱子就這麼大,高快200cm,單隻重(含箱)為200多Kg
    開箱使用電動起子是一定要的
    這次開箱有請美麗的助理Miranda幫忙
    若有需要更多高清隱藏版開箱照片請回在版上
    打開了
    喇叭因為太重了,沒有過程......只能拍出已拿出來的空箱,裡面黑色的是面網
    非常漂亮
    後方也有一顆高音
    喇叭端子為WBT,為Single-wiring的設計
    ENCLOSURE
    GENERAL
    - Time Coherent
    - Dispersion Coherent
    - Frequency Response: 19 hz to 23,000hz +/-2db
    - Sensitivity: 87db
    - Nominal Impedance: 6 Ohms
    - True Dynamic
    - Tonal Accurate
    TECHNOLOGY
    - Engineered, designed, and manufactured by Hansen Audio
    - Sound wave diffraction distortion elimination technology
    - Acoustically inert
    TERMINAL CONNECTIONS
    - High current pole terminal
    - Decreased transition resistance
    WEIGHT - 450lbs. (In Crate)
    SIZE
    - Height: 61 inches
    - Width: 14 inches
    - Depth: 24 inches
    FINISHES- Luxury Leather (Animal Free)
    - Hansen Audio Luxury Leather - Black
    - Hansen Audio Luxury Leather - Stone
    - Hansen Audio Luxury Leather - Terra Cotta
    GRILLS
    - Driver protection grills included
    (to be removed during critical listening)
    DRIVERS
    TWEETER X 2
    - Engineered, designed and manufactured for Hansen Audio
    - 25mm high performance dome mounted on a dispersion optimized 6mm aluminum plate
    - Precision assembled
    MID BAND DRIVER X 2
    - Engineered, designed and manufactured by Hansen Audio
    - 182 mm drivers
    - Exotic multi-layer composite sandwich cone
    - Optimized geometry "Hansen motor system"
    - Hand assembled "Hansen Architecture" frames
    - Sound wave deformation prevention
    WOOFER x 2
    - 269 mm drivers
    - Exotic multi-layer composite sandwich cone;
    CROSSOVER
    - Hansen Audio Enlightened Technology
    www.hansenaudio.com
  2. The Following 9 Users Say Thank You to Leo Yeh For This Useful Post:
    有靚箱看,有靚女看,哈哈
  4. The Following User Says Thank You to 故事 For This Useful Post:
  5. #3
    優的~~我要隱藏版拉~~電話最好也來一下~~
  6. The Following User Says Thank You to sirayliu For This Useful Post:
  7. #4
    引用 作者: sirayliu 查看文章
    ok 我的電話先給你
  8. #5
    哇!好搶眼呀⋯眼睛睜不開了!!!
  9. #6
    隱藏版照+1+1...
  10. The Following User Says Thank You to edwardmos For This Useful Post:
  11. #7
  12. The Following User Says Thank You to chsiang For This Useful Post:
  13. #8
    這對喇叭在音響展有看到,非常的搶眼,不過這開箱更炫目呀!
  14. The Following User Says Thank You to hidoson For This Useful Post:
  15. #9
  16. The Following 4 Users Say Thank You to Leo Yeh For This Useful Post:
  17. #10
    這也漂亮的太犯規了!
  18. The Following 2 Users Say Thank You to BHMzero For This Useful Post:
